Page 2 of 3 1 2 3
Re: Oil Consumption Culprit Found? [Re: DAMOPARS] #877740
12/12/10 10:29 AM
12/12/10 10:29 AM
I'd suggest a thin/light/even swath of Permatex #1 (in the toothpaste like tube) around each side of the 8 port openings in the valley pan AND b 4 that, mocking it up to see if the port alignment is pretty much spot on & milling the intake if it isn't (plus it straightens the intake face) cause as you know it's along the bottom that the oil is being drawn in. Holler how it turns out. EDIT I agree get a blocked off valley pan & if using his thin gaskets that's an excellent idea to super glue the gaskets in place (not at the port openings as I am not sure superglue is gas resistant) in addition to (imnho) permatex #1 (or your choice of (non rtv) sealer) on the port openings. The MP/felpro paper gaskets I have seen are too poorly cut to suit me and they are thick which is OK if the intake (or head) face is milled so you have good port alignment. #1 port alignment & yes some have used pans dry sucessfully but I dont see the metal ridge being pliable enough to seal 15 in hg esp if both sides ain't milled perfectly flat. If your handy w an exacto knife cut your own and can get em dead nuts perfect.
Re: Oil Consumption Culprit Found? [Re: DaytonaTurbo] #877741
12/12/10 10:42 AM
12/12/10 10:42 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I had good luck with using no extra gaskets or sealer on the valley pan. I just shot both sides with several good coats of the permatex copper spray, did the rtv on the pan rails. Also had to use permatex thread sealer on the intake manifold bolts because a lot of oil was getting sucked up the threads.
That is all I did, that "orange" is RTV not paint in the pics above, bad choice.
Don't be the exception.
Re: Oil Consumption Culprit Found? [Re: topside] #877742
12/12/10 10:58 AM
12/12/10 10:58 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
We sell paper gaskets for the pan, only .015 thick so they don't jack up the intake. Glue them to the pan and no air/oil leaks. Thinnest ones on the market, had them made to avoid the jack-up problem with everyone else's gaskets.
Price? How to order?
Re: Oil Consumption Culprit Found? [Re: DAMOPARS] #877743
12/12/10 11:21 AM
12/12/10 11:21 AM
Out in Left Field, NY
bobs66440 Offline OP
Looks like oil around the bolt holes.
Yeah, I'm definitely going to use thread sealer. When it was together and running there was oil running up one of the bolts and making a puddle in the intake. You can see it here...
Re: Oil Consumption Culprit Found? [Re: bobs66440] #877744
12/12/10 11:56 AM
12/12/10 11:56 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Of course, the bolts/bolt holes have nothing to do with your real problem.
When you get everything cleaned up, do a fit test setting the intake on the heads, finger tightening the four corner bolts and checking gap size between the head and intake with a feeler gauge. Report back what you find. I frequently see intakes that leak, but yours looks pretty bad.
If you want to keep the dual quad set-up, you may want to consider getting the Eddy CH28 and enjoy a performance bump too.
Re: Oil Consumption Culprit Found? [Re: bobs66440] #877745
12/12/10 12:20 PM
12/12/10 12:20 PM
scratchnfotraction Offline
on the thin gaskets..how much? where to order?
I am waiting on a felpro pan with heat blocked off,was told to just use the copper spray and pan only for a BB intake swap
have also been told just the pan dry will be fine,and is reusable as long as I keep the same intake..
kinda interested in this,I dont want the same trouble with it sucking oil
Re: Oil Consumption Culprit Found? [Re: topside] #877746
12/12/10 12:33 PM
12/12/10 12:33 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I am also interested in where I can purchase these thin gaskets.
This is the land of the free because of the brave
Re: Oil Consumption Culprit Found? [Re: scratchnfotraction] #877747
12/12/10 12:37 PM
12/12/10 12:37 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
I've used the compression gaskets before and like them. I use Gasgacinch (http://www.summitracing.com/parts/EDL-9300/) on anything that will see oil or gas. It is cheap, works well, and is still legal in 49 states or so.
Re: Oil Consumption Culprit Found? [Re: DaytonaTurbo] #877748
12/12/10 12:48 PM
12/12/10 12:48 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Done it this way for 35 years. Never a problem. I use HiTack aircraft sealer on all my wet bolts.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Oil Consumption Culprit Found? [Re: Pacnorthcuda] #877749
12/12/10 12:48 PM
12/12/10 12:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
1qt/200 miles is a Lot of oil to suck buy the pan but I suppose its possible. Others disagree but I prefer to use the composition gaskets on both sides of the valley pan. I even superglue them to the pan the day before install--very anal about it, I create wood plates to clamp both sides.
What ever you do dont use RTV around the intake runners--RTV is not gasoline resistant.
You may have more than one source of oil loss.
I would say that is where most of the oil is getting in there. I like to use at least one gasket , and have a little machined off the intake , the composition gasket are .030 thick EACH .
Re: Oil Consumption Culprit Found? [Re: JohnRR] #877750
12/12/10 01:31 PM
12/12/10 01:31 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I sent PMs to the guys that asked about the .015 gaskets, but if anyone else is interested send me a PM or email me directly at topside340@yahoo.com. We're also on Ebay, seller name topside340, same as our tools.
Made them for exactly this kind of deal, seal it for sure when you assemble it and no worries.
Re: Oil Consumption Culprit Found? [Re: JohnRR] #877751
12/12/10 02:04 PM
12/12/10 02:04 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
this is the best solution, it's a pain in the butt finding a good machine shop that can take 0.025" or 0.030" off each side but then you can add a gasket to the valley pan without messing up the alignment of the ports and creating this aggravating problem. anyone know if other v8's have this problem or is it just mopar big blocks? why is it so common with our engines?
Re: Oil Consumption Culprit Found? [Re: topside] #877752
12/12/10 02:08 PM
12/12/10 02:08 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I always keep a couple sets of both the .015" and .030" around. I have mixed them for .045".
http://cgi.ebay.com/ebaymotors/361-440-M...=item255f8949e2
Re: Oil Consumption Culprit Found? [Re: BSB67] #877753
12/12/10 03:08 PM
12/12/10 03:08 PM
I test fit the intake with two of the .030 gaskets on each side(but without the pan because I don't have one yet...picking it up later) and I could run all the bolts in with no problem. It may be a little tight with the pan, but as it is now I can still move the intake up and down a little (maybe .040-.050) with all the bolts threaded in.
Re: Oil Consumption Culprit Found? [Re: bobs66440] #877754
12/12/10 03:53 PM
12/12/10 03:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Well now you know why it's leaking , you shouldn't be able to do that with that much gasket in there , clean it up , all 4 gaskets and the pan and you should be good to go, clean out as much of the oil as possible, intake valves closed of course.
Re: Oil Consumption Culprit Found? [Re: JohnRR] #877755
12/12/10 04:04 PM
12/12/10 04:04 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Sounds like the bolts might have been holding the intake off of the head
Re: Oil Consumption Culprit Found? [Re: bobs66440] #877756
12/12/10 04:09 PM
12/12/10 04:09 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The sealer probally dried and cracked.Thats why I always install my pan dry.Ive run them like that for 40 years and never had any leaks.I even run aluminum intake steel heads and aluminum heads and intake that way.As long as the heads and intake are clean and flat they seal.Back in the 60s we reused the pans all the time.They were expensive then at like 25 bucks a pop.Just some silicone at the 4 corners and under the hold downs.Rocky
Chrysler Firepower
Re: Oil Consumption Culprit Found? [Re: BSB67] #877757
12/12/10 04:20 PM
12/12/10 04:20 PM
Aha, yes. That makes sense because I put the intake on without the gaskets and looked in the bolt holes and they didn't line up.
Re: Oil Consumption Culprit Found? [Re: bobs66440] #877758
12/12/10 06:25 PM
12/12/10 06:25 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
Quote: Do you guys think that this could be responsible for that much oil usage? This is the last thing to try before going the rebuild route, which I hate to do because it runs so good...I don't want to open a can of worms (and my wallet).
Not to be a wise a$$ but you've already opened a can of worms. You know where this is giong from this piont, just save yourself the grief of tearing it down in the car, pull it, inspect everything and when you find out how worn it really is, rebuild it. Hey, its winter, what else do you have to do? I'll be tearing down another one myself in a few weeks.
Re: Oil Consumption Culprit Found? [Re: dirtybee] #877759
12/12/10 06:40 PM
12/12/10 06:40 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
It's simple math. Angles change as blocks are decked,heads are milled and who knows if someone didn't already cut the intake...
Page 2 of 3 1 2 3
