Page 2 of 5 1 2 3 4 5
Re: Heater Box resto? [Re: screamindriver] #901444
01/12/11 03:03 PM
01/12/11 03:03 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Thanks for the info on the font and size Mark. I looked at the preview with the 2 point border option also. Maybe have to request the 1 point ? Or is that the default size or something when we select border
Also, Does anyone know what number goes on a 68 box ?
Thanks,
Al
Re: Heater Box resto? [Re: belv2vert66] #901445
01/12/11 03:12 PM
01/12/11 03:12 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
the options have changed. but, i think the 2pt will work well also.
Re: Heater Box resto? [Re: belv2vert66] #901446
01/12/11 03:14 PM
01/12/11 03:14 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
Thanks,
Al
number is 2837500. that is the same for 1968 and 1969.
Re: Heater Box resto? [Re: macmic87] #901447
01/12/11 03:18 PM
01/12/11 03:18 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
What the number for 70 B Body non/A/C ?
CHECK OUT MY NEW WEB SITE !
Re: Heater Box resto? [Re: macmic87] #901448
01/12/11 03:20 PM
01/12/11 03:20 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
the fiberglass part of the box is the same from 1966-1970. 1966-67 has some differences with the heat/ defrost flapper and a seperate part number (MODEL 747). 1968-1970 are all the same with 2 slight differences. first the part number. and, second the reason it is a different part number is the heater core. 1966-1969 is the same heater core with a 5/8 inlet and a 5/8 outlet. the 1970 has a 1/2 inlet with a 5/8 outlet.
Re: Heater Box resto? [Re: anlauto] #901449
01/12/11 03:35 PM
01/12/11 03:35 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
the way I see it
2936680 is 1970 B-body non air
2837500 is 1968-69 B-body non air
2936602 is E-body I think all 5 years non air
I knew 67 was laid out different,, just couldn't remember the number , is 1966 the same as 67 ?
I have a couple boxes to do this winter and plan to get the stamps made locally
Re: Heater Box resto? [Re: gtx6970] #901450
01/12/11 03:41 PM
01/12/11 03:41 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
the way I see it
I knew 67 was laid out different just couldn't remember the number , is 1966 the same as 67 ?
I havea couple boxes to do this winter and plan to get the stamps made locally
Will post a picture tonight but my 70 RR non AC shows 2936681... ?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Heater Box resto? [Re: macmic87] #901451
01/12/11 04:03 PM
01/12/11 04:03 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
I washed mine really good and then took a light buffing compound and went over the whole thing. turned out really nice. then I lightly waxed it. how did you restore the resister? or is that NOS? thanks!
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Heater Box resto? [Re: gtx6970] #901452
01/12/11 05:05 PM
01/12/11 05:05 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
as far as i know, yes
Re: Heater Box resto? [Re: mopars_1] #901453
01/12/11 05:06 PM
01/12/11 05:06 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
-kevin
just washed it. a little blow dry and covered the contacts and gave it a light coat of satin poly.
Re: Heater Box resto? [Re: macmic87] #901454
01/12/11 08:45 PM
01/12/11 08:45 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
What is satin poly?
Re: Heater Box resto? [Re: rayztoy] #901455
01/12/11 08:49 PM
01/12/11 08:49 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
spray can of satin polyurethane
Re: Heater Box resto? [Re: JMCFAN] #901456
01/12/11 10:11 PM
01/12/11 10:11 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Photo of box on m 70RR
Re: Heater Box resto? [Re: JMCFAN] #901457
01/12/11 10:13 PM
01/12/11 10:13 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Another
Re: Heater Box resto? [Re: macmic87] #901458
01/12/11 10:28 PM
01/12/11 10:28 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
for the 1970 b body non a/c heater box number 2936680 go to http://www.rubberstampchamp.com/custom.aspx?id=30
then go to size 3/4 x 3 and type in 2936680. font- futura book, size 38, bold, with a 1 pt border. nice source to get my stamps for all of these.
Nice stash and info...
Troy
Houston Mopar Connection Club
Re: Heater Box resto? [Re: JMCFAN] #901459
01/12/11 10:40 PM
01/12/11 10:40 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
i have the part number from the actual part listing from chrysler. let me see if i can post it. next to the blue high lighter you can see that the part number for a 1970 non a/c car is 2836680. not saying that yours is not original, but this is what i am going by.
[image][/image]
Re: Heater Box resto? [Re: macmic87] #901460
01/12/11 10:46 PM
01/12/11 10:46 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
wierd. Definelty a 70RR...and from the disaasembly I dont think the box has been out of the car...
Re: Heater Box resto? [Re: macmic87] #901461
01/12/11 11:02 PM
01/12/11 11:02 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
from left to right 1966, 1967, 1968-69, 1968-69, 1970. all b body non a/c.
Re: Heater Box resto? [Re: JMCFAN] #901462
01/12/11 11:17 PM
01/12/11 11:17 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
thought maybe i had an answer. for 1969 if the heater box was in a canadian car the part number was 2837501 in stead of 2837500. went back and checked to see if that was so for the 1970 and it was not. the number ends up being 2936068 (canadian) instead of what i am used to seeing 2936680. well you can see that in the above post. what is the build date of your car? maybe it is late in the model year. with mopar, never say never.
Re: Heater Box resto? [Re: macmic87] #901463
01/12/11 11:28 PM
01/12/11 11:28 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Where do I find the build date? I have data tag and vin. no build sheet..
cool puzzle.
