Re: SAVE ME FROM MY STUPIDITY PLEASE!! [Re: towguy76] #891424
12/29/10 09:59 PM
12/29/10 09:59 PM
Cali
BullT Offline OP
BullT  Offline OP
Cali
thanks for the concern and help, i currently have 3 jackstands and a jack under there
so am i backing this bolt ALL the way out? ive gone 75 quarter turns and the tension doesnt seem relieved at all, just want to be careful not to pull it out and have the whole thing fall on top of me
Re: SAVE ME FROM MY STUPIDITY PLEASE!! [Re: BullT] #891425
12/29/10 10:01 PM
12/29/10 10:01 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You can take it all the way out if you like..(or just unscrew it so the rounded end is flush with the plate it is screwed into)
As long as you have the car properly supported, all that will happen is the lower control arm should become loose and have no more tension holding it down (like it is now)
Re: SAVE ME FROM MY STUPIDITY PLEASE!! [Re: OzHemi] #891426
12/29/10 10:27 PM
12/29/10 10:27 PM
Cali
BullT Offline OP
BullT  Offline OP
Cali
ok we are now good! thanks for all the help guys i am still alive!
so i am guessing now that i have a jackstand safely under the axle i should tighten the adjusting bolt back up to relieve some of the pressure off the frame?
Re: SAVE ME FROM MY STUPIDITY PLEASE!! [Re: BullT] #891427
12/29/10 10:41 PM
12/29/10 10:41 PM
Port St Lucie, Florida
towguy76 Offline
towguy76  Offline
No, leave it how it is. The weight on the frame is fine. When you have the car on a lift thats where they pick it up from. I wouldnt tighten that bolt untill you have the brake backing plates back on, otherwise you wont be able to get them back on. If you are going to have it torn down for a while, you are fine to leave the torsion bars loose untill you are ready to put it all back together.
Rick
Re: SAVE ME FROM MY STUPIDITY PLEASE!! [Re: BullT] #891428
12/30/10 12:50 AM
12/30/10 12:50 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You really need to get a service manual , you have your terms all screwed up and it sounds like you are learning this as you go , you are going to damage or bend something , or worse hurt yourself .
Re: SAVE ME FROM MY STUPIDITY PLEASE!! [Re: JohnRR] #891429
12/30/10 01:53 AM
12/30/10 01:53 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
What you are calling an axle is the lower control arm. Mopar suspensions aren't all that difficult, but you really need to know what oyu are doing before going and unbolting things. Since you have it at this point it would be a good idea to check all of your ball joints and bushings......
Re: SAVE ME FROM MY STUPIDITY PLEASE!! [Re: BullT] #891430
12/30/10 04:25 AM
12/30/10 04:25 AM
rhode island
bomber1965 Offline
bomber1965  Offline
rhode island
ok i think i see what you are saying so if i loosen that bolt i should be able to move the axle back up?
where will all the weight be shifting too?
say force instead of weight......you wont be shifting weight you'll be relieving the force (twist) in the torsion bar.
what you did was unbolt the suspension end, that had this twisting force exerted on it, wanting to come apart violently.
you need to understand the components your trying to disassemble to avoid bad things from happening.
your only born with a set number of fingers and eyeballs.
see the red torsion bar?
that is preloaded (twisted) with that little bolt you were looking for.
then the weight of the whole car bouncing down the road loads and unloads it more.
you have to fully unload the red bar using the little bolt before taking the suspension parts off, or it go BOOM!
Re: SAVE ME FROM MY STUPIDITY PLEASE!! [Re: bomber1965] #891431
12/30/10 04:28 AM
12/30/10 04:28 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Weeeeell........
Re: SAVE ME FROM MY STUPIDITY PLEASE!! [Re: OzHemi] #891432
12/30/10 04:40 AM
12/30/10 04:40 AM
rhode island
bomber1965 Offline
bomber1965  Offline
rhode island
wellll..... I never said it was a standard set,
just try keeping what nature gave ya.....
Re: SAVE ME FROM MY STUPIDITY PLEASE!! [Re: BullT] #891433
12/30/10 11:04 AM
12/30/10 11:04 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Often times a man's life in these parts depends upon a mere scrap of information. In the future, you can get the scraps of information you need to save your life from the internet or the local library. The trick is to get them BEFORE you start a project.
Re: SAVE ME FROM MY STUPIDITY PLEASE!! [Re: jbc426] #891434
12/30/10 11:33 AM
12/30/10 11:33 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
sounds like all the great members here got you lined out.very glad it all worked out for you and you did not get hurt or even worse. one more thing i would add is to remove the shock absor it will help you lift the lower control arm back in place. mopar front ends are pretty straight forward but that tor bar can kill ya, you can see in the first pics from you that the t bar still has tension on it. good luck , please be careful and ask some questions first.
Re: SAVE ME FROM MY STUPIDITY PLEASE!! [Re: BullT] #891435
12/30/10 02:04 PM
12/30/10 02:04 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Please click this link and download the service manual. It's for a Plymouth but it'll work for your Dodge.
http://www.mymopar.com/index.php?pid=109
- Stu Harmon
