Re: Help me get this header bolt out! [Re: Ron_M] #877559
12/12/10 11:22 AM
12/12/10 11:22 AM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
Think I'm gonna buy a cheapie 12 point box and grind it down
x 100 ....I did that years ago for ... headers and one style of an intake manifold.
Re: Help me get this header bolt out! [Re: FuryUs] #877560
12/12/10 01:18 PM
12/12/10 01:18 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
I'm not Rocky, but yes the header bolts enter the water jacket.
...As in ALL of them !!! ...And{I'm not Rocky either but} I try to use header studs every time I can...That avoids a big hassle...Some say to use RVT sealer on the bolts but if you need to keep tightening them during the initial mating process then they'll leak anyhow..
Re: Help me get this header bolt out! [Re: Ron_M] #877561
12/12/10 01:52 PM
12/12/10 01:52 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
Here is my thoughts on this FUBAR; use a 6 point box, ground down thin enough to fit; a 12 point will slip/strip on the hex. PB blaster, a pin punch and a hammer hit the flats of the bolt you can see/get to, the action will wiggle the bolt back and forth, breaking the rust bond, PB blaster some more, try the wrench. You don't have hit the punch with a kill shot, just a solid bump.
Good luck.
Re: Help me get this header bolt out! [Re: JBurch] #877562
12/12/10 02:37 PM
12/12/10 02:37 PM
northeast pa
3wracing Offline
3wracing  Offline
northeast pa
What about putting the other header bolts back in and running the motor to get some heat in it then try and get the bolt out . Ive had this work in the past . Working with the hot header isnt the greatest buuuut if it works
Re: Help me get this header bolt out! [Re: Ron_M] #877563
12/12/10 02:40 PM
12/12/10 02:40 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Yes on saving the headers (I need the $$ to rebuild the engine) and I am afraid if I keep nailing that tube, I'll breach it but that is a suggestion I'll keep in mind and might even go try. Thanks!
If you breach the tube you can weld it back up afterwards , getting a box wrench on there is your best bet .
Re: Help me get this header bolt out! [Re: StukaJU87] #877564
12/12/10 02:42 PM
12/12/10 02:42 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Thats why I always antisieze my bolts.Rocky
Rocky, can you settle a question for me once and for all please as I will be installing headers on a fresh 440 in the near future?
Do any of the exhaust bolts on stock heads go through to the water jacket? I have heard some say yes and some say no.
If the answer is "yes", how would never sieze keep it from leaking?
Do yourself huge favor and leave in as many studs , all on at least the drivers side , as you can , draining the cooling system to change a gasket or a starter bites .
And as said they are ALL wet .
Re: Help me get this header bolt out! [Re: Ron_M] #877565
12/12/10 02:54 PM
12/12/10 02:54 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It's the second bolt-stud back on each side of engine that the stud won't work on on many mfg headers. The rest get studs in most cases.
Re: Help me get this header bolt out! [Re: buildanother] #877566
12/12/10 02:59 PM
12/12/10 02:59 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
If you're good you can get a stud in there .
Re: Help me get this header bolt out! [Re: JohnRR] #877567
12/12/10 03:03 PM
12/12/10 03:03 PM
Do yourself a huge favor and leave in as many studs
yes the shouldered OE type studs seal the best & I trim the outer fine threaded portion so there's only enough threads left to fit flush when a thin high quality nut is installed. Any more than that is a waste & hampers header fitment. Mock it up/remove/shorten/reinstall(w appropriate sealer on the coarse threads)then install the headers. As said all wet on BB (stock heads),maybe diff on aftermarket and corners (4) wet on a SB
Re: Help me get this header bolt out! [Re: RapidRobert] #877568
12/12/10 03:48 PM
12/12/10 03:48 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I have plenty of brand new grade 8 studs. Never thought of shortening the ones that are too long for the header tubes. Thanks for the tip!
Scott
1969 Super Bee, 383/4 speed
Re: Help me get this header bolt out! [Re: StukaJU87] #877569
12/12/10 09:46 PM
12/12/10 09:46 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
sharp chisel and spin it...
Re: Help me get this header bolt out! [Re: buildanother] #877570
12/12/10 09:55 PM
12/12/10 09:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
used every mani stud on these Summit headers and the last set of headmans I had. work like a dream.
Re: Help me get this header bolt out! [Re: Mr.Yuck] #877571
12/12/10 10:00 PM
12/12/10 10:00 PM
chicagoland,usa
chicagoland,usa
I was kindof referring to some hooker and tti headers.
Re: Help me get this header bolt out! [Re: buildanother] #877572
12/12/10 10:01 PM
12/12/10 10:01 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
expensive an OVER-RATED. I do have a nice set of Hooker Super Comps in the garage thou....
Re: Help me get this header bolt out! [Re: Mr.Yuck] #877573
12/12/10 11:07 PM
12/12/10 11:07 PM
5205's or 5215's
Re: Help me get this header bolt out! [Re: FuryUs] #877574
12/13/10 07:31 AM
12/13/10 07:31 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
When I ran all bolts on my headers I used silver antisieze.I run it on all 6 vehicles that and do have headers.Ive never had a leak.I run studs on my 440 now except for 2 that have to be bolts.My kids 413 has been together for 8 years with headers and bolts.Never leaks a drop and the bolts come right out.Ive also ran the same on 5 small blocks.Rocky
Chrysler Firepower
Re: Help me get this header bolt out! [Re: therocks] #877575
12/13/10 11:10 AM
12/13/10 11:10 AM
GA
Boosted Offline
Boosted  Offline
GA
I have Hooker Headers on my car that are old Superstock Headers.. 2" tubes to 3 1/2" collecters. I have studs in every hole on them. I did use some of th eMr. gasket 3514 studs though in the tight areas,, I used thread sealer on all the studs in the heads... I am running aluminum heads and did not want bolts to take in and out as we all know what happes to threads in aluminum heads when useing them to much..
Idid have to hang the header on the studs, start that nut and work my way in with them.. Starter goes on and off without removing the headers...
Good luck with those... I prefer studs as they make it a bit easier to put the headers on as they will hold the studs..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Help me get this header bolt out! [Re: RapidRobert] #877576
12/13/10 12:27 PM
12/13/10 12:27 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
5205's or 5215's
not sure I got them from a budy for $125. was going to use them w/ the new motor but I would of had to do some exhaust work, the old ones have a evac system and they were TIGHT. So I left the Summit's on.
Coming soon!!!!
