Re: What creates engine rpm?
[Re: mopar_man]
#898370
01/13/11 02:30 PM
01/13/11 02:30 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
I suspect, even though it may be impossible to measure that the crank may not be travelling at a constant speed in one revolution as the piston speed changes four times every revolution. everybody agree?
Yep, it's true the speed changes throughout each revolution. Engines with greater # of cylinders get more 'bumps' per revolution and that's what makes them feel smoother with less NVH (all else equal, of course).
No, it's not impossible to measure. Truck diesel engines have increasingly-strict emissions control, and the crankshaft sensor can detect a void in acceleration of the crank due to a misfire, and then determine which cylinder it was.
[Re: Fury Fan]
#898371
01/13/11 02:57 PM
01/13/11 02:57 PM
Posts: 8,915 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
You have the counterweights on the crank doing their part to maintain inertia. The piston may be changing speed as it changes direction but the crank is still rotating in the same direction. With the additional weight of a flywheel on the end of a crank I'd have to disagree and say the speed would be constant.
If your theory were true then it would be a miracle that single cylinder 4 stroke motors run at all.
[Re: Stanton]
#898372
01/13/11 04:26 PM
01/13/11 04:26 PM
[Re: pressureangle]
#898374
01/13/11 05:30 PM
01/13/11 05:30 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Sorry, it's a fact. (I'm an ASE Master Heavy Truck tech, and worked the past 3 years for Navistar Defense) It's true, modern diesels (and likely some modern gas engines) can detect misfire through time change in the crank sensor.
And yes, if you remove enough counterweight from a single cylinder engine, it stalls more easily and requires a higher idle RPM. Have a look at model airplane engines, the old COX .049 has no flywheel or counterweight at all.
Nobody's arguing that a misfire will slow down a motor - put enough misfires in sequence and its called "killing the ignition" and yes, the motor WILL slow down and (I'm going out on a limb here !!) eventually come to a complete stop.
And I won't argue that if you remove the flywheel and any counterweights you will also see the crank slow down. But let's be practical and talk about common, everyday engines in normal operating modes. Any properly running engine will have absolutely no detectable loss of speed between firing stokes.
[Re: Fury Fan]
#898376
01/14/11 09:44 AM
01/14/11 09:44 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I agree with Fury Fan.
With the right oscilloscope, torque sensors, rpm sensors and pressure gauges inside the cylinder you can see all the slight changes in rotation, even with heavy counterweight and flywheels.... even with Mazda Wankel design engines.
The NVH (noise vibration and harshness) engineering teams at all the major automakers do this routinely even out on the 'convoy style' road trips you see a group of new vehicles making, such as out at Death Valley National Park.
People think of crankshafts as massive and so stiff they resist twisting completely, but it is more accurate to think of them like big 'Chrysler Torsion Bar Springs' because they not only twist but they are constantly oscillating back and forth in very complex ways.
