Re: SAVE ME FROM MY STUPIDITY PLEASE!!
[Re: BullT]
#891427
12/29/10 10:41 PM
12/29/10 10:41 PM
Posts: 76 Port St Lucie, Florida
towguy76
No, leave it how it is. The weight on the frame is fine. When you have the car on a lift thats where they pick it up from. I wouldnt tighten that bolt untill you have the brake backing plates back on, otherwise you wont be able to get them back on. If you are going to have it torn down for a while, you are fine to leave the torsion bars loose untill you are ready to put it all back together.
Rick
[Re: BullT]
#891428
12/30/10 12:50 AM
12/30/10 12:50 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
ok we are now good! thanks for all the help guys i am still alive!
so i am guessing now that i have a jackstand safely under the axle i should tighten the adjusting bolt back up to relieve some of the pressure off the frame?
You really need to get a service manual , you have your terms all screwed up and it sounds like you are learning this as you go , you are going to damage or bend something , or worse hurt yourself .
[Re: bomber1965]
#891431
12/30/10 04:28 AM
12/30/10 04:28 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
your only born with a set number of fingers and eyeballs. ![](/ubbthreads/images/graemlins/tsk.gif) .
Weeeeell........ ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
![](/ubbthreads/images/graemlins/grin.gif)
![](http://i415.photobucket.com/albums/pp237/ozhemi/3eyes.png)
[Re: BullT]
#891433
12/30/10 11:04 AM
12/30/10 11:04 AM
Posts: 3,288 West Coast, USA
jbc426
West Coast, USA
Often times a man's life in these parts depends upon a mere scrap of information. In the future, you can get the scraps of information you need to save your life from the internet or the local library. The trick is to get them BEFORE you start a project.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: BullT]
#891435
12/30/10 02:04 PM
12/30/10 02:04 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Please click this link and download the service manual. It's for a Plymouth but it'll work for your Dodge. http://www.mymopar.com/index.php?pid=109
