Page 2 of 3 1 2 3
Re: Let me see your small block motor plates. [Re: Mopar366] #894578
05/26/11 01:31 AM
05/26/11 01:31 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
used mainly in race cars when you cant use a normal mount.
I am truckless..
Re: Let me see your small block motor plates. [Re: 340SHORTY] #894579
05/26/11 01:54 AM
05/26/11 01:54 AM
Mopar366 Offline
Mopar366  Offline
Normal motor mounts or mounts for accesories?
1982 d150 1993 dakota
Re: Let me see your small block motor plates. [Re: Mopar366] #894580
05/26/11 05:49 AM
05/26/11 05:49 AM
Q
Quicktree Offline
Quicktree  Offline
Q
both, and they eliminate some of the stress on the block.
Re: Let me see your small block motor plates. [Re: S/ST 3040] #894581
05/26/11 08:01 PM
05/26/11 08:01 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Mine, from the limited run of BSE plates.
Where are you running the Alternator? Is that just the mopar small block MSD crank trigger? Didnt know you could mount it on the driver side.
BSE is Brian Smith Enterprises. (408strokerdart)
I'm not sure if he still makes them.
I don't run an alternator. The plate is drilled to mount
a STAR vacuum pump and catch can.
I talked to Brian over the winter about doing one of his motor plates but he couldn't get enough guys together to have a run of them made... Maybe if we get 8-10 guys who want one of his he'll make a run of them now. I'll buy one...
Re: Let me see your small block motor plates. [Re: 340_Dart] #894582
05/26/11 08:32 PM
05/26/11 08:32 PM
Out West
408strokerdart Offline
Out West
Yeah....really need a run of about 6 or more to make them affordable. We can customize them also. Most off the shelf plates barely go to the inside of the frame rails on a-bodies. This is what spurred me to make my own since it wanted it to go across the top of the frame and fit correctly. If I get enough interest I would do another run of them.
Re: Let me see your small block motor plates. [Re: 408strokerdart] #894583
05/26/11 09:55 PM
05/26/11 09:55 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Brian, I'll take one to put a SB in an A-body if you do another run. Im not sure what the specifics of my accessories will be yet but Im going to be putting an R block-based SB in my Duster and want a quality motor plate.
Re: Let me see your small block motor plates. [Re: Pat7272] #894584
08/20/11 04:34 PM
08/20/11 04:34 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Can anyone recommend a motor plate that works well on a 9 inch deck R-3 block with a Weber belt drive? The water outlets on the block are a little different.
Thanks!
Bill Lamb
Re: Let me see your small block motor plates. [Re: 340Cuda] #894585
08/20/11 05:11 PM
08/20/11 05:11 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Unless you can find short deck w/p spacers (RARE).........it would be cheaper to make your own engine plate.
Re: Let me see your small block motor plates. [Re: Pat7272] #894586
08/21/11 06:27 PM
08/21/11 06:27 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
put me on the list also,,and i will give u the paticualars of the motor
Re: Let me see your small block motor plates. [Re: fishy340] #894587
08/21/11 08:22 PM
08/21/11 08:22 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
I count 3 of us who would be in for having Brian make another run of his motor plates... Come on guys, anyone else need one????
Re: Let me see your small block motor plates. [Re: 340_Dart] #894588
08/21/11 10:44 PM
08/21/11 10:44 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Bump for a 9.56-9.6" R3 block in a Duster!
Still dont know anything about the engine accesories lol. There will be a vacuum pump and an alternator on it, no power steering. Electric fans and water pump.
Re: Let me see your small block motor plates. [Re: 340Cuda] #894589
08/24/11 02:08 PM
08/24/11 02:08 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Thanks!
Bill Lamb
You mean like this? We can make motor plates for just about anything, including the new HEMI engines.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Let me see your small block motor plates. [Re: nhramark] #894590
08/24/11 02:15 PM
08/24/11 02:15 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
New Hemi.
Re: Let me see your small block motor plates. [Re: nhramark] #894591
08/24/11 02:20 PM
08/24/11 02:20 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Also made this for a member here.... you get the idea.
Re: Let me see your small block motor plates. [Re: nhramark] #894592
08/24/11 09:36 PM
08/24/11 09:36 PM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
Looks nice,I will keep that in mind.
Re: Let me see your small block motor plates. [Re: Hitman340] #894593
08/24/11 09:44 PM
08/24/11 09:44 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Mark, What's a motor plate similar to the one you posted in the dart chassis run cost wise?
Re: Let me see your small block motor plates. [Re: 340_Dart] #894594
08/24/11 09:48 PM
08/24/11 09:48 PM
Pacifica, CA
Devilbrad Offline OP
Pacifica, CA
And Mark, what CSR pump is that? SBM?
Re: Let me see your small block motor plates. [Re: Devilbrad] #894595
08/24/11 11:10 PM
08/24/11 11:10 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
BBC on gen3 hemi plate
Re: Let me see your small block motor plates. [Re: nhramark] #894596
08/25/11 01:42 PM
08/25/11 01:42 PM
MD
ADakotaRTGuy Offline
MD
SBM Dakota with a fixture for an alternator? Probably oddball but would be nice if I could get one. Need a hefty alternator because its ok on a street driven EFI app.
Re: Let me see your small block motor plates. [Re: 340_Dart] #894597
08/25/11 05:54 PM
08/25/11 05:54 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
3/8" plate is $175. The Pentastars (or your initials or whatever) is a few extra bucks. Everything is waterjet cut. Call 314-435-3461 for details.
Page 2 of 3 1 2 3
