Re: Best MW Intake For 4500 Series Carb?
[Re: tboomer]
#887888
12/25/10 01:43 PM
12/25/10 01:43 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
I like my Indy on my 440-1 heads...made 60hp more than the Indy x-ram. About 1 1/2in of clearance to the scoop. 337 is a good piece also. Have Radar clean either up and port match 'em! Happy Holidays Ted.
The little old lady from Pasadena is back!
[Re: tboomer]
#887890
12/25/10 02:05 PM
12/25/10 02:05 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
Dwayne put the Indy 440-3 on mine when it was up there last.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: tboomer]
#887893
12/25/10 08:41 PM
12/25/10 08:41 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Thanks,Dap! I have spent about 2 grand on parts for this thing since late fall...Another 2 grand and it should be ready to go!!
4 grand ! you are definately going to drive around me this year !
[Re: tboomer]
#887896
12/26/10 12:34 PM
12/26/10 12:34 PM
Dap
Staten Island N.Y.
I have only used the Indy valley covers. Dwayne used the right stuff to seal them up and never had an issue with leaks. What do you have left to do?
[Re: Dap]
#887898
12/26/10 06:47 PM
12/26/10 06:47 PM
Posts: 16,934 NC
440Jim
NC
My low deck has Indy heads and their valley plate. The gap to the heads is pretty small, maybe 0.030", and with gray silicone it never leaked or even hinted at leaking. To get it off for this winter's freshen up, I ran an Exacto knife blade down it to cut the seal.
[Re: tboomer]
#887901
12/27/10 06:47 PM
12/27/10 06:47 PM
BradH
...Radar will get the work...It will be interesting to see what the heads do after he starts grinding on them...
I wouldn't expect they're going to pick up that much going to a MW entry, just because the rest of the runner in that particular head is fairly limited. IMO, the gain will come from being able to use a less restrictive intake to support the large(r) engine, not from major gains in head flow.
[Re: AndyF]
#887906
12/28/10 03:26 AM
12/28/10 03:26 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
My Indy dual plane will be opened up to Max Wedge size but I dont plan to run the 4500 carb at first. Ron
[Re: 383man]
#887907
12/28/10 04:15 AM
12/28/10 04:15 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Im considering that same intake myself.
But for Ted, I think you need to repost the New base combo again. Its been awhile , and I forget. sorry
Its a 512 Ci, with, ??
[Re: cudadon]
#887909
12/28/10 01:58 PM
12/28/10 01:58 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
I'm a huge fan of the Indy 2d, especially in MW form and additional radius work in the lower plenum....a 360 CFM dual plane is a pretty serious piece that will keep pace with most of the heads out there. There's at least 30HP in the radius work out of the lower plenum, the upper plenum is pretty much good to go once you open up to MW. I too wish it was available with a 4500, I've thought to take mine to see if it can be Bridgeported (and I was secretly hoping Andy might have already sized this up ); but my pro-systems 4150 1000hp seems to be doing fine....6800rpm at 517 cubes. To be honest it runs so good I haven't thought to open the hood on the car in a couple months My combo (380cfm heads) leaves some top end power on the table that I might need a single plane and a .700 lift cam to reach my in my old age I guess I'm very happy to leave well-enough alone...I can't bring myself to do anything that would alter the Formula 1-like throttle response and roll-on torque of this badazz dual plane.
[Re: AndyF]
#887910
12/28/10 03:19 PM
12/28/10 03:19 PM
Posts: 16,934 NC
440Jim
NC
Those choices are the Indy 440-3, 440-3X and Edelbrock Super Victor.
What is the height comparison between them?
I see the regular Victor listed as 6.1" on the Edelbrock site, but I don't see the manifold height listed on the Super Victor?
From the Indy catalog, the 440-3 is 6.75" and their 440-3X says 8.4"!
[Re: tboomer]
#887913
12/29/10 10:15 PM
12/29/10 10:15 PM
Posts: 151 ohio
Rich970
ohio
Thanks for the welcome. i just pulled mine this is what it looks like in side.
[Re: Cab_Burge]
#887915
12/30/10 11:56 AM
12/30/10 11:56 AM
Posts: 151 ohio
Rich970
ohio
Thanks i was told that mine was one of the early ones . i saw a pic of another one that looked better inside. to my understanding this is a stock out the box 440-3 also. i know mine is i bought it from indy new
[Re: Rich970]
#887916
12/30/10 12:18 PM
12/30/10 12:18 PM
Posts: 16,934 NC
440Jim
NC
Rich, You really need to start a new topic for your question, but a quick 2-cents: That looks like the latest casting. The top of the runner dividers under the cloverleaf are cast and not machined like the previous version. There may have been a much earlier version also. Those intakes didn't have the 4 large, oval injection bosses, but rather 8 small round bosses slightly higher on the runners. We need some Indy Intake pics and carb height dimensions to add to the Moparts.com Tech archive. BB Intake Pics My attachement is an old 400-3, and the injector bosses have been fitted with injectors, but you can see the old style Indy lettering, and the smaller, round, bosses.
[Re: 440Jim]
#887917
12/30/10 05:11 PM
12/30/10 05:11 PM
Posts: 151 ohio
Rich970
ohio
[Re: Sport440]
#887918
01/03/11 02:02 PM
01/03/11 02:02 PM
Posts: 26,030 United Socialist States of Ame...
tboomer
Mike...Here is the base combo.. RB 512 CID 13.4-1 compression M-1 intake with a 2" 4500 adapter Holley 1150 Dominator Hooker 2" adj.race headers MP ported 383-440 aluminum heads Mech.solid roller cam 260/268 with 1.6 rockers .652/635 lift car is 3395# with me in it.
[Re: tboomer]
#887919
01/03/11 06:42 PM
01/03/11 06:42 PM
BradH
Now you need to switch to a cam w/ about 15 degrees more duration and .100" more lift that fits the rest of the new combination.
