Page 1 of 5 1 2 3 4 5
Heater Box resto? #901424
01/10/11 07:07 PM
01/10/11 07:07 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
70RR. In process of restoring a non-AC heater box. Already ordered kit from member here
How do you restor the fiberglass box? I see YO sells a kit with cleaner and spray base and top coat... anyone use it? Is there something better etc...?
Also how do you reproduce the yellow part# on the metal plate?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Heater Box resto? [Re: JMCFAN] #901425
01/10/11 07:26 PM
01/10/11 07:26 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
I simply power washed mine. Some guys power wash and then lightly clear. I did not clear mine.
As for the part number. Mine was still visable and I left it. However, I think there is a member that has the stamp or template. Maybe others will chime in.
65 Barracuda
70 Challenger
Re: Heater Box resto? [Re: JMCFAN] #901426
01/10/11 08:26 PM
01/10/11 08:26 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
usually lightly, and i mean lightly blast the fiberglass box. it will turn a lighter gray color. blow it off good and clear with a poly satin finish. the satin poly will bring the color back. i had a stamp company make my stamps for the part numbers.
[img]https://uniim1.shutterfly.com/ng/service...1143434/enhance[/img]
[img]https://uniim1.shutterfly.com/ng/service...1143394/enhance[/img]
Re: Heater Box resto? [Re: jrwoodjoe] #901427
01/10/11 08:39 PM
01/10/11 08:39 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I power washed mine as well and scrubbed hard with a brush and Simple Green while concentrating on the "corners". I agree that mine does not need clear on the box. Be careful if powerwashing on concrete, it will scar the box if it moves around. Most people blast the sheetmetal parts and repaint as appropriate. Some high enders zinc plate brackets flap doors and clips. I am going to paint mine.
Make sure if you aren't positive of it's condition to get the heater core checked out. Rivets for the brackets you drill out will be different and many suggest a washer so they won't pull through the fiberglass
I am about half way through mine right now and need the stamp as well. I was going to do with out but if it is available and reasonable, I'd love to hear the source.
PS, you didn't damage the blower motor taking the fan off did you ? I did, and it is not a cheap lesson.
Re: Heater Box resto? [Re: belv2vert66] #901428
01/10/11 08:55 PM
01/10/11 08:55 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
No...got the blower fan off OK...little WD and a some sore fingers...
Was wondering about the brackets that are rivited on... drill them out?
The rest is all apart and have blasted ( glass bead) 1/2 of them... looking good so far
Re: Heater Box resto? [Re: belv2vert66] #901429
01/10/11 08:58 PM
01/10/11 08:58 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
while the subject is at hand.
I have a B-body non air box on the bench now. And the slotted hex head screws for the ft cover are what appear to be black phosphate,maybe zinc but they are definitly black and not silver or clear. Where as on the remainder of the assy holding the box together are clear / silver
it's out of a 67 GTX if it matters
Enjoy life today, It has an expiration date
Re: Heater Box resto? [Re: JMCFAN] #901430
01/10/11 08:58 PM
01/10/11 08:58 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
also....how did you restor your resistor plate...looks sweet!
Re: Heater Box resto? [Re: gtx6970] #901431
01/10/11 11:14 PM
01/10/11 11:14 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Bill, I can't tell what my front cover screws on the 68 box were. Too rusted. Definitely clear zinc on the rest as far as I can tell.
Mark (above post) restores an awesome box and has been very helpful to me.... I have done several but the last A body turned out well for me....
don't forget the drivers side vent...
Re: Heater Box resto? [Re: belv2vert66] #901432
01/11/11 08:31 AM
01/11/11 08:31 AM
gtx6970 Offline
gtx6970  Offline
Al, When I started taking this box apart it thought it seemed odd the front plate screws would be black , yet the screws on the back cover and the box halves were clear zinc.Otherwise it's the exact same screw in dimensions and appearence
maybe it's a year thing as this box is supposed to be from a 1967 GTX hardtop
Re: Heater Box resto? [Re: gtx6970] #901433
01/11/11 07:24 PM
01/11/11 07:24 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
I wouls also be interested in the stamp....mine is 2936681. How did you get it?
Also what paint did you use on the metal parts aftr blasting?
Re: Heater Box resto? [Re: JMCFAN] #901434
01/11/11 08:06 PM
01/11/11 08:06 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
What I've done in the past for stamps...
Easiest way...Find a local company that makes rubber stamps and have them scan the original into their computer.
The other choice...Spend some time with your "Word" program on your computer searching the 100's of different fonts until you find one the same or real close. Then print it off playing with the "size" and "spacing" until it matches.
Print it off, draw a box around it with a black marker....NOW take that to a local Staples or something similar and get a stamp made...Cost $20-$30 probably....Use it once then sell it to me
CHECK OUT MY NEW WEB SITE !
Re: Heater Box resto? [Re: anlauto] #901435
01/12/11 08:45 AM
01/12/11 08:45 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
stamps are not that tough to get made. found an online place did a few proofs and had them shipped out in less that a week. usually less than $10 a stamp.
Re: Heater Box resto? [Re: macmic87] #901436
01/12/11 08:56 AM
01/12/11 08:56 AM
anlauto Offline
anlauto  Offline
Please share the on line info..
Re: Heater Box resto? [Re: macmic87] #901437
01/12/11 09:26 AM
01/12/11 09:26 AM
gtx6970 Offline
gtx6970  Offline
I have a local mom and pop print company make them for me. as long is it doesn't have 'artwork ' on it they usually run in the $10-$15 range .
I had a stamp made for the 69 and down voltage regulator a few months ago as an example and they were about $15 each
Ones with artwok , such as a pentastar for example ran in the $25 each range
Re: Heater Box resto? [Re: gtx6970] #901438
01/12/11 09:57 AM
01/12/11 09:57 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Same here, $15 at my local stamp shop for the 2837500
Troy
Houston Mopar Connection Club
Re: Heater Box resto? [Re: macmic87] #901439
01/12/11 11:51 AM
01/12/11 11:51 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Could you share the size and font?
Re: Heater Box resto? [Re: JMCFAN] #901440
01/12/11 12:13 PM
01/12/11 12:13 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
for the 1970 b body non a/c heater box number 2936680 go to http://www.rubberstampchamp.com/custom.aspx?id=30
then go to size 3/4 x 3 and type in 2936680. font- futura book, size 38, bold, with a 1 pt border. nice source to get my stamps for all of these.
[image][/image]
Re: Heater Box resto? [Re: macmic87] #901441
01/12/11 12:46 PM
01/12/11 12:46 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Why would mine show 2936681.... ?
Re: Heater Box resto? [Re: JMCFAN] #901442
01/12/11 01:06 PM
01/12/11 01:06 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
if you can, post a pic. i would like to see it.
Re: Heater Box resto? [Re: macmic87] #901443
01/12/11 01:25 PM
01/12/11 01:25 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I tried your link for the stampings...Thanks...One question, it won't let me use a 1 pt border...It starts at 2...Was this a typo ???
