Re: Best MW Intake For 4500 Series Carb?
[Re: tboomer]
#887888
12/25/10 01:43 PM
12/25/10 01:43 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
I like my Indy on my 440-1 heads...made 60hp more than the Indy x-ram. About 1 1/2in of clearance to the scoop. 337 is a good piece also. Have Radar clean either up and port match 'em! Happy Holidays Ted.
The little old lady from Pasadena is back!
[Re: tboomer]
#887890
12/25/10 02:05 PM
12/25/10 02:05 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
Dwayne put the Indy 440-3 on mine when it was up there last.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: tboomer]
#887893
12/25/10 08:41 PM
12/25/10 08:41 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Thanks,Dap! I have spent about 2 grand on parts for this thing since late fall...Another 2 grand and it should be ready to go!!
4 grand ! you are definately going to drive around me this year !
[Re: tboomer]
#887896
12/26/10 12:34 PM
12/26/10 12:34 PM
Dap
Staten Island N.Y.
I have only used the Indy valley covers. Dwayne used the right stuff to seal them up and never had an issue with leaks. What do you have left to do?
[Re: Dap]
#887898
12/26/10 06:47 PM
12/26/10 06:47 PM
Posts: 16,934 NC
440Jim
NC
My low deck has Indy heads and their valley plate. The gap to the heads is pretty small, maybe 0.030", and with gray silicone it never leaked or even hinted at leaking. To get it off for this winter's freshen up, I ran an Exacto knife blade down it to cut the seal.
[Re: tboomer]
#887901
12/27/10 06:47 PM
12/27/10 06:47 PM
BradH
...Radar will get the work...It will be interesting to see what the heads do after he starts grinding on them...
I wouldn't expect they're going to pick up that much going to a MW entry, just because the rest of the runner in that particular head is fairly limited. IMO, the gain will come from being able to use a less restrictive intake to support the large(r) engine, not from major gains in head flow.
[Re: AndyF]
#887906
12/28/10 03:26 AM
12/28/10 03:26 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
My Indy dual plane will be opened up to Max Wedge size but I dont plan to run the 4500 carb at first. Ron
