knocked 43# off my rear end..."update"
#880839
12/15/10 03:10 PM
12/15/10 03:10 PM
dartman366
Mt. Vernon, Ohio
by going from this..
Re: knocked 43# off my rear end...
[Re: Moparnut426]
#880843
12/15/10 03:38 PM
12/15/10 03:38 PM
dartman366
Mt. Vernon, Ohio
Thats awsome!! Im wanting to do the same. I have the set up under the charger, and Im wanting to swap the strange stuff from it to my demon. Will I be able to take the 11 inch drums off my demon, and just swap it out? What about a proportioning valve for the rear disks? Also the charger has 5/8 studs will that be a problem since Im not planning on using them on the demon. Im just taking the charger off the track, and would like the disks on the car I drive the most.
Kasey
If you have the 8.75 or dana 60 then everything bolt's right on, but you have to have the Green bearing's on the axel's and those are included in the kit,, as far as 5/8 stud's the disc's are drilled and slotted for both 5/8 and 1/2,,nice nice stuff. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: sshemi]
#880844
12/15/10 03:47 PM
12/15/10 03:47 PM
dartman366
Mt. Vernon, Ohio
43 lbs thats quite a bit for unsprung weight.
drum and backing plate assembly was 33.5# each side, the disc,caliper and bracket are 12# each side. I figure between this and the front end, I should of knocked a 100#s or so off of the car, I have yet to weighted the front end stuff. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: dartman366]
#880845
12/15/10 03:49 PM
12/15/10 03:49 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
oh my, i have never weighed drum brakes. i didnt think it was that much
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#880847
12/15/10 03:53 PM
12/15/10 03:53 PM
dartman366
Mt. Vernon, Ohio
My drum's were the 2.5X11 off of a C-barge, did a real fine job,,just heavy. ![](/ubbthreads/images/graemlins/biggrin.gif)
