Paint Samples... #897800
01/06/11 02:14 PM
01/06/11 02:14 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
For all you Paint and Body guys.. Its time to paint the new hot rod and the body shop that it will be going to, is under contract with Dupont paint.. so I have a couple of questions for ya..
1) Is Dupont hard enough to survive the race track? That includes the fiberglass hood, front end and trunk lid.. The paint on my 73 scratches so easily.. all you have to do is hold a screwdriver tip a foot away and its scratched.. So I would like a hard paint that will hold up to the typical bumps, knicks and scratches
2) I havent decided on the final color yet, but am leaning towards silver, orange or lime green... is there any pro's or con's to these colors..?
3) Will there be a difference in color when applied to the steel body vs the fiberglass parts? I remember the two tone look of the GM's a few years back when they had the plastic bumper covers..
4) Is there a website that shows paint samples for the Dupont paint?
Lastly, for those that are curious.. its a tubbed 70 Duster.. and feel free to offer any other suggestions or advise..
Thanks in advance
2)
Re: Paint Samples... [Re: Jeepmon] #897801
01/06/11 02:31 PM
01/06/11 02:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Why not use a clear coat so it doesnt scratch as easy
and if you get a scratch you can wheel it out pretty
easy... you shouldnt see any color difference in the
metal or glass because it should be sealed before paint
Re: Paint Samples... [Re: MR_P_BODY] #897802
01/06/11 02:36 PM
01/06/11 02:36 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks Raff.. as you can tell.. my ignorance is showing.. I'm sure the body shop (very very close friend too) will do me right, but I figured it wouldnt be a bad thing to know a little something about this subject before I drop off the car..
Re: Paint Samples... [Re: Jeepmon] #897803
01/06/11 02:40 PM
01/06/11 02:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Even if you go with a single stage paint you can still
clear it
Re: Paint Samples... [Re: Jeepmon] #897804
01/06/11 05:48 PM
01/06/11 05:48 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
1) Is Dupont hard enough to survive the race track? That includes removing the fiberglass hood, front end and trunk lid.. The paint on my 73 scratches so easily.. all you have to do is hold a screwdriver tip a foot away and its scratched.. So I would like a hard paint that will hold up to the typical bumps, knicks and scratches
I painted my car in 1981 with DuPont CENTARI acrylic enamel.It's got a few nicks here and there,but it has held up very well and still has a nice gloss after 30 years.
Orange and red are more expensive paint
No,my car has a fiberglass hood and the basic prep is the same as if it were steel.The color is the same also.
The DuPont site has their own "Hot Hues" which is similar to House Of Kolor paint. You can also go to a paint store and look at a color chip book.
Thanks in advance
2)
Nautilus Racing-
Re: Paint Samples... [Re: Chris2581] #897805
01/06/11 06:14 PM
01/06/11 06:14 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Don,
DuPont 2 stage is just as tough as any OEM paint. You can go with their Urathane clear which is the most durable. Since your buddy is an auto body guy he'll know exactly how to formulate the clear. If not done right the clear can be brittle....or too soft...one scratches...the other fractures and flakes off.
Red and Orange are expensive...but both hide body flaws well....
And if your doing Lime Green....be careful of metallics...they are tricky in the line colors.
if everything is primered....then sealed it will be the same color all over. the whole car needs to be primed and sealed at the same time. If not they can gas out at different rates and cause minor color shift. make sure he uses sealer closest to the color you choose. Lime Green....go white sealer....dark colors...dark sealers.
My buddy has been laying down paint since the early 90's....and we use nothing but DuPont and House of Colors on my stuff.
As far as color samples.....your buddy should have a CHIT book if he has the DuPont mixing system....we just paint my boys Junior the new Honda Accord midnight black...it actually has blue pearl and blue mica flake....turned out awesome in the sun.
Re: Paint Samples... [Re: Chassisman] #897806
01/06/11 06:26 PM
01/06/11 06:26 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
There is so many good paints out there. I have cheap dupont nason select base and clear coat on my car!! It is a good clear but if I was doing it again I would use the high end dupont clear, Cant remember the number off the top of my head but it is much better. It sands and buffs up alot easier then the nason clear. I dont know that much about it but my good friend owns a body shop and I spend alot of time there and am catching on. He has a dupont mixing bank. He has herd alot of good about some of the new water based clears. I have also herd that valspar makes some top of the line clears.
67' charger 499 RB 10.57 at 127
Re: Paint Samples... [Re: dragram440] #897807
01/06/11 07:22 PM
01/06/11 07:22 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
The base coat is water based not the clear.Use's the same clear as always.I'am not a fan of Dupont.The color is like water and does not cover but I'am sure your guy nows that,LOL.Silver is a great color for a race car.Hides tons of little things.
Re: Paint Samples... [Re: 8secDart] #897808
01/06/11 07:27 PM
01/06/11 07:27 PM
Lehigh Acres, Florida
rickstershemi Offline
PPG BASE / CLEAR .....
PS: proper prep-work makes all the difference.
Rickster
Re: Paint Samples... [Re: rickstershemi] #897809
01/06/11 10:14 PM
01/06/11 10:14 PM
fresno ca
mikeysmopars Offline
fresno ca
Rickster
PPG's DBU basecoat is the best and easyest system to use but with the EPA you cant get it especially here in California. Now with having to use HVLP Guns and compliant materials were stuck using not so user friendly paints unless you have a nice heated well lit downdraft booth.
I painted my Dart with Dupont Cromax because it was given to me but Hard to get to cover and mettalics you have to realy finnesse while spraying.
Iv'e sprayed a couple cars with Duponts Cromax Water base and I struggled on both cars. Silver is definatly hard with waterborne, all conditions need to be perfect. Dupont's Elete Basecoat is very durrable, Most Big Rig trucks use it from the factory but again you need a good booth for it to come out nice without major cutting and pollishing.
If i had my choice I would use PPG's DBU Basecoat system but you need to check to see if you can get it in your area.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Paint Samples... [Re: mikeysmopars] #897810
01/06/11 10:23 PM
01/06/11 10:23 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
My car was painted with Dupont and worked well, proper prep is the best thing to do.
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: Paint Samples... [Re: mikeysmopars] #897811
01/06/11 10:47 PM
01/06/11 10:47 PM
8secDart Offline
8secDart  Offline
Rickster
I still use DBU everyday.I love it.I've used everthing under the sun.I think the time is coming for me to give it up with all the water bullChit,LOL
Re: Paint Samples... [Re: 8secDart] #897812
01/07/11 12:02 AM
01/07/11 12:02 AM
Rickster
No problem getting it here in sunny floriduh
Rickster
Re: Paint Samples... [Re: Cudahlr] #897813
01/07/11 12:04 AM
01/07/11 12:04 AM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
Wow, that car is sure pretty FYI my wife now wants a purple machine like yours after seeing yours up close this summer Thanks a lot pal.
Re: Paint Samples... [Re: Jeepmon] #897814
01/07/11 12:55 AM
01/07/11 12:55 AM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
i have been in and around the autobody business my whole life, the past ten years i have been working at a major autobody paint supplier, We sell many brands of paint including Dupont. Dupont is good, as 8secdart stated, yes the coverage is not that good, but still a quality paint. What makes paint chip easily is poor surface prep or too thick of a film build. that said, engine comp and jambs should be prepped very well and minimal film build in these areas to insure good resistance to chipping
....BAD A$$ STREET CAR.....
Re: Paint Samples... [Re: n20mstr] #897815
01/07/11 01:11 AM
01/07/11 01:11 AM
8secDart Offline
8secDart  Offline
Tony very well said.I guess that's why your a Rep and I'am a wornout a$$ bodyman,LOL
The new Dupont system is better for coverage but still lacks.I think it's called Premier.
Re: Paint Samples... [Re: Jeepmon] #897816
01/07/11 01:18 AM
01/07/11 01:18 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Don my car is Dupont paint, Hot hues to be exact lots of nice shades IMO. Been on there for almost 6 years now. You have seen it in up close and in person so you decide if it will hold up..
One other thing that we have to deal with here is Compliant materials. Stuff you guys spray in most of the country and even a lot of California is not the same stuff we are allowed to use in the Bay Area. Just something that needs to be kept in mind.
Don wish we could have painted it for you but you know the deal. We did just get a truck done in Dupont a white pearl. Painted it last Saturday and came out great. Now if I can just get the other cars out of the shop before we move
Re: Paint Samples... [Re: 8secDart] #897817
01/07/11 01:30 AM
01/07/11 01:30 AM
ill
dennismopar73 Offline
ill
dupont is very good paint!!
my car is painted with dupont
but martin sen is by far the best paint easiest to use
spray mix
paint paint development is all they do !!
as for dupont , paint and paint development is only
25 % of what they do
but dupont is good paint, will not denie
Re: Paint Samples... [Re: dennismopar73] #897818
01/07/11 01:58 AM
01/07/11 01:58 AM
8secDart Offline
8secDart  Offline
spray mix
Man I hope you don't paint for a living.If so you are going around your elbow to get your A$$.Martin sir may be the chit for barns and things but it has no place on a car!!!!!!
Re: Paint Samples... [Re: Jeepmon] #897819
01/07/11 03:38 AM
01/07/11 03:38 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks everyone.. I'm glad to hear Dupont is a decent brand of paint...
I'll be dropping off the car Saturday morning.. and the only problem I have is picking which color... Sheesh, I've seen soooo many nice paint jobs that I want to copy.. but then I want to be unique too... I think I'm going
