Re: multiple balancer timing marks
[Re: buildanother]
#885763
12/24/10 02:55 AM
12/24/10 02:55 AM
RapidRobert
Yeah I've only dealt w the std (1) slit pass car dampeners (BB) and some SB's w the partial ones/1 full one like Scratchn mentioned. Hope he posts a clear/close up pic of what we're dealing w & hopefully solve this
[Re: StukaJU87]
#885765
12/24/10 05:26 PM
12/24/10 05:26 PM
Posts: 15,487 Florida
scratchnfotraction
IMO,the one down below the timing tab is the 0* mark to use the others are not as deep as you said roll the lower/deeper cut line up to 0* and check for TDC I will wager thats it ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: scratchnfotraction]
#885766
12/24/10 06:32 PM
12/24/10 06:32 PM
RapidRobert
We got a clear pic! & that is a 1st for me ![](/ubbthreads/images/graemlins/blush.gif) (that many marks). W the one at the bottom being that far seperate plus the 3 bunched ones being "advanced" I'd say the chances are good. Stick the straw in there & lets find out. Turn it CW till the bottom mark is at O on the tab then stick the straw in then w your breaker bar/socket move the crank back & forth a bit on either side of the O & see if you're at the piston "dwell" point (can move the crank back/forth a bit from O & the straw does not move). If so put that mark at 10 BTDC (make sure your on #1 compression) then set the dist.
