Re: Help me get this header bolt out!
[Re: Ron_M]
#877540
12/11/10 04:18 PM
12/11/10 04:18 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Are you trying to save those headers? If not, hacksaw, chisel or dent that thing out of the way.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: HemiStan]
#877542
12/11/10 04:24 PM
12/11/10 04:24 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
Yes on saving the headers (I need the $$ to rebuild the engine) and I am afraid if I keep nailing that tube, I'll breach it but that is a suggestion I'll keep in mind and might even go try. Thanks!
Common sense is a flower that does not grow in everybody's garden
[Re: jbc426]
#877543
12/11/10 04:26 PM
12/11/10 04:26 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Use a 6 point box if you can get it in.I have some that are thinner than regular wrenches.That or try a 14 MM wrench.Its a bit smaller than what looks like a 9/16 head on that bolt.If you have a propane torch heat the bolt real good and melt some wax in there.Thats why I always antisieze my bolts.Rocky
Chrysler Firepower
[Re: jbc426]
#877544
12/11/10 04:26 PM
12/11/10 04:26 PM
Posts: 892 Illinois
StrkrDart69
Illinois
Cut the headers out with a sawzall. With a long blade you should be able to get in close to the flange. Then try a 6 point box wrench and heat.
[Re: Ron_M]
#877545
12/11/10 04:29 PM
12/11/10 04:29 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
Beefy-quality open end wrench. If that don't work, try sneaking a 12 point thin walled box wrench on it. It that don't work, just knock it around with a nice bity chisel. I think many here have a drawer full of stuff, stuff like random silly header bolts, that could be spared for you when you trash that one.
[Re: buildanother]
#877546
12/11/10 05:31 PM
12/11/10 05:31 PM
Posts: 4,848 Memphis
HemiRick
Memphis
This is why you use header bolts....The one you are trying to remove is a regular bolt....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: 440challenger]
#877550
12/11/10 09:05 PM
12/11/10 09:05 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
propane torch, pb blast and a real good VICE grip and keep working it back and fourth
mapp gas might even be better. Burns much hotter with the oxygen. Next time maybe header bolts and anti seize.
[Re: bboogieart]
#877551
12/11/10 09:32 PM
12/11/10 09:32 PM
Ron_M
Connecticut
Thanks all for the advice.
FWIW, I didn't bolt this thing together and I am learning the hard (and most likely expensive) way. Again. LOL!
Think I'm gonna buy a cheapie 12 point box and grind it down and use a propane torch. If that fails, I'll cut it with the grinder.
[Re: Ron_M]
#877553
12/11/10 09:57 PM
12/11/10 09:57 PM
Posts: 1,805 ky hills
thehemikid
ky hills
...Try your best to break it loose with a 6 point. A 12 point will come in handy after its broke loose. If the corners are rounding you might use a 6 point like this instead. It uses the sides more than the corners.
[Re: Ron_M]
#877554
12/12/10 02:49 AM
12/12/10 02:49 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
A couple of last options, Make a nice clean cut on the header tube then take it to a muffler shop and have it repaired. Sawsall / grind the bolt head off. Leave it on the head, remove the head and unscrew the head from the pipe after it is off.
[Re: sthemi]
#877555
12/12/10 02:56 AM
12/12/10 02:56 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
As hammered as that tube already is I agree cut the tube & have it repaired...
