Page 2 of 4 1 2 3 4
Re: R bias ply tires really that bad to drive your Mopar on [Re: A12] #881171
12/16/10 01:03 AM
12/16/10 01:03 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The difference in how my A12 RR drove w/ the bias-ply G70-15s and the Coker 225/75R15 redline radials was pretty significant. Loved the look of the bias-plies, but the car's handling does take a back seat to appearance when you hang a 40-year old tire design on it.
Re: R bias ply tires really that bad to drive your Mopar on [Re: BradH] #881172
12/16/10 05:01 AM
12/16/10 05:01 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Funny to hear some of the comments about the strange/odd/harsh feel of the bias ply tires because I'm old enough to have experienced the "strange, wiggly, soft, squirmy feel" of radials when they first started to become popular in the late '60's-early '70's. The radial tires always looked under inflated and all of the "road feel" went away which at the time was not considered a good thing A lot of drivers didn't like radials at first and if you asked guys what they thought you got almost a reverse of what is written here "you'll lose a lot of road feel and they squirm and........" I guess you could argue about how bad all of the old technology is from not having four wheel independent suspension and not having four wheel disc brakes and no variable ratio power steering and........ I guess if I get a set of bias ply tires and drive on them for a while I can have the wife complain about the terrible harsh ride for a while then put a set of radials on a set of 15" wheels and have the road feel go away and the car squirm and wiggle down the road just like the old days
But these sure look nice IMO
MikeR
Re: R bias ply tires really that bad to drive your Mopar on [Re: A12] #881173
12/16/10 05:06 AM
12/16/10 05:06 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
kind of an OT question but maybe not: could I run a F.A.S.T. or stock class race with a set of G70-14's or would I need to say with the F70-14's?
Re: R bias ply tires really that bad to drive your Mopar on [Re: Golden-Arm] #881174
12/16/10 05:14 AM
12/16/10 05:14 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
nice looking X though!!
THANKS! .. it's a 4-speed with a 3.54 Dana
Re: R bias ply tires really that bad to drive your Mopar on [Re: A12] #881175
12/16/10 08:16 AM
12/16/10 08:16 AM
restos just aren't my thing
gtsuperbee Offline
gtsuperbee  Offline
I'm pretty sure you are allowed one size bigger. I know you can in pure stock. Looks good mike, although more y2 than y4
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Re: R bias ply tires really that bad to drive your Mopar on [Re: A12] #881176
12/16/10 08:31 AM
12/16/10 08:31 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
i think it depends how much your gonna drive the car. if its only a 300 mile a year car then put bias plys on it, if your gonna actually drive the car and put a good amount of miles on it then put a radial on it.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: R bias ply tires really that bad to drive your Mopa [Re: Moparmaniacc] #881177
12/16/10 08:41 AM
12/16/10 08:41 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
What I am waiting for is for someone to reproduce the Goodyears that look exactly "like 1970", but are actually radials.
I agree, seems like the technology to pull it off should exist.
I also like the look of the polyglass tires on a classic car.. Joe
65 Barracuda
70 Challenger
Re: R bias ply tires really that bad to drive your Mopa [Re: jrwoodjoe] #881178
12/16/10 11:35 AM
12/16/10 11:35 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Another thing to consider is how fast your car is. Quick cars are one thing, but these cars weren't called Rapid Transit for nothing. The top end on a car with 3.54 rear end gears at 6500 rpm in 4th is pretty deep into the triple digits. These cars didn't come with 150 mph speedometers for no reason.
Speed ratings are something to consider if you ever want to stretch your Mopars legs as they were designed and intended to be stretched. I wouldn't run less than a V rated tire on mine, and you can always put the period correct tires on for shows. Just drive slow there.
Another option is that you can have a red stripe put on any modern tire.
Re: R bias ply tires really that bad to drive your Mopar on [Re: A12] #881179
12/16/10 11:44 AM
12/16/10 11:44 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yes you can , they allow up to a MAX size of a G70 if the car had 70 series tires and a G60 if the car had a 60 series tire .
I have firestone redlines on the Dart , no issues here and the road around here are bad .
Re: R bias ply tires really that bad to drive your Mopar on [Re: JohnRR] #881180
12/16/10 12:46 PM
12/16/10 12:46 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Another thing to consider is: Put the tire pressure per the decal if you run Bias Ply it makes a big difference. When I had them on my Cuda and GTX 26 psi drive pretty decent but say 30 or 32 psi danced all over. Ron
Re: R bias ply tires really that bad to drive your Mopar on [Re: A12] #881181
12/16/10 12:53 PM
12/16/10 12:53 PM
BradH Offline
BradH  Offline
... I'm old enough to have experienced the "strange, wiggly, soft, squirmy feel" of radials when they first started to become popular in the late '60's-early '70's. The radial tires always looked under inflated and all of the "road feel" went away which at the time was not considered a good thing A lot of drivers didn't like radials at first and if you asked guys what they thought you got almost a reverse of what is written here "you'll lose a lot of road feel and they squirm and...
Same memories here, including a very clear one the first time I drove my '72 'Cuda 340 after having just had radials installed. As soon as I got out of the tire dealer's parking lot and pulled out on Duke Street, it was already apparent those new tires were "different".
I have no problems driving old cars w/ bias-ply tires, but have known the trade-offs (as do you) from having lived with both over the years.
Re: R bias ply tires really that bad to drive your Mopar on [Re: BradH] #881182
12/16/10 01:01 PM
12/16/10 01:01 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Everybody's got the red lines, i think with the color of your car a white line would stand out more.
Re: R bias ply tires really that bad to drive your Mopar on [Re: A12] #881183
12/16/10 01:24 PM
12/16/10 01:24 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
The redlines look better on your car than the RWL.
I wouldn't be afraid to run the repro bias plys. The look outweighs the harshness.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: R bias ply tires really that bad to drive your Mopar on [Re: A12] #881184
12/16/10 01:26 PM
12/16/10 01:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Hope you like to really work the wheel. They will find and follow any grove, bump or crease in the road. If you drive the car alot I'd pass. I had them on a 70 383 4 speed charger, that car was a hand full. Didn't help that is was manual steering and manual brake.
Coming soon!!!!
Re: R bias ply tires really that bad to drive your Mopar on [Re: abodyjoe] #881185
12/16/10 02:46 PM
12/16/10 02:46 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Averaging at least a 100 miles a weekend (sometimes 200+) from late March to late October so at the least 2500+ miles a year but that's if I only do local cruising, the Nat's, Chrysler Classics and a few stock class drag races are within 150 miles and I'd have no hesitation with driving there too.
Re: R bias ply tires really that bad to drive your Mopar on [Re: Mr.Yuck] #881186
12/16/10 02:48 PM
12/16/10 02:48 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
The GTX has power steering and power disc brakes, may not be a big issue???
Re: R bias ply tires really that bad to drive your Mopar on [Re: A12] #881187
12/16/10 03:02 PM
12/16/10 03:02 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive driven on all of them.I started driving in 64 so bias was the only thing out there.I had bias Mickeys on the frt of my 65.Even after I aligned it they were all over the place.Put them on the kids 62 and the same thing.I installed the 165 radials and it was night and day.We rab radials on the 57 62 66 67 and all of my Imps.Bias if you drive maybe 20 miles a week.Rocky
Chrysler Firepower
Re: R bias ply tires really that bad to drive your Mopar on [Re: therocks] #881188
12/16/10 03:34 PM
12/16/10 03:34 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I would drive an hour to the dragstrip on the Firestone G-70-15 bias ply redlines, race it, and drive it home. Some of the more drastic ruts in the road would cause it to wander, but for a 40 year old car, it was manageable. The look of the car with original type tires is well worth the tradeoff in the way the car handles.
Re: R bias ply tires really that bad to drive your Mopar on [Re: A12] #881189
12/16/10 03:46 PM
12/16/10 03:46 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
It's not a huge issue. If it's a "looks" thing than go with what you like. As stated they make radials that look like old bais plys. I would NEVER put a set of NOS...old...used whatever you call t hem bais plys on.
Re: R bias ply tires really that bad to drive your Mopar on [Re: Mr.Yuck] #881190
12/16/10 06:07 PM
12/16/10 06:07 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
I had bias ply tires (stock) on 65 ford back in 1987 my first old car always liked old classic cars and that i know wasn't a mopar but at 16 years old it was what i could afford at the time .
The car has the normal one finger overcompensating power steering that most 60 's cars had .
Let me tell you when i first drove that car on the highway through the one lane concrete lined construction zones at 50 to 60 mph . Man it was defiantly interesting to say the least!
I had to be concentrating so hard an-griping that wheel white knuckle style to keep that thing from grabbing a expansion rut and bouncing off the concrete that it was enough to make you want to fill you shorts if you know what i mean.
I got a set of brand new keystone classic wheels and 235 70 r 15 raised white letter tires from k mart that were radial Generals i thinks was the brand hard to remember but all i can say was i was not scared to drive the car at any speed after the radials installed ! I also remember praying to god when driving down narrow city streets in Chicago hoping not to bounce like a pingpong ball of the parked cars that lined the streets .
1969 Dodge Charger 1969 Dodge Superbee
Page 2 of 4 1 2 3 4
