Re: 360 Stroker Kit, which one to use? [Re: Suregrip] #877008
12/11/10 11:17 PM
12/11/10 11:17 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
So I could use my stock 360 balancer with the 1-98113 kit? But the other kit 1-98113BI would need a neutral balancer? I am getting this right?
NO
Re: 360 Stroker Kit, which one to use? [Re: AndyF] #877009
12/12/10 01:54 AM
12/12/10 01:54 AM
Az
Crizila Offline
Crizila  Offline
Az
Call the guys at Hughes Engines and they'll set you up with what you need. I worked with them on the 427 inch small block that I built last year.
and go internal balance. Using your old external balancer is a bad idea, even if ( what you can see of it ) looks alright. It will give you more options as far as flex plates and convertors also.
Fastest 300
Re: 360 Stroker Kit, which one to use? [Re: Crizila] #877010
12/13/10 09:51 AM
12/13/10 09:51 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
cam, I'd use a lunati voodoo 60403 cam
I'd go KB dished pistons, SCAT cast crank, and either redone stock rods or SCAT I-beams.
I'd just have the rotating assy balanced locally. if it needs any mallory metal to internal balance, go external to 360 specs. I'd probably buy a new stock balancer.
for heads, if you wanted a little more giddyup, I'd get some magnum heads, probably these from hughes engines
2017 Grand Cherokee Overland
Re: 360 Stroker Kit, which one to use? [Re: patrick] #877011
12/15/10 08:13 AM
12/15/10 08:13 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I have those on my Duster, great value and work like a charm. For the larger motor I'd pop for the 2.02 intake version though.
