painless perf mag efi. if you bought it wwyd?
#89388
07/16/08 10:44 AM
07/16/08 10:44 AM
Andrewh
Changed the title again for more hits. Read the last couple of posts on what I figured out. If you bought the painless kit to run the stock efi on a magnum 360, which would you rather do to get it to work. Okay, while working on the car last night, I realized there might be a problem. Painless put a water temp sensor in this stand pipe. This is for a heater hose and goes to the heater core. Now all the mopars I have ever owned shut the water off completely to the heater core unless you are running heat. Which I do not plan on doing. So if I am thinking this through properly, that will never read acurate coolant temps. Where else can you put this sensor?
Re: mag 5.9 sensor questions and what is this?
[Re: Andrewh]
#89399
07/17/08 11:34 AM
07/17/08 11:34 AM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
Will their sensor pigtail not physically plug in to the Mopar/Magnum temp sensor? They (or you) should check some of the earlier model sensors, as I think some of the connectors changed over the years, particularly between the OBD-I and OBD-II years. I know this is true about the TPS and MAP sensors, or at least that's been my experience hooking all the various parts up to my Frankinjection system on the Valiant.
If nothing else, Painless should supply the sensor ends to work with the Mopar sensors that are native to the engine. I mean, they sell WIRING HARNESSES, they can make this happen. Sensor output should be identical, so I doubt that's going to be an issue. I'm not bashing Painless at all, but let's take a look at the product they're trying to make, the engine it's going to be hooked up to, and the folks that they want to buy it. Use the stock Magnum sensors...
Clair
[Re: Andrewh]
#89406
07/17/08 03:53 PM
07/17/08 03:53 PM
Clair_Davis
Fort Worth, TX
their response was that the analog ranges are different, so they are using the gm ones for the computer.
Interesting. I guess I need to stop out there and get their thoughts on that situation, I was under the impression that the sensor response was the same. Since they're only about 3 mi from my office, and 8 mi from my house. Just need to get away from both for a bit, which seems to be the trouble.
I'll see if I can dig up my info on the sensor ranges, too, since I think I have some documentation on that as well.
Clair
[Re: Clair_Davis]
#89407
07/17/08 04:30 PM
07/17/08 04:30 PM
Posts: 482 Dirty South, MS
mopowered
Dirty South, MS
The CTS sensor response is definitely different between Mopar and GM (see www.msefi.com for the exact response curves of each). My CTS is a GM one (with the single blade connector sticking out) that cost about $0.50 at a local junkyard. It fits in a perfect sized hole in my M1 intake directly under the A/C bracket. I simply bent the blade in the direction of where I needed to plug in the CTS signal wire connector. BTW I fabbed up the harness and computer (MegaSquirt) by hand in a few hours so if this redneck can do it w/junkyard parts then surely someone armed w/the power of "Painless Wiring" can do it...
