Re: 275/60/15 on a Cuda (long) [Re: jvcuda] #889014
12/27/10 02:29 PM
12/27/10 02:29 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Yes, I'm sure there is a bit of variation from car to car. The other factor for me was the appearance. I know some folks are fine with the tire location in the wheelwell with the 4.5"BS wheels, but it wasn't quite what I was looking for.
Re: 275/60/15 on a Cuda (long) [Re: Pacnorthcuda] #889015
12/27/10 02:32 PM
12/27/10 02:32 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Yes, I believe you are right; the factory angled the springs to assist with handling. There is likely some affect to straightening out the leaf springs, but I doubt it would be noticeable unless you were road racing. I believe all of the spring relocation kits try to put the springs parallel in order to maximize tire clearance, so what I did is no worse than those solutions.
Re: 275/60/15 on a Cuda (long) [Re: davenc] #889016
12/27/10 04:06 PM
12/27/10 04:06 PM
London, England
Gavin Offline
Gavin  Offline
London, England
Yes I did wonder about the factory rationale for the non-parallel springs - was it purely packaging or was there an advantage?
If there was a handling advantage then I'm guessing that it will be more than compensated for by the extra tread width. But it would be good to know.
(But agree that traditional relocation methods would have the same issue anyway)
Re: 275/60/15 on a Cuda (long) [Re: Gavin] #889017
12/27/10 04:43 PM
12/27/10 04:43 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
That certainly is a new approach to fitting rubber. It seemed to be a bit intensive time wise and now with a custom backspace wheel, may not have been the cheapest, nor quickest, method to achive a bolt in fit, but I'm glad it worked for you.
The simpler bolt in method is to move the springs inboard 3/4 to 1 inch, then bolt in the B body rear. While the B body housing does not offer any more wheel well room than the E body housing, their ready availability does make it easier for most guys than cutting and rewelding the perches off the E body rear. However, either of these changes will alter the required backspace to fit the rims, especially since there is a difference in B body housing widths pre/post 67.
For my Challenger, the 3/4" spring move combined with a '67 B body housing allow a 15x10 with 5" backspace install that resulted in a 12" wide tire fitting with room to spare on both the spring and fender side. Entirely bolt in, using off the shelf parts.
BTW, the splayed spring design is a handling benefit that is designed in to all E bodies, post 72 B bodies, and all FJM bodies. E bodies are narrower at the front, while all other are narrower in the rear. What the splayed mount does is put the spring in a position that provides additional torsional resistance to the leaf, hence more roll resistance to the body, and minimizes roll steer by the rear housing moving and altering wheelbase length. The extra tread width doesn't contribute to either of these attributes.
Re: 275/60/15 on a Cuda (long) [Re: TC@HP2] #889018
12/27/10 05:38 PM
12/27/10 05:38 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
I think the approach I took was an "intermediate cost" route. I considered using a B-body rear but if I went that route I didn't want to put an 8 3/4 back in. The cost of stepping up to a Dana was significant.
Even if using an 8 3/4, you still need the housing and axles from a B-body plus the front and rear hangers. The AR TT2 15 X 10 rims are actually more expensive (around $270) versus the custom offset 15 X 8 (around $250). From what I investigated, going to a B-body rear was going to be more expensive than what I did. Of course the extra expense would allow the fitment of even larger tires but for my car, 275/60 will be plenty.
I do agree that it took a good bit of time and labor to work this out. And I did end up with a set of rims which I didn't use. I can still recover some of that cost if I choose to sell them. It would have been easier if I had the idea in advance. I thought I would share this idea, since it might help someone else facing a similar situation.
I agree that it is not for everyone, but it may be worth considering. For me, it provided the "right" look for the car.
Thanks for the insights on the handling. I'll have to wait until the weather improves to see if I can notice any change in the roll stiffness of the car.
Re: 275/60/15 on a Cuda (long) [Re: TC@HP2] #889019
12/27/10 06:15 PM
12/27/10 06:15 PM
London, England
Gavin Offline
Gavin  Offline
London, England
Thanks, that explains it, useful info. FWIW my point about the extra tread width was not that I expected it to directly compensate for the loss of splayed spring benefit (whatever it was) but just that usually one of the most significant 'handling' improvements is better tires. Therefore I was suggesting that even though a benefit may have been lost, the one that was gained is also significant - probably more so than what was lost!
Or to put it the other way around - if it isn't then there is not much point in doing this unless you don't care about cornering.
Re: 275/60/15 on a Cuda (long) [Re: Gavin] #889020
12/27/10 07:10 PM
12/27/10 07:10 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I just stuffed 325 50R 15 NITTO 555R's under my '70 'Cuda with 10 inch wide 5.5" backspaced Ralleys, a b-body rearend, Dr Diff's 1 inch inset hanger kit and Caltrac Monoleafs. It's tight, but nothing rubs through the whole range of travel,and I didn't have to roll the fenders. It fills the wheel well nicely.
Re: 275/60/15 on a Cuda (long) [Re: jbc426] #889021
12/27/10 07:12 PM
12/27/10 07:12 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
...another view. I don't believe anything bigger will fit without rolling the fender and relocating the spring perches inboard a bit more with DrDiffs 1.5 inch kit. He says the rear valance may interference issues with that kit though. I guess I'll just have to get by with these for now.
Re: 275/60/15 on a Cuda (long) [Re: jbc426] #889022
12/27/10 07:13 PM
12/27/10 07:13 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
...and from the front.
Re: 275/60/15 on a Cuda (long) [Re: jbc426] #889023
12/27/10 07:51 PM
12/27/10 07:51 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Wow! That sure is stuffed. Is this a street car? How much tire sidewall to inner fender lip clearance do you have on rear suspension compression?
Re: 275/60/15 on a Cuda (long) [Re: davenc] #889024
12/28/10 01:34 AM
12/28/10 01:34 AM
1974Cuda360 Offline
1974Cuda360  Offline
jbc426, I am also curious to know if your car is street driven often and how the Caltrac setup affects the feel of the car on the street as well as the track.
This is a very informative thread. I am looking into improving my rear suspension and this information really helps.
Re: 275/60/15 on a Cuda (long) [Re: davenc] #889025
12/28/10 01:57 AM
12/28/10 01:57 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
99.99% street, and still about two months away from being back on the road since the early '80's.
It's going to be too fast for the track without a full cage, but at least I'll get one good lap in.
I can stick my hand, up to my palm knuckles, between the tire and the fender lip. On a hard bounce only fingers. I ground the sheet metal until it was even with the wheel moulding trim to get the maximun clearance.
Re: 275/60/15 on a Cuda (long) [Re: 1974Cuda360] #889026
12/28/10 02:02 AM
12/28/10 02:02 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
It's a street car. I've only done a few hotlaps around the block, but it rides smoother than it ever has before, and that's with no glass, interior, trim etc. Caltracs with the split monoleafs +1 inch ride height are sweet.
It hooked up hard with some little pinner tires I had on it for painting etc when I smoked 'em in the driveway. Haven't launched on these big tires yet, as I have my steering column and dash out right now.
Re: 275/60/15 on a Cuda (long) [Re: jbc426] #889027
12/28/10 05:03 AM
12/28/10 05:03 AM
K
kielbasa Offline
kielbasa  Offline
K
holy cow, love the look of the 325's in there!!
more pics of you have any.....definitely a path I'd like to take on my AAR.
Thanks for all the info from all of you guys!
Re: 275/60/15 on a Cuda (long) [Re: jbc426] #889028
12/28/10 11:09 AM
12/28/10 11:09 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Looks good.
I'm planning on doing a similar B body Dana/Dr. Diff offset hanger swap under my wife's 71 R/T Challenger with a 325/50-15 drag radial tire.
My rim is a 15x10 with a 5.75" back spacing which I'm hoping to adjust outward with wheel spacers.
How close is your tire/rim on the inside near the leaf spring?
Re: 275/60/15 on a Cuda (long) [Re: KillerBee] #889029
12/28/10 12:50 PM
12/28/10 12:50 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Looks good.
It just missed touching when I first bolted them on. Now, it's just past the minimum clearance, at about 1/3 of an inch without the use of a 1/4 inch spacer. Dr diff said 1/4 inch is the absolute minimum clearance from the spring.
To get that much on my car without the spacer, I had to grind a slight relief in the rear mono-leaf being careful to to get it hot and spreading it out over aproximately 8 inches, being careful to smooth it completely and re-radiusing the edge again. I wouldn't have done this to the front segment because it has to handle much more stress, but in this case I didn't have to because of the earlier mentioned angling of the rea springs in the e-body. I have over 3/4 of an inch clearence up there.
I felt the rear spring's mono-leaf segment is really over-designed, so I got my space that way instead of using the 1/4 inch spacer and giving up that same clearance at the sharper fender lip. Unless you look closely, it isn't noticable. Of course, I'll be keeping a close eye on it for any type of deflection, bending etc.
On a regular leaf spring car, I would roll the fender lip and use the 1/4 inch spacers with the 5 & 1/2 inch backspaced 10 inch rims, order 5 1/4 inch backspaced rims, or use the appropriate spacer for the ones you have with the earlier dana.
For a Challenger, I would use the 1 & 1/2 inch Dr Diff kit. I believe he said you'll have to relocate the spring perch, or use an earlier model Dana 60. Challengers don't have the interferance issue at the valance panel that 'Cudas have.
Re: 275/60/15 on a Cuda (long) [Re: jbc426] #889030
12/31/10 01:47 PM
12/31/10 01:47 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
My Challenger with a 3/4" spring kit, 67 B body rear, 15x10 with 5" back space and a 26x10x15 tire. That measures out to about a 305r/50x15 in metric terms.
Re: 275/60/15 on a Cuda (long) [Re: TC@HP2] #889031
12/31/10 02:07 PM
12/31/10 02:07 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Love that stance and rake!
Re: 275/60/15 on a Cuda (long) [Re: jbc426] #889032
01/02/11 02:03 PM
01/02/11 02:03 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Thanks!
what you don't get a perspective of with that shot is how low the car sits. While I haven't measured it, I'd guess the top of the roof to be around 48-52".
