Page 2 of 5 1 2 3 4 5
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890678
12/28/10 11:01 PM
12/28/10 11:01 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Bill, it's time for one of Andy's 3/8" motor plates
I would need another pair of pump gaskets then
no gaskets if you use a motor plate
ultra grey silicon only
vibration will kill the gaskets and will leak
1.39 9.85 - 137 mph
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890679
12/28/10 11:09 PM
12/28/10 11:09 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Would this be the right one?
http://www.summitracing.com/parts/EAR-949012ERL/
Is the dimensions they list for "fitting size 2" the same as a -12?
12an is the correct size for the braided line. Not sure what size the other fitting needs to be. Maybe call Milodon and see what they say ?
Dwayne would know for sure
Ron
Re: Well, I tried to put my motor in today [Re: Eric] #890680
12/28/10 11:32 PM
12/28/10 11:32 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Bill...why not just make a motor plate?...
that thing needs a motor plate anyway I think.
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890681
12/28/10 11:37 PM
12/28/10 11:37 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
I've posted these before, Bill but here's how I got around this problem. The steel line is two 90 degree Aeroquip parts that I cut and rewelded into the "U" bend.
Re: Well, I tried to put my motor in today [Re: PC-CHARGER] #890682
12/28/10 11:38 PM
12/28/10 11:38 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
2
Re: Well, I tried to put my motor in today [Re: PC-CHARGER] #890683
12/28/10 11:39 PM
12/28/10 11:39 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
3
Re: Well, I tried to put my motor in today [Re: Ari440] #890684
12/28/10 11:42 PM
12/28/10 11:42 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
AND?
vibration will kill Inferior gaskets and will leak
Fixed it for ya Ari
Motor Plate, Motor Plate, Motor Plate,
Re: Well, I tried to put my motor in today [Re: roadhazard] #890685
12/28/10 11:48 PM
12/28/10 11:48 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
AND?
Fixed it for ya Ari
THANKS
1.39 9.85 - 137 mph
Re: Well, I tried to put my motor in today [Re: PC-CHARGER] #890686
12/28/10 11:51 PM
12/28/10 11:51 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I had the same problem and found this fitting on e-bay. Earls #849012 90deg. 12AN o-ring to 12AN swivel -seal to hose end $24.95 { at buy it now price } E-BAY # 150274214939 The 12 AN o-ring end screws into the pump , the other end , the hose is put on the fitting so it eliminates the extra fitting. Both ends swivel.
Re: Well, I tried to put my motor in today [Re: Ari440] #890687
12/28/10 11:54 PM
12/28/10 11:54 PM
ill
dennismopar73 Offline
ill
bill for what it worth
i really like the 90 to 90 degree option
just not a 'plate ' fan at all
i have seen the alumim 'charge' forward under de ecelleration top end start seeing tranny pony tails break j m o
Re: Well, I tried to put my motor in today [Re: rowin4] #890688
12/29/10 12:08 AM
12/29/10 12:08 AM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
http://www.summitracing.com/parts/EAR-849012ERL/?rtype=1
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890689
12/29/10 12:42 AM
12/29/10 12:42 AM
rowin4 Offline
rowin4  Offline
Do you think some one at Summit is dyslexic ? got the Earl's e-bay price of $24.95 and put down $42.95
Re: Well, I tried to put my motor in today [Re: rowin4] #890690
12/29/10 01:01 AM
12/29/10 01:01 AM
BROOK PARK, OH
BROOK PARK, OH
The E bag listing has the same 42.95
http://cgi.ebay.com/ebaymotors/Earls-Per...sQ5fAccessories
That's why I posted it so you could verify if it was the same one you used or I looked it up wrong
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890691
12/29/10 01:10 AM
12/29/10 01:10 AM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Yes, that is just the OD for -12 male threads. Both share the same 3/4-16 thread. SAE O-ring boss and JIC (AN) have the same thread pitch.
You can go the industrial fitting route and spend less than $5.00
6801-12-12-FG or 12-C5OX
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890692
12/29/10 01:22 AM
12/29/10 01:22 AM
rowin4 Offline
rowin4  Offline
[/quote
I just punched in the # 150274214939 It's $24.95 plus $4.90 expedited shipping. I thought for a minute I was seeing things different.
Re: Well, I tried to put my motor in today [Re: rowin4] #890693
12/29/10 01:25 AM
12/29/10 01:25 AM
BROOK PARK, OH
BROOK PARK, OH
Now I get it,
Ad # 150274214939 is from a different seller. Not Summit Racing Equip.
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890694
12/29/10 01:35 AM
12/29/10 01:35 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Now I get it,
Its about time
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890695
12/29/10 01:36 AM
12/29/10 01:36 AM
rowin4 Offline
rowin4  Offline
Now I get it,
Yup! Same part, same manufacture,
Re: Well, I tried to put my motor in today [Re: rowin4] #890696
12/29/10 01:37 AM
12/29/10 01:37 AM
Colorado Springs, Colorado
Dartthunder340 Offline
I wonder if you could just cut a hole where your red circle was in the picture, then put whatever diameter pipe to run the oil line through the area and weld around it all, I don't know if that would be more of a hassle or if I even explained it enough to understand. Just trying to offer a suggestion.
Better get inside Ma. Looks like a storm's comin'.
Re: Well, I tried to put my motor in today [Re: Dartthunder340] #890697
12/29/10 01:43 AM
12/29/10 01:43 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
