440source timing cover OOPS! Will not work with TCI
#901834
01/11/11 02:28 AM
01/11/11 02:28 AM
Posts: 305 5th and plum
redmist
5th and plum
I picked up a 440 source aluminum timing cover for my build. This unit looks great. I had to take some material off the cam bolts to get the cover to fit on (as per 440source) and that's not a problem. What is a problem is it looks like the cover WILL NOT work with a TCI "Rattler" dampener. The Dampener bottoms out on the seal housing before I get it snugged down with the dampener bolt! Is anyone running this cover with an aftermarket Dampener?? Wich one works? Looks like I may be selling my "rattler" in order to get a unit that will work with the cover. I love the look of the cover!
Re: 440source timing cover OOPS! Will not work with TCI
[Re: redmist]
#901837
01/11/11 03:02 AM
01/11/11 03:02 AM
redmist
5th and plum
Ok. I busted out the caliper... The TCI rattler fits over the stock cover seal. The seal portion is small enough to fit into the recess on the Dampener. The 440source cover is almost a quarter inch bigger then the stock cover!!! In this picture, i have held up the caliper with the same measurement as seen in the first pic. DAMN! Looks like it's a stock cover going on. God only knows what aftermarket parts would work with this cover. And it's even one of their 100% made in the USA parts. Poop..
[Re: redmist]
#901838
01/11/11 03:27 AM
01/11/11 03:27 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
We have an SFI approved damper with that cover, one of the cheap ones but son't remeber the brand. Just out of the memory, I would say that most aftermarket dampers have a bigger recess in the rear, and would fit.
Plynouth VIP '67 TT IC EFI
[Re: Twin Turbo Mower]
#901840
01/11/11 08:00 AM
01/11/11 08:00 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I noticed the other day that AndyF mentioned his timing cover won't work with a Rattler. I love my TCI Rattler but I may have to sell it and get an ATI for better timing cover options.
[Re: ProSport]
#901842
01/11/11 01:09 PM
01/11/11 01:09 PM
Posts: 31,078 Oregon
AndyF
I've never owned a TCI damper but I did have a customer tell me once that his Rattler damper wouldn't fit my billet covers. I think the screw heads on the back side of the damper rubbed on the cover but he didn't send me a picture so I'm not positive.
[Re: '72CudaRacer]
#901844
03/20/11 02:08 AM
03/20/11 02:08 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
If any of the above mentioned Rattlers come up for sale,I'd be very interested...PM me.
[Re: Al_Alguire]
#901847
03/20/11 02:30 AM
03/20/11 02:30 AM
Posts: 3,245 Between a rock & a hard place
cudadoug
Maybe I'm missing something, but what's the point of this timing cover? Or any that won't work with any dampner?? I could see if it was some trick piece...two piece for easy cam and/or cam timing changes maybe...
What's wrong with the cheap MP chromie for some bling, or a nice powder coated stock one??
They sell them with instructions that the cam bolts won't clear??? What the heck??!!?? Why not ENGINEER the part to work in the first place???
