Lokar cable ??? #885053
12/21/10 02:06 PM
12/21/10 02:06 PM
La Grange, Ky
70rrclone Offline OP
La Grange, Ky
is anyone using the lokar throttle and or kickdown cables. are they worth it? any idea what lenght is needed for a 70 B body w/440?
thanks
Shane
Re: Lokar cable ??? [Re: 70rrclone] #885054
12/21/10 02:46 PM
12/21/10 02:46 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I used the kickdown cable with a Carter Carb and had to modifiy the carb to hook to the cable. If you have the Holley no mods are needed. I also bought the bracket that holds the cable. It would have been cheaper for me to make it.
Cable works great though and is easy to adjust.
I'm using the factory throttle cable. Car is a 68 Charger with a small block and edelbrock performer intake.
Re: Lokar cable ??? [Re: 70rrclone] #885055
12/21/10 03:07 PM
12/21/10 03:07 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
thanks
Shane
I had bought the Lokar kickdown for my Slant 6 / 904...The parts they give you are rinky dink in my opinion. I had to make my own brackets so they wouldn't go anywhere. Install was easy but I figured for the money I spent it could have been designed better
on my 69 Charger, 440/727...I have the Bouchillon Kit...I love, it was a cinch to install, just study the diagram, cut where it says and load it up. Gives you a multitude of setups. I was sketchy on it because it said that it was for 2bbl/4bbl applications. Holley, Carter, Edelbrock, Demon etc....But I had to figure out where it was going and what pressure since I have Dual Quads. It looks great in the engine bay, looks like a stock piece.
More will chime in with Bouchillon's kit...give it a few
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Lokar cable ??? [Re: Pyper70] #885056
12/21/10 04:12 PM
12/21/10 04:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thanks
Shane
I haven't used either but more people ask questions about the lokar , which is basically a GENERIC kit for everything , the Bouchillon kit is a MOPAR specific kit .
Re: Lokar cable ??? [Re: 70rrclone] #885057
12/21/10 05:11 PM
12/21/10 05:11 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
Using the Lokar bracket, throttle and kickdown. Easy to install and adjust. Set it up once and never had a problem.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Lokar cable ??? [Re: 70rrclone] #885058
12/21/10 08:09 PM
12/21/10 08:09 PM
P
Pauls69 Offline
super gas
Pauls69  Offline
super gas
P
i have the lokar as well, but folks seem to really like the Bouchillon's kit. iirc, the Bouchillon version allows you to adjust the throttle position lever a bit better, but can't remember the details.
Re: Lokar cable ??? [Re: 36PLYM] #885059
12/21/10 08:23 PM
12/21/10 08:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
People who use the Lokar and claim to have no problems are either lucky or they have a problem and don't know it.
Re: Lokar cable ??? [Re: John_Kunkel] #885060
12/21/10 08:45 PM
12/21/10 08:45 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Re: Lokar cable ??? [Re: John_Kunkel] #885061
12/21/10 08:50 PM
12/21/10 08:50 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
well I have used many of them on Mopars and fords and have had 0 problems out of any of them but I have been in the trans business over 20 years and know a thing or two about set up.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Lokar cable ??? [Re: dusturbd340W5] #885062
12/21/10 11:30 PM
12/21/10 11:30 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I've had no problems with the Lokar trans and throttle cables. I guess the ones that have no problems know what they're doing.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Lokar cable ??? [Re: John_Kunkel] #885063
12/22/10 12:00 AM
12/22/10 12:00 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I would not hesitate to install a Lokar throttle cable and/or kick-down cable.
I must be one of the lucky ones. I have used Lokar cables on my last 5 builds as well as on several friends cars, and now keep a spare one in my tool box to help out others at the track that are having problems.
When Eric Paul's brother was having cable issues at a race in Indy, I installed a Lokar cable on it on the spot in less than 15 minutes to get him up and running again.
The Lokar trans kick down is so smooth I had a guy ask if I disconnected the back two barrels on his carb, because he could no longer feel the pedal get stiff for the secondaries (when actually he had been feeling a bind in the stock kick-down all along, not the carb).
Yes, they are fairly generic, but I work on race cars not show cars, and am used to a little fabrication.
Scott
Re: Lokar cable ??? [Re: ProStDodge] #885064
12/22/10 04:18 AM
12/22/10 04:18 AM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
I've used the Lokar stuff and some custom fabbing to get my van's throttle and kickdown just right (mostly for the throttle side actually). Worked great out of the box on the kickdown. I've also heard a lot of really good things about the Bouchillon kit and wouldn't hesitate to use either myself.
Re: Lokar cable ??? [Re: ProStDodge] #885065
12/22/10 03:02 PM
12/22/10 03:02 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Mine were easy to install and adjust.
Re: Lokar cable ??? [Re: Todd] #885066
12/22/10 03:12 PM
12/22/10 03:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I had this Lokar cable on my 63 since I put it on the road in 2006 with zero trouble. Works great for me. Ron
Re: Lokar cable ??? [Re: 383man] #885067
12/22/10 08:01 PM
12/22/10 08:01 PM
Amherst,NY
challengermike Offline
Amherst,NY
I used both the throttle cable and trans cable on my 69 coronet and they worked great,the gas pedal needed alittle fab work to attach the cable to it but it wasnt hard to do.
Re: Lokar cable ??? [Re: 383man] #885068
12/22/10 08:13 PM
12/22/10 08:13 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Same for me. It bolted right up to my eddy carb
Re: Lokar cable ??? [Re: Triggerfish] #2607304
01/16/19 01:26 AM
01/16/19 01:26 AM
Wausau Wi
Convertcuda Offline
Convertcuda  Offline
Wausau Wi
Anyone got a pic of how they attached cable to gas pedal?
Thanks Ken
Re: Lokar cable ??? [Re: Convertcuda] #2607589
01/16/19 04:26 PM
01/16/19 04:26 PM
moparx Offline
moparx  Offline
ken, i'm not a fan of the lokar setup for many reasons. with that said, i don't have a 727 kit here, but i have a pic of a 904 kit. it was used for a mockup, then removed. maybe you can see from the pics ?
the bracket bolts to the rear carb bolt, then the attaching stud bolts to the carb bracket. if the carb doesn't have the correct bracket, it is a MUST you obtain one.
hope this helps.
beer
Re: Lokar cable ??? [Re: 70rrclone] #2607713
01/16/19 08:45 PM
01/16/19 08:45 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
thanks
Shane
they suck,,, factory unit even if you have to modify it is much better.
Coming soon!!!!
Re: Lokar cable ??? [Re: 70rrclone] #2607871
01/17/19 01:22 AM
01/17/19 01:22 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My Lokar throttle cable has been on my car for over 12 years and still working perfect. So simple to install and hook up and easy adjustment. And I like the throttle bracket on the carb so it works fine no matter how tall or short your intake is. Worked way better then my original cable. But I only use the throttle cable as I don't use any kickdown cable with a manual valve body. Ron
