Re: Heater Box resto?
[Re: screamindriver]
#901444
01/12/11 03:03 PM
01/12/11 03:03 PM
Posts: 1,384 Back In Iowa
belv2vert66
Back In Iowa
Thanks for the info on the font and size Mark. I looked at the preview with the 2 point border option also. Maybe have to request the 1 point ? Or is that the default size or something when we select border Also, Does anyone know what number goes on a 68 box ? Thanks, Al
[Re: belv2vert66]
#901446
01/12/11 03:14 PM
01/12/11 03:14 PM
Posts: 836 lancaster, new york
macmic87
lancaster, new york
Thanks, Al
number is 2837500. that is the same for 1968 and 1969.
[Re: macmic87]
#901448
01/12/11 03:20 PM
01/12/11 03:20 PM
macmic87
lancaster, new york
the fiberglass part of the box is the same from 1966-1970. 1966-67 has some differences with the heat/ defrost flapper and a seperate part number (MODEL 747). 1968-1970 are all the same with 2 slight differences. first the part number. and, second the reason it is a different part number is the heater core. 1966-1969 is the same heater core with a 5/8 inlet and a 5/8 outlet. the 1970 has a 1/2 inlet with a 5/8 outlet.
[Re: macmic87]
#901451
01/12/11 04:03 PM
01/12/11 04:03 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
I washed mine really good and then took a light buffing compound and went over the whole thing. turned out really nice. then I lightly waxed it. how did you restore the resister? or is that NOS? thanks! -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: gtx6970]
#901452
01/12/11 05:05 PM
01/12/11 05:05 PM
macmic87
lancaster, new york
I knew 67 was laid out different,, just couldn't remember the number , is 1966 the same as 67 ?
I have a couple boxes to do this winter and plan to get the stamps made locally
as far as i know, yes
[Re: mopars_1]
#901453
01/12/11 05:06 PM
01/12/11 05:06 PM
macmic87
lancaster, new york
just washed it. a little blow dry and covered the contacts and gave it a light coat of satin poly.
[Re: macmic87]
#901454
01/12/11 08:45 PM
01/12/11 08:45 PM
Posts: 1,170 Richmond, VA
rayztoy
Richmond, VA
What is satin poly?
[Re: macmic87]
#901458
01/12/11 10:28 PM
01/12/11 10:28 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
for the 1970 b body non a/c heater box number 2936680 go to http://www.rubberstampchamp.com/custom.aspx?id=30 then go to size 3/4 x 3 and type in 2936680. font- futura book, size 38, bold, with a 1 pt border. nice source to get my stamps for all of these.
Nice stash and info...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: JMCFAN]
#901459
01/12/11 10:40 PM
01/12/11 10:40 PM
macmic87
lancaster, new york
i have the part number from the actual part listing from chrysler. let me see if i can post it. next to the blue high lighter you can see that the part number for a 1970 non a/c car is 2836680. not saying that yours is not original, but this is what i am going by. [image][/image]
[Re: macmic87]
#901460
01/12/11 10:46 PM
01/12/11 10:46 PM
Posts: 2,120 New Mexico
JMCFAN
New Mexico
wierd. Definelty a 70RR...and from the disaasembly I dont think the box has been out of the car...
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: macmic87]
#901463
01/12/11 11:28 PM
01/12/11 11:28 PM
JMCFAN
New Mexico
Where do I find the build date? I have data tag and vin. no build sheet.. cool puzzle.
