Another How fast will it go... #901767
01/10/11 10:54 PM
01/10/11 10:54 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Here's the combo, what do you think? I know the downfalls in the combo for what I want to do with it, but as it sits, what do you guys predict?
360 smallblock chrysler stock stroke .030" over KB pistons 10.5:1 CR with 0.040" quench
IMM prepped RHS iron heads flow peaks 271 at 550" on the int, 190 at 550" exh
Bullet hydraulic roller cam 243/251 at .50 duration, lift is 562/562 on a 109 LSA with 4 degrees advance ground in on a 1.5 rocker (not sure if i should step up to the 1.6 and getting 600/600 out of it). Exh lobe is considering light nitrous use in the future as well
Was told rpm range would be 1500-6200, but possibly higher?
Edelbrock RPM air gap port matched with a Holley 750HP on top
1-5/8" headers into a 3" exhaust with Borla race mufflers and x pipe
The car weighs 3400lbs with me in it and is getting a dana with 4.10 gears
Car has a 28x12.5 ET street bias ply and has the full caltrac setup out back, with calvert 90/10's up front, 6cyl torsion bars and adjustable upper control arms
Transmission is a a chrysler 4 speed 2.66 first transmission with a centerforce dual friction clutch and a v-gate shifter with two step (hopefully will help with consistency some and not missing gears)...Im a pretty good driver and at the track the gas will be matted 110% of the time
lets hear it! hopefully my hopes for it are close to what it should run
Re: Another How fast will it go... [Re: mshred] #901768
01/11/11 12:12 AM
01/11/11 12:12 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
the weight is what concerns me, i would say at 3000lbs thats a 10 sec car, at 3400 id say 10.50-10.70
....BAD A$$ STREET CAR.....
Re: Another How fast will it go... [Re: n20mstr] #901769
01/11/11 12:21 AM
01/11/11 12:21 AM
Outside
thedriver Offline
thedriver  Offline
Outside
11.70's NA
1973 challenger
Dana. 4 speed. Low deck.
Re: Another How fast will it go... [Re: n20mstr] #901770
01/11/11 12:25 AM
01/11/11 12:25 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
thats generous lol unless thats on the gas? I shoulda made it clear to everyone that im looking for NA predictions
its a heavy one with me in it, but its all steel, full interior street car...only light weight thing are the wheels and the 4door back seat (Weighs nothing!)
please keep them coming guys, I need to get an idea if im on the right track
Re: Another How fast will it go... [Re: thedriver] #901771
01/11/11 12:27 AM
01/11/11 12:27 AM
Q
Quicktree Offline
Quicktree  Offline
Q
mid 11s
Re: Another How fast will it go... [Re: Quicktree] #901772
01/11/11 12:30 AM
01/11/11 12:30 AM
N
n20mstr Offline
n20mstr  Offline
N
ooops i meant to say 10.90's at 3000 then 11.50 - 11.70 at 3400
work on the weight man.
Re: Another How fast will it go... [Re: mshred] #901773
01/11/11 12:32 AM
01/11/11 12:32 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Your weight is about 100 lbs lighter than a Challenger I had and with a much more tame 360, I went 11.70, but I had 4.56 gear, 28x10.5 slicks, auto, 3500 converter, home ported stock heads, .540 flat solid, 9:1 compression.
If you can row those gears, I would think 11.4's.
Re: Another How fast will it go... [Re: TheOtherDodge] #901774
01/11/11 12:38 AM
01/11/11 12:38 AM
Az
Crizila Offline
Crizila  Offline
Az
12.000000's on a good day.
Fastest 300
Re: Another How fast will it go... [Re: Crizila] #901775
01/11/11 12:50 AM
01/11/11 12:50 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
4 speed...
how good can you shift?
and getting the car to launch without bogging it.
Tony
70 AARCuda Vitamin C
Re: Another How fast will it go... [Re: 70AARcuda] #901776
01/11/11 12:53 AM
01/11/11 12:53 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
4 speed...
I can hit the gears pretty good, and the v-gate is there to try and eliminate missed shifts
I know my gear ratio is going to kill me though....it being a stickshift with only 4.10's, im hoping if i launch high enough it won't bog, but Im not sure...not many stick combos to compare too that are mopar
Id go to a higher numerical gear, but this car sees alot of street use and the 4.10's with a 28" tire are already pushing it for the highway
what do ya think?
Re: Another How fast will it go... [Re: mshred] #901777
01/11/11 01:02 AM
01/11/11 01:02 AM
Renton Washington
Triple Threat Offline
Renton Washington
The motor is gonna make enough power to push the car well into the 11's. Whether or not you can do you job will be the biggest factor.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Another How fast will it go... [Re: mshred] #901778
01/11/11 01:28 AM
01/11/11 01:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: Another How fast will it go... [Re: MR_P_BODY] #901779
01/11/11 09:04 AM
01/11/11 09:04 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I'm thinking you could go easy 11.40's if it hooks, I ran 11.70's all night long with a 4 speed a-body with a W2 340 isky solid.....30 years ago.
Cam spec's look good for what you are doing, I like the 1.6 rockers.
WIZE
In Car:
Re: Another How fast will it go... [Re: Streetwize] #901780
01/11/11 10:36 AM
01/11/11 10:36 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
my combo faster than a W2 combo? not questioning, just surprises me...How high were you spinning that 340 with the solid?
A member here has offerred to shim my hydraulic lifters in combination with a spring using about 150 open seat pressure so that i can rev up to 7k if needed
Re: Another How fast will it go... [Re: mshred] #901781
01/11/11 10:47 AM
01/11/11 10:47 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Spun it 7200, eventually 7800 going to 4.56 gears....big block boyz HATED me back then
I doubt my old first get W2's flowed much better than your RHS's, I was barely 18 and all I did was a bowl clean up and VJ on them. I eventually got them worked to flow around 290. When I detuned it to my daily work car it still ran high 11's switching to 3.91's and an ultradyne hydraulic 231/239 flat tappet.
your ET is going to be in the 60'....if you get a 360 to hook just right you just row it through and she'll et.
Didn't understand your open/seat comment...did you mean 150 on the seat?
WIZE
In Car:
Re: Another How fast will it go... [Re: Streetwize] #901782
01/11/11 10:49 AM
01/11/11 10:49 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
cool...yes I meant 150 on the seat
please keep the predictions coming guys!
Re: Another How fast will it go... [Re: mshred] #901783
01/11/11 12:05 PM
01/11/11 12:05 PM
SoCal
Brian Hafliger Offline
SoCal
You don't need to shim the lifters...run the heads they way you get them and run the lifters untouched.
Run 10w40 oil and let it eat. I've run hyd. rollers with our RHS heads up to 7000rpm and still not had any lifter pump.
Brian
Brian Hafliger
Re: Another How fast will it go... [Re: Brian Hafliger] #901784
01/11/11 12:47 PM
01/11/11 12:47 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I personally think 11.90s. If it had a stroker crank id say 11.40s.
Re: Another How fast will it go... [Re: viperblue72] #901785
01/11/11 02:25 PM
01/11/11 02:25 PM
mi
dirty magnum Offline
mi
13.30
Re: Another How fast will it go... [Re: dirty magnum] #901786
01/11/11 03:26 PM
01/11/11 03:26 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
I think it should go 11.50 or better pretty easy.
You weigh 500 more than mine and have enough power there to at least run a tenth better. Check my sig.
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
