Page 2 of 4 1 2 3 4
Re: 69 RR off to the media blasters (pics inside) [Re: Dave Watt] #890835
12/31/10 11:56 AM
12/31/10 11:56 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Is it a low VIN - SO?
Re: 69 RR off to the media blasters (pics inside) [Re: FJ5_Fish] #890836
12/31/10 12:03 PM
12/31/10 12:03 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Pretty low VIN# and SO number. One of the first 20 built.
Re: 69 RR off to the media blasters (pics inside) [Re: Dave Watt] #890837
12/31/10 12:15 PM
12/31/10 12:15 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Hmmm - There may be something to the proving grounds or magazine angle after all...
Re: 69 RR off to the media blasters (pics inside) [Re: AZ_A12_BEE] #890838
01/01/11 03:37 AM
01/01/11 03:37 AM
California
BigDaddy440 Offline OP
California
Are you removing the cage?
Yes
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 RR off to the media blasters (pics inside) [Re: FJ5_Fish] #890839
01/01/11 03:44 AM
01/01/11 03:44 AM
California
California
Not sure about a magazine article, or anything else really and I'm certainly not claiming it has any special importance other than being an A12 car. I'm interested in why it was supposedly at the proving grounds at one point.
Yes the car is one of the first 20 built. Dave Watt has been so very kind in assisting me with his knowledge of A12 cars.
I'll post more pics when I have them.
Thanks!
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 RR off to the media blasters (pics inside) [Re: BigDaddy440] #890840
01/01/11 12:20 PM
01/01/11 12:20 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Thanks!
-Dan
Did it go to Canada like most of the first ones did?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 69 RR off to the media blasters (pics inside) [Re: AZ_A12_BEE] #890841
01/01/11 04:43 PM
01/01/11 04:43 PM
California
California
I don't think so...
It was purchased in Ohio and as far as I know spent its time between Ohio and Indiana...but the information I have at this point is limited.
-dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 RR off to the media blasters (pics inside) [Re: BigDaddy440] #890842
01/01/11 08:50 PM
01/01/11 08:50 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
Re: 69 RR off to the media blasters (pics inside) [Re: BigDaddy440] #890843
01/07/11 01:35 AM
01/07/11 01:35 AM
California
California
The blasting job is finished. I requested that the thinnest sheet metal remain painted. I mainly wanted to expose problem areas and areas that are a pain to use a DA sander on. Also my body & paint man was afraid that an inexperienced blaster operator might damage the thinner sheet metal areas.
This car is nearly rust free, it's quite amazing. But given it's history (not driven much) it makes sense. The last picture shows the biggest rust damaged area on the car. There's a couple other areas, but they're even smaller than this.
Being that the car was a race car there were several little modifications that are plain to see. First you'll notice all the gold colored brazing on the underside of the car. When I fist noticed this (months ago) I thought there were some possible panel replacements, but I don't think so. After seeing the other small modifications that were completed to stiffen the car, it became apparent that at some point all the body seems has been tacked up in an effort to strengthen up the car. Also there are no indications that any of sheet metal / floors had ever been removed. If you look near the rear seat area inside the car, you'll see a reinforcement modification that was completed...effective? not sure. I'm also not sure if it will interfere with the factory rear seat...looks like it might. There are a few other interesting modifications that I'll need to reverse, roll cage etc, but for the most part it's an incredibly solid car.
pics:
My plan is currently to have all the metal work completed on the car and have the engine bay, underside, door jams, and trunk painted factory Plymouth Ralley Green. Then take the car back home and install brake lines, fuel lines, gas tank, and install the new / rebuilt front and rear suspension. Once its a roller again, then it will go back to the shop for the final body work and paint job. Any thoughts about my plans? Suggestions are appreciated.
-dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 RR off to the media blasters (pics inside) [Re: BigDaddy440] #890844
01/07/11 02:46 AM
01/07/11 02:46 AM
pics:
-dan
Do yourself and paint the whole car at the same time. Its not worth mismatched jambs, engine bay, overspray on the suspension and all the other headaches associated with painting a roller. Trust me.
Re: 69 RR off to the media blasters (pics inside) [Re: ] #890845
01/07/11 08:54 AM
01/07/11 08:54 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Your plan is the worst restoration plan I've ever heard.
CHECK OUT MY NEW WEB SITE !
Re: 69 RR off to the media blasters (pics inside) [Re: anlauto] #890846
01/07/11 10:14 AM
01/07/11 10:14 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I gotta agree here, all paint and body work must be completed then assemble car.
Re: 69 RR off to the media blasters (pics inside) [Re: anlauto] #890847
01/07/11 02:41 PM
01/07/11 02:41 PM
California
California
I'm certainly open to suggestions, but I don't know why people have to make unhelpful / nonconstructive comments. 1969Hemi actually game me a reason as to why he thought painting the entire car all at once was a better idea, and I can appreciate that.
I see why having everything painted at once makes good sense. My reasoning for wanting the car painted into two stages was to allow me a chance to work on the undercarriage, engine bay, and Dash re-installation while saving funds for a three or four months for the main paint job. Working on these areas without fear of damaging the fresh paint on the rest of the car I though would be helpful.
I'll certainly reconsider my plans and speak with my paint and body guy. I'm still in the beginning stages of ironing out the body work details with him. This is the first time I've torn a car this far down for a resto and so I'm all ears for suggestions....which is a huge reason I'm on a site like Moparts to begin with.
That said...Putting a "two-cents" icon after a rude comment doesn't make it any less rude. There's no question Allen that you have gobs more experience than me when it comes to auto restoration, so why not actually share some helpful advice? I doubt you'd make that comment in person and then walk away without sharing anything further. Right?
-dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 RR off to the media blasters (pics inside) [Re: BigDaddy440] #890848
01/07/11 03:04 PM
01/07/11 03:04 PM
Wattsburg, Pa
Dr V Offline
Dr V  Offline
Wattsburg, Pa
Dan, you have to be a lot more careful during assembly if you paint everything separate. But the final job looks sooo much better. U can paint the car whole but you will not get in the cracks and edges of the panels without running the s$!t out of the paint. I have done it both ways. The progress looks good so far. Eric
69 1/2 A12 BEE 4 spd
1968 Charger 383
1970 Roadrunner 440+6 Survivor
2019 Redeye
2005 FORD GT Red/White
2017 Viper ACR Extreme Red/White
1979 Branco Red/Red
2018 Porsche GT3 Miami
1971 440+6 Cuda 4 speed V2
2020 Sebring Orange Vette
1979 Chevy Boogie Hippie Van
Re: 69 RR off to the media blasters (pics inside) [Re: BigDaddy440] #890849
01/07/11 03:57 PM
01/07/11 03:57 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Looks good so far. When I did my car, I had the completed shell painted then assembled it. You definetly need to be carefull on completely painted car. But that method is what the plant did when the car was originally built. If you buy all the paint at once and do the underside, engine bay and jambs, you could probably leave the outside final paint work until the drive train is installed and the interior is complete. Make sure you are tapping off the right things before the final spray.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 69 RR off to the media blasters (pics inside) [Re: AZ_A12_BEE] #890850
01/07/11 04:45 PM
01/07/11 04:45 PM
anlauto Offline
anlauto  Offline
Dan
I certainly apologize for coming off rude with my comment. Please check the date stamp, it was quite early and I only had a very short time to comment before getting my kids out of bed and starting our day...
Ok first off...Your time is just as valuable as your money. The first thing to remember when doing a restoration is that you don't want to do things twice.
I can guarantee you that no matter who the painter is or how good they think they can mask a car, you're going to get sanding dust, primer over spray, paint over spray and all other kinds of crap on your nice new clean fresh parts that you've already mounted. You're going to spend more time and effort RE-DETAILING all your components.
Second of all..."Spring Green" is a metallic colour and the car should be all painted together as mentioned.
Also the engine/transmission should be installed from the bottom, meaning that if you've gone ahead and installed the K Frame already, you'll have to remove it again..
And if it's a "money thing" like you have to save up for the final paint, then you're better off concentrating all your financial efforts in one direction at a time. For instance, hold off doing the suspension and drive train until the paint is 100% complete. Then as you can afford other components you can get them done and install them right away.
For example...picture having a complete painted shell in your garage and nothing else prepared....You can get the heater box and pedals done - install them, you can get the dash, steering column done - install them, etc...etc...
instead if you get those things done first, they just sit around collecting dust waiting for a car that may never get painted...
Sorry about this morning...
Re: 69 RR off to the media blasters (pics inside) [Re: anlauto] #890851
01/07/11 06:00 PM
01/07/11 06:00 PM
California
California
Dan
I certainly apologize for coming off rude with my comment...
I appreciate that Allen. I also appreciate the information you provided above, it makes sense, and I'll be taking all of this into consideration. As you know this is a huge undertaking and being that I've never had a car torn down to this extent, I'm still learning.
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 69 RR off to the media blasters (pics inside) [Re: BigDaddy440] #890852
01/07/11 08:52 PM
01/07/11 08:52 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
That car is probably one of the very few I have seen that has been blasted properly IMO. The sheetmetal is clean and there is no surface rust or "not so good" blasted areas on the hard to reach spots. I usually see cars back from the blaster here at moparts and they always look like a partially done job and then they prime over the "light flash rust". This one has been blasted real good with attention on gettong to all the nooks and crannies. Good job. Also, your bodyman knows what he says when he told you to keep them off the exterior sheetmetal. Blasting warps. Period. Even if somebody tells me they can blast without warping I say "no thanks" I wont risk warping nice original sheetmetal. Id rather spend some time sanding than trying to fix wavy panels afterwards and having to use bondo (noooo!!!noo! nooooo!!!!).
On painting the car separate....dont do that. Do it all at the same time and then assemble.
Also being a metallic paint car, dont paint doors and fenders separate. Paint em bolted on the car to assure that the flake is nice and even. Thats the way Ma Mopar did them. Also, you dont risk chipping anything afterwards----again metallic would be a [Edited by Moparts - Family Friendly Site - Keep it clean] to match if something bad happens!! And you are bound to have that happen when trying to mount those big fenders and doors on when they are all nice and painted.
Re: 69 RR off to the media blasters (pics inside) [Re: BigDaddy440] #890853
01/07/11 09:07 PM
01/07/11 09:07 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Dan, the car looks great. That thing is really solid.
I have to agree with some of the guys suggesting to paint the complete car before bringing it home. Otherwise you will end up with overspray and dust in areas you didn't think possible if you take it back to the bodyshop to finish the outside. I know it would be nice to spread the expense over a longer period of time, but you'll be much happier with the results this way.
Re: 69 RR off to the media blasters (pics inside) [Re: BigDaddy440] #890854
01/07/11 10:14 PM
01/07/11 10:14 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Hey the car looks... bare, really bare. That's what freaks me out, you got to get it some kind of primer like fast and you don't have plan in place yet?
I would have done the outside with plastic while I was doing the bottem. And then you could get the whole thing in primer all at once. Rust never sleeps, nowhere.
Good luck with it, I hope you don't leave it bare long.
Page 2 of 4 1 2 3 4
