Re: 318 to 273 Problems
[Re: bobs69]
#886648
12/24/10 11:24 AM
12/24/10 11:24 AM
Posts: 2,826 NY usa
540challenger
NY usa
What problems will i run into changing from a 318 to a 273 in my 66 pickup? Thanks
The only major problem that needs to be address before you do the swap is the transmission on autos. Early 273, 67 and back have a smaller recess where the nose of the torque convertor goes inot the crank. double check before you install.
[Re: JDMopar]
#886650
12/24/10 01:13 PM
12/24/10 01:13 PM
Posts: 2,826 NY usa
540challenger
NY usa
Good catch! I forgot about that one.
Yes that one can cost alot of If you miss it ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: stumpy]
#886652
12/24/10 02:33 PM
12/24/10 02:33 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Mabey he has a bad 318 in his truck and happens to have a good 273 sitting around. Mabey he just wants better MPG and don't mind the performance hit, it could be lots of reasons.
He will get better miledge and it will take longer to get an equal sized load going. My 239 in my dakota gets way better miledge than my 318 dakota even towing a 67 cuda on a flat bed but it was working a lot harder going up mountain passes. As a matter of fact the little motor truck only got one MPG less loaded than the V8 did un loaded.
As for the converter you can get one made with the small hub and regular 904 guts. You could also swap cranks.
[Re: stumpy]
#886654
12/24/10 03:15 PM
12/24/10 03:15 PM
HotRodDave
Kalispell Mt.
It will get better MPG, been there done that. It does not work harder, the same amount of work or less (if you accelerate slower)actually gets done. Also it has less pumping loss and less friction loss. At the same power output say about 75HP (about what his truck would require to hit 70mph and maintain it) the 273 will have lower intake vaccume that fights the pistons going down added to the friction reduction it WILL get better MPG as long as the tunes are right for both motors. If bigger is better than he should be able to build a 605 hemi and get 50 mpg because it does not have to work as hard ![](/ubbthreads/images/graemlins/eyes.gif)
[Re: stumpy]
#886659
12/24/10 08:28 PM
12/24/10 08:28 PM
HotRodDave
Kalispell Mt.
Obviously you never tried the experiment I sugested before, the vaccume thing is a proven fact. Low vaccume is part of why a diesel gets so much better MPG and why an atkins cycle engine gets good MPG. Now... Go get in your car go to the top of a really big hill, close the throttle shut the engine off and coast, this is simulateing high vaccume low compression, then hit the gas and you can feel the vehicle coast much easier now even though compression is much higher but vaccume is now gone, this will prove beyond a shadow of doubt that vaccume robs more power than high compression. It is true that you want to build your engine to produce high vaccume but that is only because it means your engine is produceing the most HP from a given amount of fuel, what you need to do is to maximize it is gear it really high so it actually runs at a lower vaccume, any HP you produce above what is needed to maintain your speed is wasteing fuel.
Also WOT HP has nothing to do with MPG at a cruise or even mild acceleration, it only takes a certain amount of HP to keep a vehicle going at a certain speed no matter how big the engine is, in his case it probably takes around 75 HP or less around 70 mph and the 273 is more than capable of that and at less than WOT also. Anything more is WASTED FUEL.
My 66 cuda with a 273 got much better MPG than my 68 318 cuda in stock form both motors were completly stock and had 2.76 rear gears. No the 273 was not fast but MPG was un-questionably better till I built the super duper MPG 318 and I am 100% convinced that a 273 built the same way would have got even better MPG.
[Re: stumpy]
#886663
12/25/10 01:02 AM
12/25/10 01:02 AM
HotRodDave
Kalispell Mt.
I agree that he is wrong, I even came up with a very scientific test to prove it, he has not tried it nor has he come up with any evidence or test to prove his "theory" or disprove the facts. The fact is if you hook a vaccume gauge to your engine it will still have very high vaccume at 70mph cruise speeds because the typical automotive engine is way more power than is needed for that operation.
[Re: stumpy]
#886665
12/25/10 05:33 AM
12/25/10 05:33 AM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Mom's '93 Dakota got the same or worse mileage than my old ;95 318 truck. My truck would run circles around it, they were basically the same truck, extended cab 2wd autos. Her truck has manual windows and locks however.
I'll take the 318 over the V6 any day.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: HotRodDave]
#886666
12/25/10 09:31 AM
12/25/10 09:31 AM
Posts: 15,487 Florida
scratchnfotraction
so stumpy agrees that yall disagree but you still feel you do not agree that you disagree ![](/ubbthreads/images/graemlins/shruggy.gif) I remember a poster of Archie Bunker,it read "in his own mind,he knows he is right" sounds like you are the same way ![](/ubbthreads/images/graemlins/shruggy.gif) at least stumpy went half way to agree to disagree,so you most likly will not agree with anyone unless the say you are correct and agree with you I think to agree that you disagree would be the end of it hard to be humble when you know your right in your own mind and wont agree to disagree and move on sometimes I guess ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: scratchnfotraction]
#886669
12/25/10 10:40 AM
12/25/10 10:40 AM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
Owned a 67' Cuda with the 273 Commando Engine and 4-speed. Great car!! Down on power compared to a 68' with a 340, BUT I knocked down over 21-22mpg on the road. Always kept the motor in a good state of tune. Now compared to my ex-car 79' Chrysler Lebaron Coupe with the "Lean Burn" 318 and 3speed auto w/lockup converter, mileage was different. Besides the 318 being smog-laden, it too was down on power. it had VERY good road manners but I couldn't seem to get out of the high teens' in on road mileage. I took the black box out (lean burn module troublesome) and put the hi-po ignition on it. Pickup speed was improved a lot but mileage was pretty much the same. If I drove a 50-55 with the cruise on for LONGER trips (level roadways out west), I'd notice almost NO difference from my 'Cuda. The 'Cuda ran at 60-65 on the road. Had NO problems with it as long as it was tuned (Had a mechanical cam in it) and the AFB performed flawlessly!! ![](/ubbthreads/images/graemlins/2245452-furysmiley.gif)
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: HotRodDave]
#886670
12/25/10 11:44 AM
12/25/10 11:44 AM
HYPER8oSoNic
Desert Tracker
I guess the argument goes back to the AGE OLD comparision of balance between HORSEPOWER vs. TORQUE. Throw into the mix: BSFC, Vehicle weight, gearing, tire/front end science, C of G, and so on and so forth, and you have ENDLESS possibilities on the mileage/power factor. YOU BOTH are RIGHT in your RESPECTIVE ways, since there are no CONCRETE standards to base the "theories" on. Everything Detroit builds is based on a COMPRIMISE, and IF you guys still are at odds, settle this at the TRACK. AT least there you can have a laugh or two, as well as BRAGGING RIGHTS!! A MERRY CHRISTMAS and HAPPY NEW YEAR to all!! And God Bless us, every one!!![](/ubbthreads/images/graemlins/thumbs.gif) ![](/ubbthreads/images/graemlins/XMasTruck.gif)
[Re: HYPER8oSoNic]
#886671
12/25/10 01:30 PM
12/25/10 01:30 PM
Posts: 2,826 NY usa
540challenger
NY usa
Unless it is a 318 magnum the 273 "if it is the 4bbl version should be very clost to the horse/torque power of 318 heck even the 2bbl version would be close enough to the 72 and after 318 you won't see and big difference just drive and enjoy. The guy before me put a 273 4bbl in my challenger and it drove fine and plenty of power to move on a side note it was no 1/4 street fighter but niether is a 318 ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: 540challenger]
#886672
12/25/10 05:34 PM
12/25/10 05:34 PM
HYPER8oSoNic
Desert Tracker
, but why put the smaller motor in a HEAVY chassis car for the 1/4 mi jaunts anyway!! It makes better sense to run the LIGHTEST chassis as per rules in class or bracket racing. Anything goes for street usage, if it moves it, it's good. Heck they HAD slant sixes in trucks for years and really no one has complained. If they did, a larger motor swapped in cured the problem. The 318 is nothing to sneeze at for racing, it just lacks in the breathing dept. on the top end scale! ![](/ubbthreads/images/graemlins/Twocents.gif)
