Re: mopar 590 cam.; what CR do i need to go with it?
[Re: 602heavy]
#889851
12/28/10 01:32 PM
12/28/10 01:32 PM
Posts: 808 mckinney texas
shoebox
mckinney texas
i hear yall.. maybe i can get with clovis here on that 250 cam or do the 557. i need to stay as low buck as possible! lol thanks for all the input!
[Re: maximum entropy]
#889853
12/28/10 02:56 PM
12/28/10 02:56 PM
Posts: 1,200 UK
602heavy
UK
the narrow lsa cams don't need that much compression. :
That maybe true to a point , but what you gotta realise is the more that cam is advanced the earlier exhaust valve is opened , not a good call with long duration low comp motors. .............the Ultradyne will make more power across the board than that 590 , will idle a bunch nicer too. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: shoebox]
#889857
12/28/10 03:52 PM
12/28/10 03:52 PM
BradH
FWIW, three cams I've used w/ different 440 combinations over the years. Every one of these cams is smaller than an MP .590" (271 @ .050", 106 LSA). ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) 1. 9.8 CR, ported OEM heads, 3200-stall: 246/246 @.050", .560", 110 LSA ==> 11.7 @ 118 MPH 2. 9.8 CR, ported OEM heads, 4500-stall: 254/254 @.050", .554", 108 LSA ==> 11.0 @ 122 MPH 3. 10.8 CR, MP Stage VI heads, 4500-stall: 266/266 @ .050", .600", 108 LSA ==> 10.5 @ 126 MPH The car used 4.10s, ran w/ a full exhaust system the whole time, and weighed 3650++ lbs w/ driver.
#889858
12/28/10 04:23 PM
12/28/10 04:23 PM
Posts: 1,200 UK
602heavy
UK
i have a problem with that...
![](/ubbthreads/images/graemlins/biggrin.gif)
Maybe you did'nt , but the OP might. .........well , if he ain't gonna run that 590 on the street then all is good right?
[Re: BradH]
#889861
12/28/10 04:40 PM
12/28/10 04:40 PM
Posts: 3,877 Smyrna, South Carolina
STEFF
It's obvious you just want people to tell you it's OK to run the .590, regardless of whether it's the right cam or not.
It's not.
Boy, isn't that the truth! This guy had his mind all made up & it didn't matter what anyone say..........and then he consistently whips out the "Cheap" word as well. Give it time, he'll be back posting "why is my car a dog??" But, hey it'll have a wicked idle.
[Re: 602heavy]
#889863
12/29/10 12:28 AM
12/29/10 12:28 AM
Posts: 202 TN Hoosier
jb500
TN Hoosier
Me , i'd go with the Ultradyne.............the earlier that 590 is installed the less top end #s that motor is gonna see , why install on a 100 CL? , surely this is telling you the cam is too big for the motor , installing that cam too early will be fine for the 'seat of the pants' feel , with the comp ratio you're running that 590 will be a dog , much better grinds out there for you're application.
What about the UD 290/.597 cam? 263@.050 and 108CL. That is what Tim at Bullet recommended for my stock stroke combo: 10.5,RPM heads, Dynamic 9.5, and 4.10. Runs great on the street and has a mean ex lope.
My best so far is 11.58@115 3800lbs Coronet. May be more in it if I knew what I was doing(not much track time....yet).
