Re: Replacing Dot 3 Brake Fluid with Dot 5 [Re: Clair_Davis] #89160
07/16/08 11:38 PM
07/16/08 11:38 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i only warm silicone brake fluid in the sun.
shake up some silicone fluid then pour it into a pan and heat it up. you will be amazed by the amount of air that is released from heating it up that you can't see when it's sitting.
this is why previous posters have spongy brake pedals that will never get firm no matter how much bleeding they do.
perception is 90% of reality
Re: Replacing Dot 3 Brake Fluid with Dot 5 [Re: Clair_Davis] #89161
07/17/08 12:13 AM
07/17/08 12:13 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
obviously, mixing fluids diminishes the benefit the higher-rated fluid.
Clair
but maybe not so obvious, and therefore are trace amounts due to lack of complete flushing enough to degrade the performance of a higher rated fluid if that trace amount is found in the highly heated caliper for instance?
Re: Replacing Dot 3 Brake Fluid with Dot 5 [Re: jcc] #89162
07/17/08 08:27 AM
07/17/08 08:27 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Egg-Zakly. It's not too tough to get a good flush on calipers or wheel cylinders, if you're really interested in getting the 100% full benefit of a DOT5 or 5.1 for example. Just pull them and drain them well. For most folks who want to upgrade to DOT5 for the paint protection factor, it's a lot less of an issue.
Clair
Re: Replacing Dot 3 Brake Fluid with Dot 5 [Re: Mr T2U] #89163
07/17/08 09:22 AM
07/17/08 09:22 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I've got to pull my master cylinder this weekend and will have to re-bleed the system. I will be sure to sit the bottles in the sun to see what happens.
Should the tops be off or does that not matter???
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Replacing Dot 3 Brake Fluid with Dot 5 [Re: CJK440] #89164
07/17/08 11:29 PM
07/17/08 11:29 PM
Mr T2U Offline
Mr T2U  Offline
i leave the top off when i do it. i am not sure if it really matters but i figure top off would be better.
