Possible Engine Problems
#89661
07/16/08 11:36 PM
07/16/08 11:36 PM
Posts: 1,032 Ohio
dobie
Ohio
Tonight while driving around town I noticed the temp gauge was the hottest it's ever been, at around 170-180 degrees. Prior to tonight it's never been past 160 degrees. So I finally get home and open up the hood to see if I have a coolant leak or anything. While looking around I noticed I'm getting oil seeping from between the driver side head and block. Not much, and I can't find much else, but I've never found this before. It still seems to run fine. No bad sounds, oil pressure is good at around 80 psi. Anyways, I've been getting on her pretty hard lately with the but not enough that I would've thought I'd harm it. So, is this oil seeping between the head/block normal, or do I have bigger issues waiting to turn up? Thanks.
1968 Plymouth Road Runner
383 4 speed
Re: Possible Engine Problems
[Re: MoparforLife]
#89664
07/17/08 07:44 AM
07/17/08 07:44 AM
I would rather see 180/180 temps than 160 temps. Your engine will be running more effiecently.
160 is TOO LOW an you cause much more wear at 160 because the components havent expanded to their correct dimensions- lots more slop at 160 than 180.
#89665
07/17/08 11:06 AM
07/17/08 11:06 AM
DaytonaTurbo
Manitoba, Canada
One of my shop manuals had a graph showing cylinder bore wear versus temp, and I remember even at 160 there was still a fair amount more wear occuring than at 180. You just want to be at operating temp, not under.
[Re: DaytonaTurbo]
#89666
07/17/08 11:21 AM
07/17/08 11:21 AM
Posts: 1,032 Ohio
dobie
Ohio
Wow. That's great information. Thanks for the replies.
383 4 speed
[Re: dobie]
#89667
07/17/08 04:59 PM
07/17/08 04:59 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I'll add if you used oil on the head bolts to ge tthe right torque, you may have just used a little excess. It takes a while to work itself out. I wouldnt sweat it.
[Re: moper]
#89668
07/17/08 05:49 PM
07/17/08 05:49 PM
Posts: 1,032 Ohio
dobie
Ohio
Well, I bought the motor from an original 60,000 miles 68 Newport. We did nothing to it other than replacing the freeze plugs, oil pan/sump, and timing chain. No leakage then. Also added a 4 bbl setup. Other than that, it was never apart.
383 4 speed
