Re: What's Your Fuel Cell Capacity? [Re: JonsGottaDusta] #883977
12/20/10 05:06 AM
12/20/10 05:06 AM
Vallejo California
T748 Offline
super street
T748  Offline
super street
Vallejo California
15 gallon cell with sender. With the car being race only now, I don't use a fuel gauge any more. It's not accurate enough. Instead I have an aluminum "stick" with 1/2 gallon increments marked on it. I usually run 3 to 7 gallons as ballast depending on track conditions. -Tom.
Re: What's Your Fuel Cell Capacity? [Re: JonsGottaDusta] #883978
12/20/10 08:16 AM
12/20/10 08:16 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
5 gal, no sending unit.
Re: What's Your Fuel Cell Capacity? [Re: JBurch] #883979
12/20/10 09:14 AM
12/20/10 09:14 AM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
8 gallon, no sender. Keep it filled to top of the foam.
Re: What's Your Fuel Cell Capacity? [Re: 68valiant68] #883980
12/20/10 10:34 AM
12/20/10 10:34 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
5 Gal, no sender, refill every 3 runs
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: What's Your Fuel Cell Capacity? [Re: 70Cuda383] #883981
12/20/10 12:05 PM
12/20/10 12:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'll be building my tank for the Rampage... I use
the stock sending unit but modifying it for the height
of the tank(extending the float arm) that way it
works with the stock gauge unit on the dash... in
yours make sure it isnt touching the tank where its
binding so it cant make the full travel... also check
your ground
Re: What's Your Fuel Cell Capacity? [Re: MR_P_BODY] #883982
12/20/10 12:09 PM
12/20/10 12:09 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
12 gallons to lazy for a 5 gallon cell
Re: What's Your Fuel Cell Capacity? [Re: MR_P_BODY] #883983
12/20/10 02:01 PM
12/20/10 02:01 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
your ground
mine is a tube sending unit, the foam float is inside the tube, magnet on the foam. as the foam rises and falls, the magnet changes the resistance through the sending unit.
the ground seems to work ok. sometimes the gauge reads full all the time, then it reads empty all the time, then it reads somewhere in the middle for awhile...almost as if the foam is stuck.
how do I fix this? my truck is a street truck, and I really prefer to have a functioning gauge instead of having to remember the miles and fill up per the number of miles driven.
**Photobucket sucks**
Re: What's Your Fuel Cell Capacity? [Re: JonsGottaDusta] #883984
12/20/10 09:50 PM
12/20/10 09:50 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I made my cell, 20 gallons, slosh baffles, sending unit with a baffle around it, sump, fits like a glove.
CrAzYMoPaRGuY
Re: What's Your Fuel Cell Capacity? [Re: CrAzYMoPaRGuY] #883985
12/20/10 09:58 PM
12/20/10 09:58 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Mine is an alum, home made tank. 4.25 gal, no sender. I fill it after every pass and use a wooden stick for a gauge.
Brian Dunnigan
Re: What's Your Fuel Cell Capacity? [Re: JonsGottaDusta] #883986
12/20/10 10:11 PM
12/20/10 10:11 PM
NC
440Jim Offline
440Jim  Offline
NC
For drag racing, I like a small fuel cell. But 5-6 gallons makes life a little easier.
I am running a 4 gallon cell with my injection (which needs a front cell... weight). And that is getting on the small side for round-robin racing with no help to get the fuel jug back to the staging lanes.
Re: What's Your Fuel Cell Capacity? [Re: JonsGottaDusta] #883987
12/20/10 10:31 PM
12/20/10 10:31 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
15 gal yes w a sender,car burns alot of fuel.
Re: What's Your Fuel Cell Capacity? [Re: 440Jim] #883988
12/20/10 10:44 PM
12/20/10 10:44 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Yeah, especially when we park at the finish line at MIR and don't feel like schleping the fuel jug to the staging lanes...
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: What's Your Fuel Cell Capacity? [Re: Dads426] #883989
12/21/10 03:19 PM
12/21/10 03:19 PM
san diego
JonsGottaDusta Offline OP
san diego
Thanks for all the replies, everyone. I'm actually surprised to hear how many of you guy are running 3-5 gallon cells.
Are any of you guys running EFI on your race cars with a cell?
Thanks,
- Jon D.
Re: What's Your Fuel Cell Capacity? [Re: JonsGottaDusta] #883990
12/21/10 07:18 PM
12/21/10 07:18 PM
Calif, USA
V
viperrt Offline
viperrt  Offline
V
Calif, USA
Custom aluminum holds about 12 gallons no sender
