What's Your Fuel Cell Capacity?
#883957
12/19/10 07:25 PM
12/19/10 07:25 PM
Posts: 6,236 san diego
JonsGottaDusta
san diego
Hey Everyone, I was trying to get an idea on what the average size fuel cell the people of the race forum run in their vehicles. Also, how many of you are running a fuel sender for a functioning gas gauge, versus just opening the cap and checking the level? Please post what you've got!
Re: What's Your Fuel Cell Capacity?
[Re: JonsGottaDusta]
#883958
12/19/10 07:33 PM
12/19/10 07:33 PM
Posts: 1,443 Maryland
Dads426
Maryland
When we bought the car it had a 5 gallon and with a lift-off trunk we ditched that immediately and got a 12 gallon. Don't use a sender; for racing only we have a pretty good idea on how much we use throughout the day.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#883959
12/19/10 07:38 PM
12/19/10 07:38 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
5 gallon cell no sender.
#883965
12/19/10 08:25 PM
12/19/10 08:25 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
I kept the stock gas tank, 14 gallons useable (for street use and stealth reasons :whistling ) with the stock sender I had a stainless steel round sump welded into the bottom center of the stock tank with a # 19 AN male nipple welded into the bottom of the sump at the rear side so the # 10 hard line feeds out of it directly into a 100 micron filter and then to the electric fuel pump I've also owned and raced cars with 2.5 gallons, 5, 8 and 12 gallons tanks or cells I fill the tank in my Duster to the top of the filler neck and refilled it after qualifying each day. Adding fuel, which I have had to do in the past, is a pain with the added danger of the possibility of a fire every time you do it The more wieght you have behind the rear end the more traction you will have also , Within reason of course
[Re: MR_P_BODY]
#883967
12/19/10 08:31 PM
12/19/10 08:31 PM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
Valiant has a 4 gallon, Daytona looks to have a 12. No gauges or senders.
[Re: dartman366]
#883972
12/19/10 10:47 PM
12/19/10 10:47 PM
Posts: 19,398 Las Vegas
Al_Alguire
Las Vegas
4 gallons and keep it filled to keep the weight on the nose.
[Re: Al_Alguire]
#883973
12/19/10 11:02 PM
12/19/10 11:02 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
10 gallon aluminum, no sender, refill to about half, just above the foam after two runs.
[Re: Locomotion]
#883976
12/20/10 02:55 AM
12/20/10 02:55 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I have a cell that's listed as a 16 gallon tank, but only seems to hold 10-12. it has foam in it, does the foam really take out that much volume?
Also, anyone running a cell on their street car? is there a sending unit that actually works? mine seems to be total junk. I took it out, and the magnet on the floatie had fallen off, I RTV'd it in place with oil/gas proof black RTV, left it apart until the RTV cured...put it back together, flipped it upside down a few time and watched the gas gauge move accordingly....put it all back together and it don't work! it moves sometimes, but not very accurate.
this sending unit seems to work fine when it's out of the tank, but not when it's in the tank. I don't want to spend $100 on a new sender just to have the same problem!
**Photobucket sucks**
