Re: mopar 590 cam.; what CR do i need to go with it? [Re: 440Jim] #889850
12/28/10 01:07 PM
12/28/10 01:07 PM
UK
602heavy Offline
602heavy  Offline
UK
Me , i'd go with the Ultradyne.............the earlier that 590 is installed the less top end #s that motor is gonna see , why install on a 100 CL? , surely this is telling you the cam is too big for the motor , installing that cam too early will be fine for the 'seat of the pants' feel , with the comp ratio you're running that 590 will be a dog , much better grinds out there for you're application.
Re: mopar 590 cam.; what CR do i need to go with it? [Re: 602heavy] #889851
12/28/10 01:32 PM
12/28/10 01:32 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
i hear yall.. maybe i can get with clovis here on that 250 cam or do the 557. i need to stay as low buck as possible! lol thanks for all the input!
74 dart sport 440 www.Csucarbs.com
Re: mopar 590 cam.; what CR do i need to go with it? [Re: shoebox] #889852
12/28/10 02:45 PM
12/28/10 02:45 PM
organ
maximum entropy Offline
organ
the narrow lsa cams don't need that much compression. the next cam i'm going to try in my mule (10.33:1) is going to be the 590. it will be fine. how do you think the superstock boys run with 10:1 and 290 @ .050? narrow lsa, and a little advanced. i'll probably try it at 102 or so. stay tuned.
Re: mopar 590 cam.; what CR do i need to go with it? [Re: maximum entropy] #889853
12/28/10 02:56 PM
12/28/10 02:56 PM
UK
602heavy Offline
602heavy  Offline
UK
the narrow lsa cams don't need that much compression. :
That maybe true to a point , but what you gotta realise is the more that cam is advanced the earlier exhaust valve is opened , not a good call with long duration low comp motors. .............the Ultradyne will make more power across the board than that 590 , will idle a bunch nicer too.
Re: mopar 590 cam.; what CR do i need to go with it? [Re: 602heavy] #889854
12/28/10 03:34 PM
12/28/10 03:34 PM
organ
organ
i have a problem with that...
Re: mopar 590 cam.; what CR do i need to go with it? [Re: maximum entropy] #889855
12/28/10 03:37 PM
12/28/10 03:37 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
i want the radical idle! lol the UD will sound good though
Re: mopar 590 cam.; what CR do i need to go with it? [Re: maximum entropy] #889856
12/28/10 03:46 PM
12/28/10 03:46 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Apples vs. Bananas.... A Super Stock builder couldn't care less how the motor will run at anything other than 5k-7k, and their entire combo is built around that RPM range.
Re: mopar 590 cam.; what CR do i need to go with it? [Re: shoebox] #889857
12/28/10 03:52 PM
12/28/10 03:52 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
FWIW, three cams I've used w/ different 440 combinations over the years. Every one of these cams is smaller than an MP .590" (271 @ .050", 106 LSA).
1. 9.8 CR, ported OEM heads, 3200-stall: 246/246 @.050", .560", 110 LSA ==> 11.7 @ 118 MPH
2. 9.8 CR, ported OEM heads, 4500-stall: 254/254 @.050", .554", 108 LSA ==> 11.0 @ 122 MPH
3. 10.8 CR, MP Stage VI heads, 4500-stall: 266/266 @ .050", .600", 108 LSA ==> 10.5 @ 126 MPH
The car used 4.10s, ran w/ a full exhaust system the whole time, and weighed 3650++ lbs w/ driver.
Re: mopar 590 cam.; what CR do i need to go with it? [Re: maximum entropy] #889858
12/28/10 04:23 PM
12/28/10 04:23 PM
UK
602heavy Offline
602heavy  Offline
UK
Maybe you did'nt , but the OP might. .........well , if he ain't gonna run that 590 on the street then all is good right?
Re: mopar 590 cam.; what CR do i need to go with it? [Re: StealthWedge67] #889859
12/28/10 04:30 PM
12/28/10 04:30 PM
Get-X Offline
Get-X  Offline
5-7k? More like 7500-9400
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: mopar 590 cam.; what CR do i need to go with it? [Re: 602heavy] #889860
12/28/10 04:38 PM
12/28/10 04:38 PM
organ
organ
op mentioned he's good with wholesome radicalness, fwiw.
Re: mopar 590 cam.; what CR do i need to go with it? [Re: BradH] #889861
12/28/10 04:40 PM
12/28/10 04:40 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
It's obvious you just want people to tell you it's OK to run the .590, regardless of whether it's the right cam or not.
It's not.
Boy, isn't that the truth! This guy had his mind all made up & it didn't matter what anyone say..........and then he consistently whips out the "Cheap" word as well. Give it time, he'll be back posting "why is my car a dog??" But, hey it'll have a wicked idle.
Re: mopar 590 cam.; what CR do i need to go with it? [Re: STEFF] #889862
12/28/10 04:45 PM
12/28/10 04:45 PM
UK
602heavy Offline
602heavy  Offline
UK
' he'll be back posting "why is my car a dog??" But, hey it's got a wicked idle.
Re: mopar 590 cam.; what CR do i need to go with it? [Re: 602heavy] #889863
12/29/10 12:28 AM
12/29/10 12:28 AM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
What about the UD 290/.597 cam? 263@.050 and 108CL.
That is what Tim at Bullet recommended for my stock stroke combo: 10.5,RPM heads, Dynamic 9.5, and 4.10. Runs great on the street and has a mean ex lope.
My best so far is 11.58@115 3800lbs Coronet. May be more in it if I knew what I was doing(not much track time....yet).
Re: mopar 590 cam.; what CR do i need to go with it? [Re: jb500] #889864
12/29/10 12:31 AM
12/29/10 12:31 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
tim recommended the 251 for my car. super nice guy.. thanks for the replies fellas
Re: mopar 590 cam.; what CR do i need to go with it? [Re: shoebox] #889865
12/29/10 01:13 AM
12/29/10 01:13 AM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
The best mopar cam for the right combination ever is the old mini express. I wish they still made that
