Chrysler radio tech help needed #89696
07/17/08 01:43 AM
07/17/08 01:43 AM
md
mopars4ever Offline OP
md
I want to put a factory am fm cd radio back in my 97 ram. There is a aftermarket radio in there now. I noticed while checking ebay that a seller said the radio rdr number must match up. What is the ID RBR? Did they use it on a 97 ram? Mike
Re: Chrysler radio tech help needed [Re: mopars4ever] #89697
07/17/08 11:30 AM
07/17/08 11:30 AM
md
md
btt
Re: Chrysler radio tech help needed [Re: mopars4ever] #89698
07/17/08 11:34 AM
07/17/08 11:34 AM
places
79powerwagon Offline
places
A regular factory radio/stereo (not Infinity or one of those)? Aren't they all the same? I can't believe they'd be number-matching anything as trivial as a radio on the assembly line.
Unless it has something to do with a theft protection?
Re: Chrysler radio tech help needed [Re: 79powerwagon] #89699
07/17/08 12:04 PM
07/17/08 12:04 PM
md
md
I thought so too. Here is the auction. 97 - 01 WRANGLER CHEROKEE RBR RADIO # 4704373AE OEM Item number: 300242031668. Mike
Re: Chrysler radio tech help needed [Re: mopars4ever] #89700
07/17/08 01:26 PM
07/17/08 01:26 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
RBR is the sales code for that certain type of radio.which happens to be a AM/FM w/ CD & EQ.,and yes they did use it in 97.and it should work fine in your truck.get me you VIN# and i'll be able to tell you how the truck was originally equiped...Hope this helps ....Alan.
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: Chrysler radio tech help needed [Re: racerAL] #89701
07/17/08 10:18 PM
07/17/08 10:18 PM
5thAve Offline
5thAve  Offline
Any of those radios should work as long as the tabs for the bolts are in the right spots. I think the only difference is that some have a plug for a remote or steering wheel controls or something and some dont.
