Re: 1970 440 motor with rpm @ idle that wont remain same
[Re: mopar0723]
#890888
12/29/10 12:02 AM
12/29/10 12:02 AM
RapidRobert
Is it possible that the throttle blades are hanging up just a very slight bit, not enough to be visually seen at the throttle stop position but enough to make the change in speed you are seeing? I'd measure the EXACT distance between a point on the throttle linkage and a fixed point on the carb body to confirm/elim. Your positive nothing is hanging up the throttle (choke/fast idle etc) are all off/not interfering in any way
[Re: RapidRobert]
#890889
12/29/10 12:06 AM
12/29/10 12:06 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Are you running a MP electronic ignition??
[Re: mopar0723]
#890895
12/29/10 12:41 AM
12/29/10 12:41 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Vacuum leak could cause it but before getting to involved in looking for that throw a timing light at it....
[Re: mopar0723]
#890896
12/29/10 12:42 AM
12/29/10 12:42 AM
Posts: 5,447 So Cal
Sinitro
So Cal
Is the vacuum advance connected?? If yes, you may want to try disconnecting/plugging and see what happens... Just my $0.02..
[Re: mopar0723]
#890900
12/29/10 02:38 PM
12/29/10 02:38 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
Every sixpack I have tuned leaves my house running better than when it arrived. I would try adjusting the front & rear carbs. There are adjustment screws in the front of the base plates. May have to pull out the lead plugs if original. I made a long thin screw driver type tool out of a piece of coat hanger & flatened the end like a screwdriver so I don't have to remove any of the three carbs to tune. This was the cure for mine.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
