Re: i need a new oil pan
[Re: Locomotion]
#895780
01/04/11 12:40 AM
01/04/11 12:40 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Dont forget the Mancini Pans, they are from Charlies, and the one I purchased was very nice. Had the trap door, and baffled etc.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#895782
01/04/11 12:50 AM
01/04/11 12:50 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
someday i would love to upgrade to external and use one of those really nice pans.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: thehemikid]
#895787
01/04/11 03:44 AM
01/04/11 03:44 AM
Posts: 30,491 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
it is scraped so thin i dont think it is even weldable.
...Can you show a pic of the scraped pan.
ANYTHING is fixable ...I say beef-it-up with some heavier plate and make a skid-plate so it does not happen again. It HAS to be cheaper than buying a new pan. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: rowin4]
#895788
01/04/11 10:13 AM
01/04/11 10:13 AM
sixpackgut
Charleston
If your scrapin the 7" I don't think I would go with the Source 8" As I have said before , the pan manufacture's need to get with the program and make useful pans for the cars of today with lower ride heights. 6" with kick outs and baffles would work.
the source pan says its only 7 but... http://store.440source.com/Oil-Pan-Fabricated-Aluminum-8-Quart/productinfo/200-1076/
Cab, i think the better way to extend the hemi pan would be to use 2 pans insted of adding a piece in the center. plus my welding skills are not journeyman. if i put a value on my time, it just wouldnt be worth it
[Re: sixpackgut]
#895789
01/04/11 10:37 AM
01/04/11 10:37 AM
Posts: 6,295 U.S.
moparniac
U.S.
Ray i went from the milodon low profile with the kickouts to the source pan now! Same height! As I was told you will have to open up some if the holes to fit ! But for $150 dollars vs the milodon and a lil of my time it's well worth it! The pan is made in USA also! I drilled a hole in the side of mine and put an internal pickup in it! One thing that does suck and I don't understand about the source pan is why they made the drain plug lower than the pan itself!
Mopar Performance
[Re: RV2]
#895793
01/05/11 10:33 PM
01/05/11 10:33 PM
Posts: 4,152 SO. CAL.
70blackfish
SO. CAL.
HI Ray, I have heard good things about KEVKO RACING oil pans, look them up. I think there pan and pick up are about 300.00 milodon is always on back order. ![](/ubbthreads/images/graemlins/beer.gif)
