Re: Is a .050" quench height still effective? [Re: 602heavy] #878856
12/13/10 08:36 PM
12/13/10 08:36 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
50 is better than some of the stuff Ma Mopar has come out with .. !!
EVEN the 6 BBL engine .. look at that.
THEN the lowly 400 engine.... as far from GOOD quench as possible.
Re: Is a .050" quench height still effective? [Re: BradH] #878857
12/14/10 12:44 AM
12/14/10 12:44 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I'm seeing a pattern here...
FWIW, the pistons stick out of the deck .002", so quench will be .038" w/ a typical composition gasket.
Maintain your quench and use other methods if need be to lower comp.
Chamfer the bores around the intake valve at the block and the head, if need be.
As far as the effective perimiters of quench,
Is it incremental or is it on/off
KB pistons engineer John Erb implies its off after .060
I think its a little bit of both, But from the words of a old Engine guru,
"If your building from scratch, make maximizing the quench your number One priority toward achieving compression and avoiding Detonation"
mike
