Re: Anyone actually using a Indy Mod-Man Intake???
[Re: B G Racing]
#882484
12/28/10 02:57 PM
12/28/10 02:57 PM
Posts: 684 COLUMBUS, OH
Whompin_Wedge
COLUMBUS, OH
Strip set up on a 528" Hemi,2 800cfm Edelbrocks,3500#,9.56 at 140+.
Street set up on a 528 Hemi,3700#,10.25 at 130+.
with the mod man intake?
Casey
[Re: quick77rt ]
#882487
12/28/10 04:47 PM
12/28/10 04:47 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
nitrous plates upside down. you will be spraying the nitrous up into the boosters of the carbs
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: quick77rt ]
#882490
12/28/10 06:33 PM
12/28/10 06:33 PM
sixpackgut
Charleston
mine not like that. i dont know if you can turn that elbow. call holley tech line
[Re: sixpackgut]
#882491
12/28/10 06:38 PM
12/28/10 06:38 PM
Posts: 4,702 On the parachute mount
n20mstr
OF COURSE you can turn that elbow....take it out, clean it off. Use a little teflon paste NOT TAPE, then just tighten it to where you need it, if anything thats only 180* less than where it is now. Thats only a 1/8 pipe fitting
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#882492
12/28/10 06:42 PM
12/28/10 06:42 PM
sixpackgut
Charleston
thanks
[Re: sixpackgut]
#882493
12/28/10 06:43 PM
12/28/10 06:43 PM
quick77rt
Parts Problem
Parts Problem
Thanks Ray and Monster ![](/ubbthreads/images/graemlins/thumbs.gif) The heck with the tech line, I started to put a lil twist on it and no problem, the spray bares are threaded and epoxied? in. Thats good I wanted to plumb the noids on the pass side ![](/ubbthreads/images/graemlins/thumbs.gif) I went through some old pics as well I did have it plumbed on the pass side at one time...hmmm. More reason to keep a notebook. Im a bit skiddish on the older plate kits, dont know how they were made.
[Re: quick77rt ]
#882494
12/28/10 09:27 PM
12/28/10 09:27 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Interesting piece. Wonder how it compares with crossrams and other wedge manifolds. Looks like you could have fun on the dyno with different carb and spacer combos.
The little old lady from Pasadena is back!
[Re: quick77rt ]
#882496
12/31/10 11:07 AM
12/31/10 11:07 AM
quick77rt
Parts Problem
Parts Problem
[Re: quick77rt ]
#882499
01/05/11 06:39 PM
01/05/11 06:39 PM
quick77rt
Parts Problem
Parts Problem
[Re: quick77rt ]
#882500
01/05/11 09:03 PM
01/05/11 09:03 PM
sixpackgut
Charleston
why the black? because prostock guys do it?
[Re: sixpackgut]
#882501
01/05/11 09:06 PM
01/05/11 09:06 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
That fogger may not work well. That is a 90* nozzle and you have it plumbed standing nearly straight up, like an Annular nozzle. It will be spraying right at the roof of the intake runner looks like. You need to spray it off the engine and make sure the pattern looks decent
Monte
