Guys with Strange struts and spindle mount front wheels #889800
12/27/10 08:06 PM
12/27/10 08:06 PM
Oklahoma
silverfish Offline OP
Oklahoma
Are you using the single piston Strange brake setup? The one with the sliding piston? What other options are there out there besides this setup? I just can't seem to get much braking power out of it. Any input?
Re: Guys with Strange struts and spindle mount front wheels [Re: silverfish] #889801
12/27/10 08:14 PM
12/27/10 08:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont have the spindle struts but I have the fixed
position dynomites... it uses a cross over tube so
both pads move together... I get as much braking as
my tires can handle
Re: Guys with Strange struts and spindle mount front wheels [Re: MR_P_BODY] #889802
12/28/10 12:28 PM
12/28/10 12:28 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Not aware of any "kits" out there that incorporate anything other than the single piston caliper.
Re: Guys with Strange struts and spindle mount front wheels [Re: Al_Alguire] #889803
12/28/10 12:40 PM
12/28/10 12:40 PM
Oklahoma
Oklahoma
Do you have the Strange setup on your car?
Re: Guys with Strange struts and spindle mount front wheels [Re: silverfish] #889804
12/28/10 12:48 PM
12/28/10 12:48 PM
Las Vegas
Las Vegas
Yes I do. But I went with a non spindle mount set up. Like the spindle mount wheels more but did not like the brake options with my heavy car.
Re: Guys with Strange struts and spindle mount front wheels [Re: Al_Alguire] #889805
12/28/10 01:05 PM
12/28/10 01:05 PM
Oklahoma
Oklahoma
Well my car is light, 2250# without me, but it still doesn't feel right to me. Matter of fact, it won't even hold still with the linelock on in the driveway. This setup was already on the car when I bought it. I'm wondering if maybe something is plumbed wrong? I don't know anything about brake systems, never really messed with them. I've bled these to make sure there wasn't any air in the lines and everything seemed fine. They seem to have plenty of pressure at the calipers although I don't have a gauge on them to know exactly how much. I can put a second caliper on each side because my spindles have the mounts on both sides of the strut so maybe that would help?
Re: Guys with Strange struts and spindle mount front wheels [Re: silverfish] #889806
12/28/10 01:10 PM
12/28/10 01:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you have a adjustable prop valve on them....I had
to really cook the fronts so they became effective...
just dont over heat the rotors
Re: Guys with Strange struts and spindle mount front wheels [Re: MR_P_BODY] #889807
12/28/10 01:20 PM
12/28/10 01:20 PM
Oklahoma
Oklahoma
Yes there is a prop valve and it is screwed all the way in. I believe that means it is giving full pressure to them right?
Re: Guys with Strange struts and spindle mount front wheels [Re: silverfish] #889808
12/28/10 01:38 PM
12/28/10 01:38 PM
Oklahoma
Oklahoma
Correction: I just went to the shop and checked and the prop valve is on the rear brake line not the front but it is screwed all the way in. So if I understand the system correctly that means I've got full pressure to the front brakes if there is no prop valve on them right? It also means that I've got full pressure to the rear brakes if the prop valve is screwed all the in correct?
The front brake line runs from master cylinder to the line lock and then out from it to a tee and of course then to both sides of the front brakes. Could something be wrong with the linelock that would cause the front brakes to not work correctly?
Re: Guys with Strange struts and spindle mount front wheels [Re: silverfish] #889809
12/28/10 02:03 PM
12/28/10 02:03 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
It is possible you have too large a diameter master cyl. Do you know what Dia the piston is in your master cyl? typicaly you would want a 3/4" diameter
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Guys with Strange struts and spindle mount front wheels [Re: W.I.N. Racing] #889810
12/28/10 02:21 PM
12/28/10 02:21 PM
Oklahoma
Oklahoma
No I don't know that info. It looks to be a Strange master cylinder. I am assuming that when the car was built this was all bought and installed at the same time. So I'm going to assume its a Strange master cylinder but not sure of the piston diameter.
Re: Guys with Strange struts and spindle mount front wheels [Re: silverfish] #889811
12/28/10 03:40 PM
12/28/10 03:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
From the way it sounds your doing ALL of your braking
with the front tires... open up the prop valve so the
rears are doing MOST of the work(if this is a big
tire race car)
Re: Guys with Strange struts and spindle mount front wheels [Re: MR_P_BODY] #889812
12/28/10 03:42 PM
12/28/10 03:42 PM
Oklahoma
Oklahoma
tire race car)
Yes its a big tire Top Sportsman car 33.5 x 16.5 tires. I was under the impression that if the prop valve is screwed all the way in that gives full pressure to the rear tires? Is that not correct? If thats not correct then I am definitely not giving my back tires any pressure because the valve is screwed in as far as it will go!
Re: Guys with Strange struts and spindle mount front wheels [Re: silverfish] #889813
12/28/10 03:53 PM
12/28/10 03:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
tire race car)
On mine its just the opposite from what you have...
plus mine is on the fronts.... a prop valve is meant
to slow the fluid on a spike but it will balance out
after X period of time.... you know that the fronts
cant brake as much as the rears just due to the size
and a race car doesnt dive like a street car
Re: Guys with Strange struts and spindle mount front wheels [Re: silverfish] #889814
12/29/10 01:49 AM
12/29/10 01:49 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
Went through the same hassle and did allot of head scratching.
I had the 4 piston calipers on the fronts and they held in the burnout box easy. Then I changed to the single piston calipers for the spindle mount wheels and it would push forward on the burnout.
I have to make sure I pump the brakes and trap at least 1000 psi on the line lock and it will hold .
I have a 3/4 master cylinder on the front and a 7/8 master cylinder on the back running dual 4 piston calipers
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Guys with Strange struts and spindle mount front wheels [Re: go green] #889815
12/29/10 02:32 AM
12/29/10 02:32 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
where does the line come off of the master cylinder that is going to the front brakes???It should be the one closest to the mounting flange. If that is correct next we need to know the brake pedal ratio. I have that same brake setup on a 3000lb bracket car that runs 160 and has never pulled the chute.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Guys with Strange struts and spindle mount front wh [Re: go green] #889816
12/29/10 02:39 AM
12/29/10 02:39 AM
Oklahoma
Oklahoma
How does it do on stopping power at the top end? Are you running two separate master cylinders?
I ran it like this when i had a 750hp motor and it was no big deal. Now i have a 1100hp motor and plan to run nitrous also so it becomes a whole different story. I chose to not go test with it when i had the chance a month or so ago because i was scared of these front brakes! I just want to make sure everything is right before i go to the track with it. I guess i need to get a pressure gauge and see what ive got there.
Re: Guys with Strange struts and spindle mount front wh [Re: bigtimeauto] #889817
12/29/10 02:46 AM
12/29/10 02:46 AM
Oklahoma
Oklahoma
Not sure on that one without looking at it. I will look at it tomorrow and see. How do i measure brake pedal ratio? That kind od stopping power is what I'm looking for. Dont wanna mess with the chute unless I have to. And I wont ever race it on the 1/4 just 1/8 so probably 145-150mph will be where I plan on being with this car on the 1/8. I feel like an idiot not knowing anything about this stuff but I just havent ever messed with brakes.
Re: Guys with Strange struts and spindle mount front wh [Re: silverfish] #889818
12/29/10 02:57 AM
12/29/10 02:57 AM
go green Offline
go green  Offline
I have two separate master cylinders with a balance bar ( sprint car style peddles )
Your rotors are dead cold in the burnout box and when you jump on them at the finish line . I think a lot of people notice the brakes getting better after four to five seconds after braking with regular brake pads . I took me a while to put those two and two together.
Throw the stock Willwood and Strange brake pads in the garbage and use the Poly-matrix pads from Willwood . The poly-matrix pads are aggressive and have superior cold braking qualities over the multi range stock pads .
This brake pad change alone will help your stopping power immensely.
Re: Guys with Strange struts and spindle mount front wh [Re: go green] #889819
12/29/10 12:17 PM
12/29/10 12:17 PM
Oklahoma
Oklahoma
Thanks for the info....
