Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883514
12/24/10 06:55 PM
12/24/10 06:55 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
4. From the underside.
Troy
Houston Mopar Connection Club
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883515
12/25/10 11:14 AM
12/25/10 11:14 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Looks great Troy. Those AMD peices are sweet.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: My '69 C500, replacement of the lower core support... [Re: chargervert] #883516
12/27/10 02:31 AM
12/27/10 02:31 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Looks great Troy. Man if I lived a little closer, I'd bring my rig out there and school you on welding. I know you'd get a kick out of it. An afternoon of practice and you'll want your own welder for sure.
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883517
12/27/10 11:08 AM
12/27/10 11:08 AM
sixbbl69 Offline
sixbbl69  Offline
you don't have to be to smart to put fake spot welds on a car. with a Linco spot welder it will look and be right.if i were you i would buy another part and do it right.
Re: My '69 C500, replacement of the lower core support... [Re: sixbbl69] #883518
12/27/10 11:35 AM
12/27/10 11:35 AM
Houston, Tx
Houston, Tx
Buy another AMD support and a Lenco Spot Welder? That's about a $1000 investment........ Or, are you referring to a Lincoln Spot welder? Either way, I'll do the plug welding method and smooth out the excess on the flat part of the support panel and leave the dimple.
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883519
12/27/10 11:53 AM
12/27/10 11:53 AM
chargervert Offline
chargervert  Offline
Troy,It's just a lower core support,not the Mona Lisa. It's not a hack job to use a small amount of filler to dress the plug welds,after grinding them,and dimple them with a pencil eraser to have the correct appearance. This isn't rocket science,like some here would like you to believe. The plug welds will be plenty strong enough.
Re: My '69 C500, replacement of the lower core support... [Re: chargervert] #883520
12/27/10 04:29 PM
12/27/10 04:29 PM
sixbbl69 Offline
sixbbl69  Offline
don't do it right.just throw it together that seems to be the norm.all you need is a degree in body work.
Re: My '69 C500, replacement of the lower core support... [Re: sixbbl69] #883521
12/27/10 04:55 PM
12/27/10 04:55 PM
chargervert Offline
chargervert  Offline
I have built two Charger convertibles from scratch,and saved a totaled Challenger convertible,that required replacing everything from the tortion bar crossmember forward,plus rear quarter panels,outer wheelwells,trunk extentions,trunk floor,frame rail ends,floor pans,rocker panels,and half the cowl. I'don't do too bad with a welder. The 500 Troy is working on was slated to be one of my projects,until I read Troys wanted add here on Moparts,for a 69 Charger 500.
Re: My '69 C500, replacement of the lower core support... [Re: sixbbl69] #883522
12/27/10 05:06 PM
12/27/10 05:06 PM
Houston, Tx
Houston, Tx
That seems to be the norm? Dude, did you not see the sort of work I did on my '68 Hemi Charger R/T? I'm not trying to create a work to rival Michelangelo. My gut reaction is to not say anything, but that was uncalled for... I don't have a bottomless pit of cash.. I'm happy to "just" save it and have fun. Guess my "Joe Dirt" look it'll have for a while won't live up to your standards or approval.
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883523
12/27/10 05:22 PM
12/27/10 05:22 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
sixbarrel is just
Re: My '69 C500, replacement of the lower core support... [Re: JohnRR] #883524
12/27/10 05:33 PM
12/27/10 05:33 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
sixbarrel is just ..... AS USUAL!
There.....fixed it!
Re: My '69 C500, replacement of the lower core support... [Re: JDMopar] #883525
12/27/10 07:08 PM
12/27/10 07:08 PM
Houston, Tx
Houston, Tx
There.....fixed it!
Ah.. OK, don't recall his banter in the past... I'll take a little seasoning in the pot that's being stirred then... I'll just jump in my parts-getting-Daytona to retrieve some items I need for the Charger 500..... Ahhhh, such is the life....
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883526
12/31/10 01:52 PM
12/31/10 01:52 PM
Houston, Tx
Houston, Tx
Got the panel in Tuesday with the help of a friend with a MIG welder. Drilled out the holes in the new AMD panel in the same places as the original spot welds. We welded her up, I'll grind down smooth and then either get a round dremel grinding wheel to create the spot weld look or get one of those hand-held spot welder guns. With the panels being in place with good thorough welds, the spot welding gun will give me the dimple I'm looking for. At least, in theory I'm hoping so......
Fit was great........ Thanks AMD..
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883527
12/31/10 01:52 PM
12/31/10 01:52 PM
Houston, Tx
Houston, Tx
Other side.
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883528
12/31/10 01:53 PM
12/31/10 01:53 PM
Houston, Tx
Houston, Tx
Welded up...
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883529
12/31/10 01:53 PM
12/31/10 01:53 PM
Houston, Tx
Houston, Tx
Other side...
Troy
