Re: got a 340 intake for my 318 RR...what next?
[Re: bigdaddywiz]
#886613
12/25/10 06:10 PM
12/25/10 06:10 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
That IS a nice looking car. I swapped an '84 4-v intake onto my '75 shortbed and it made a ton of difference. I'm running an Edelbrock 600 carb. Otherwise its a stock '83 318. I am running a 4-spd with OD so I didnt have to mess with the kickdown but the cable and bracket are stock 318-2v parts.
I used a cruise control holddown on my truck with the cable going through the vertical part to get the cable where it needed to be. I also flipped it around and its angled toward the drivers valve cover.
I am also running and 8 1/4 rear and the 4 gear is much more violent on it than an auto would be so I think you will be fine, same deal with the trans. Those tranny and rear combos were used on 360 R/T Aspens BTW so they can hold up to a bit more power than a person would think.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: MoPar Jamie]
#886614
12/26/10 12:29 AM
12/26/10 12:29 AM
Posts: 124 Pittsburgh, PA
bigdaddywiz
Pittsburgh, PA
here are a few more pictures of the intake and carb for those that wanted to see them...
73 Road Runner
09 Challenger R/T
[Re: scratchnfotraction]
#886619
12/28/10 02:00 AM
12/28/10 02:00 AM
bigdaddywiz
Pittsburgh, PA
so can anyone recommend a gasket set that will work with this particular carb?
73 Road Runner
09 Challenger R/T
