Re: Well, I tried to put my motor in today
[Re: Eric]
#890680
12/28/10 11:32 PM
12/28/10 11:32 PM
Quicktree
Bill...why not just make a motor plate?...
that thing needs a motor plate anyway I think.
[Re: Ari440]
#890684
12/28/10 11:42 PM
12/28/10 11:42 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Bill, it's time for one of Andy's 3/8" motor plates ![](/ubbthreads/images/graemlins/hammer.gif)
I would need another pair of pump gaskets then ![](/ubbthreads/images/graemlins/runaway.gif)
AND? ![](/ubbthreads/images/graemlins/coffeetime.gif)
no gaskets if you use a motor plate
ultra grey silicon only
vibration will kill Inferior gaskets and will leak
Fixed it for ya Ari ![](/ubbthreads/images/graemlins/biggrin.gif)
Motor Plate, Motor Plate, Motor Plate, ![](/ubbthreads/images/graemlins/punkrocka.gif)
[Re: PC-CHARGER]
#890686
12/28/10 11:51 PM
12/28/10 11:51 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I had the same problem and found this fitting on e-bay. Earls #849012 90deg. 12AN o-ring to 12AN swivel -seal to hose end $24.95 { at buy it now price } E-BAY # 150274214939 The 12 AN o-ring end screws into the pump , the other end , the hose is put on the fitting so it eliminates the extra fitting. Both ends swivel. ![](/ubbthreads/images/graemlins/wrench.gif)
[Re: Ari440]
#890687
12/28/10 11:54 PM
12/28/10 11:54 PM
Posts: 2,177 ill
dennismopar73
ill
bill for what it worth i really like the 90 to 90 degree option just not a 'plate ' fan at all i have seen the alumim 'charge' forward under de ecelleration top end start seeing tranny pony tails break j m o ![](/ubbthreads/images/graemlins/popcrn.gif)
[Re: rowin4]
#890688
12/29/10 12:08 AM
12/29/10 12:08 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
http://www.summitracing.com/parts/EAR-849012ERL/?rtype=1 ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: WILD BILL]
#890689
12/29/10 12:42 AM
12/29/10 12:42 AM
rowin4
Do you think some one at Summit is dyslexic ? got the Earl's e-bay price of $24.95 and put down $42.95 ![](/ubbthreads/images/graemlins/down.gif)
[Re: rowin4]
#890690
12/29/10 01:01 AM
12/29/10 01:01 AM
WILD BILL
BROOK PARK, OH
The E bag listing has the same 42.95 ![](/ubbthreads/images/graemlins/shruggy.gif)
http://cgi.ebay.com/ebaymotors/Earls-Per...sQ5fAccessories
That's why I posted it so you could verify if it was the same one you used or I looked it up wrong
[Re: WILD BILL]
#890691
12/29/10 01:10 AM
12/29/10 01:10 AM
Posts: 202 TN Hoosier
jb500
TN Hoosier
Would this be the right one?
http://www.summitracing.com/parts/EAR-949012ERL/
Is the dimensions they list for "fitting size 2" the same as a -12?
Yes, that is just the OD for -12 male threads. Both share the same 3/4-16 thread. SAE O-ring boss and JIC (AN) have the same thread pitch.
You can go the industrial fitting route and spend less than $5.00 6801-12-12-FG or 12-C5OX
[Re: WILD BILL]
#890694
12/29/10 01:35 AM
12/29/10 01:35 AM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
Now I get it,
Ad # 150274214939 is from a different seller. Not Summit Racing Equip.
Its about time ![](/ubbthreads/images/graemlins/grin.gif)
![](/ubbthreads/images/graemlins/apimp.gif)
[Re: WILD BILL]
#890695
12/29/10 01:36 AM
12/29/10 01:36 AM
rowin4
Now I get it,
Yup! Same part, same manufacture,
[Re: rowin4]
#890696
12/29/10 01:37 AM
12/29/10 01:37 AM
Posts: 311 Colorado Springs, Colorado
Dartthunder340
I wonder if you could just cut a hole where your red circle was in the picture, then put whatever diameter pipe to run the oil line through the area and weld around it all, I don't know if that would be more of a hassle or if I even explained it enough to understand. Just trying to offer a suggestion.
Better get inside Ma. Looks like a storm's comin'.
