Re: piston out of deck????'s
[Re: rice2muscle]
#897136
01/05/11 09:29 PM
01/05/11 09:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You need to check the piston to head clearance... I had a engine that was .030 out and at 8000 the piston would JUST touch in one small area so I ground that area on the head on a freshen up
[Re: rice2muscle]
#897137
01/05/11 09:35 PM
01/05/11 09:35 PM
Posts: 2,091 Delray beach, Florida
Performance Only
there's different ways to look at it. they do make head saver shims for that so you can maintain the proper piston placement. if it's a stock rebuild daily driver deal, that's a good option. if your doing other mods as well, then that's a whole different scenario.
machine shop owner and engine builder
[Re: rice2muscle]
#897140
01/05/11 10:11 PM
01/05/11 10:11 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
If you are running a closed chamber head you could get a cometic gasket .055 thick and get a nice tight quench area, even fel pro sells a head gaset that thick in there kits for small blocks at least.
[Re: rice2muscle]
#897141
01/05/11 10:14 PM
01/05/11 10:14 PM
MR_P_BODY
another quick question, not tyring to start a debate war here just wondering... will i make more power if i were to just get more compression? or if i were to stroke it but have lower compression?
Stroking it gets you more CI and that wins
[Re: HotRodDave]
#897142
01/05/11 10:16 PM
01/05/11 10:16 PM
HotRodDave
Kalispell Mt.
depends on how much compression and displacement we are talking about.
[Re: HotRodDave]
#897143
01/05/11 10:33 PM
01/05/11 10:33 PM
Posts: 4,101 Yes
sixpakdodge
Yes
I ran a .055 over 440 with the piston .013 out of the hole. It loved head gaskets. It burned through a set of the .055 Cometic's right near the dowel pin, just like it did to the 1009 Fel Pro's I originally had on it. I had a set of .066 Cometic's on it when the block split due to fatigue. (Block had A LOT of runs on it.) I kept going thicker in attempt to lower the compression. It didn't make much of a difference though, the car ran the same. I was running 452 open chamber heads that were milled, but still open chambered, with flat top pistons. Definitely check, double check, triple check, and then check again, the piston to valve/head clearance. I didn't have any problems with the piston to valve or piston to head, but it's very crucial.
[Re: hemigod426]
#897145
01/06/11 09:24 AM
01/06/11 09:24 AM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
not going to blow head gaskets like the first machine shop says??
What SOME of these so-called "professionals" say is flat-out SCAREY sometimes.
[Re: dOOc]
#897146
01/06/11 12:07 PM
01/06/11 12:07 PM
Posts: 4,209 New York
polyspheric
New York
True, dat. Remember: "I do it for money" is what makes you a professional - not being good at it. Look at Congress...
Boffin Emeritus
[Re: StripeHOG]
#897150
01/06/11 07:40 PM
01/06/11 07:40 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
what kind of engine? What kind of pistons, and heads? The machine shop you speak of, doesnt give trust worthy answers, my guess is there machine work isnt trust worthy either. Talking about a .020 positive piston to deck clearance then referring to piston to valve questions is a bit confusing. This needs checked also, but piston to head is more critical in this much positive piston height than valve to piston.... Both need checked at any rate. Is this a pump gas engine, or suppose to be? I haven't seen anyone ask yet, but having that much piston height is going to increase the compression a bunch. Running 11:1+ compression will cost you power, and cause engine damage running today's pump gas. Where a properly tuned 9.5:1 engine with the correct/optimal spark timing will not only make more power, but be more dependable any way you slice it. More isn't always best in a performance engine.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
