measuring deck height #896322
01/04/11 09:39 PM
01/04/11 09:39 PM
N. IL
tntmachine Offline OP
N. IL
How do you accurately measure the deck height in a bare B or RB?
Re: measuring deck height [Re: tntmachine] #896323
01/04/11 09:53 PM
01/04/11 09:53 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The piston's relation to the deck of the block or the physical deck height of the block?
Alan Jones
Re: measuring deck height [Re: LA360] #896324
01/04/11 09:54 PM
01/04/11 09:54 PM
N. IL
N. IL
Re: measuring deck height [Re: tntmachine] #896325
01/04/11 09:55 PM
01/04/11 09:55 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
deck to the bearing saddle then add 1/2 of the bearing saddle bore.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: measuring deck height [Re: LA360] #896326
01/04/11 09:57 PM
01/04/11 09:57 PM
Get-X Offline
Get-X  Offline
I normally just hook the top of a main bore with a caliper and measure to the deck. Then add half of the main bore dimension and that gets you close.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: measuring deck height [Re: Get-X] #896327
01/04/11 10:08 PM
01/04/11 10:08 PM
LA360 Offline
LA360  Offline
I believe BHJ make tooling to measure it also
Alan Jones
Re: measuring deck height [Re: LA360] #896328
01/04/11 10:14 PM
01/04/11 10:14 PM
NC
440Jim Offline
440Jim  Offline
NC
You can get close with a large (12") caliper to the main bearing saddle. It will take measurement skill or you could be way off.
But to get the last few thousandths, you need to put a bar in the main bores/bearings and a dial indicator with a 90 degree fixture from the deck down to the bar.
Are you trying to get within 0.010" or within 0.001" ?
Re: measuring deck height [Re: tntmachine] #896329
01/04/11 11:28 PM
01/04/11 11:28 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
One of the hardest physical measurements to make on a block at home, if not impossible to be accurate.
Heck some machine shops cant get that correct either.
Like the others said, you measure off the center of the main bore. You couldn't imagine how easy it would be to be off .008 using calipers and adding 1/2 the bearing I.D.
It be more easy to throw a old crank rod and one piston in the 4 corners and you could have a close measurement.
Then who's to say the crank index or rod length is spot on? Cause there Not.
Re: measuring deck height [Re: Get-X] #896330
01/04/11 11:36 PM
01/04/11 11:36 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
I've done it and gotten real good numbers.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: measuring deck height [Re: tntmachine] #896331
01/04/11 11:48 PM
01/04/11 11:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Take it to a machine shop and have them put the
plates and shaft on it to do it right... if your
ordering pistons
Re: measuring deck height [Re: MR_P_BODY] #896332
01/04/11 11:54 PM
01/04/11 11:54 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
ordering pistons
Re: measuring deck height [Re: tntmachine] #896333
01/05/11 01:01 AM
01/05/11 01:01 AM
tn
robnbird Offline
robnbird  Offline
tn
Call your local performance machine shop. They should be able to do the measurement.
Re: measuring deck height [Re: tntmachine] #896334
01/05/11 01:29 AM
01/05/11 01:29 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I agree with those that say a dial caliper isn't accurate enough. Even in a best case scenario with a lot of care and skill the best you can hope to determine is deck height at the mid line of the bore. It would still be all but impossible to determine if the deck was tilted ie. not exactly 90* to the crank centerline. Also the main bearing bores should be align bored prior to making any measurements. You can't do that at home so you may as well let the machine shop check the decks while it's there.
Re: measuring deck height [Re: dfsmopars] #896335
01/05/11 01:34 AM
01/05/11 01:34 AM
tn
robnbird Offline
robnbird  Offline
tn
I like to set my block down on a good smooth concrete floor and a painted floor will get ye better results. make sure there ain't on gasket material on the bottom of the block where ye oil pan was. Now get ye one of these wooden yard sticks, stick it down through the top of the cylinder, let the stick catch the top of the cylinder and get your buddy to eye ball about where the center of the main crank jurnal should be cut a good notch in the stick where it catches the top of the cylinder. Now your about there take a good tape measure and measure from the bottom of the stick to the cut notch and uh you should get the same results on both sides. glad to help.
Re: measuring deck height [Re: robnbird] #896336
01/07/11 08:09 PM
01/07/11 08:09 PM
N. IL
N. IL
Thanks Rob that's how I do it. I just wanted to validate that I was doing it correctly.
