Re: C-body front disc brakes?
[Re: Andrewh]
#899686
01/11/11 11:58 AM
01/11/11 11:58 AM
Posts: 1,044 minnesota
president61
minnesota
should be 69 I think.
The rotors are 2 piece till 72, and should be the same. calipers too, till the change in 73, though honestly I am not sure if the 73 caliper is different. I know the spindle and rotor are different in 73 only. That is the 73 rotors do not work on 72 and back spindles, and vice versa. Even though they bolt up to the suspension the same.
Actually late 72 models had the 73 parts
