Re: Hood scoops/cold air induction solutions............... [Re: ProSport] #875006
12/09/10 01:10 AM
12/09/10 01:10 AM
Locomotion Online content
Locomotion  Online Content
Scoop/pan design, air pressure and flow do weird things. A friend had a '65 Satellite with a carb pan sealed '65 scoop on it. Car had some inconsistency issues and threw a real curve ball once in a while. He cut away some of the seal, made vents, and the car was a lot more consistent. Can't recall if it picked up also.
Re: Hood scoops/cold air induction solutions............... [Re: dannysbee] #875007
12/09/10 10:24 AM
12/09/10 10:24 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
This is a nice set up for a cowl hood. Sealed cool air from grille area and hot air from engine exits cowl. I like it.
mine won't look that nice but it will be sealed to the hood. An probably won't be a "ram-air" type.
Re: Hood scoops/cold air induction solutions............... [Re: Locomotion] #875008
12/10/10 02:10 AM
12/10/10 02:10 AM
State of confusion
Thumperdart Offline OP
State of confusion
That`s my point.........lots of fuel splash on carb top and although it does respond to jetting, 98`s in the rear and 84`s up ft. w/a pv seems excessive to me AND others. After talking w/Mike we thaught it would be good to even extend what I have now and see if the wide band responds. I also thaught about drilling holes in the back of the scoop to release air.......something just don`t seem right and your buddy proved it by venting his. Thankxxxx guy`s.
Re: Hood scoops/cold air induction solutions............... [Re: Thumperdart] #875009
12/10/10 02:58 AM
12/10/10 02:58 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
unseal your carb from the hood and put a plug in your scoop
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Hood scoops/cold air induction solutions............... [Re: Thumperdart] #875010
12/10/10 03:52 AM
12/10/10 03:52 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Maybe its your air filter sticking up into the scoop and directly into the incoming air, creating a siphon on the bowl vents, maybe try a half round deflector on the front part of the air filter
Re: Hood scoops/cold air induction solutions............... [Re: Thumperdart] #875011
12/10/10 05:12 AM
12/10/10 05:12 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
what carb are you running & any chance you could post a pic of your set up with the filter top removed?
Re: Hood scoops/cold air induction solutions............... [Re: Mr.Yuck] #875012
12/10/10 10:52 AM
12/10/10 10:52 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
My set-up with cowl hood. I can run a 16" K&N air filter with it.
If you like drag racing, support your local track.
Re: Hood scoops/cold air induction solutions............... [Re: CHAPPER] #875013
12/10/10 11:30 AM
12/10/10 11:30 AM
ohio
all spooled up Offline
ohio
you ever run with it off and did it lose et
Re: Hood scoops/cold air induction solutions............... [Re: all spooled up] #875014
12/10/10 11:44 AM
12/10/10 11:44 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I have never ran it without an air filter, will try next spring.
Re: Hood scoops/cold air induction solutions............... [Re: ademon] #875015
12/10/10 01:45 PM
12/10/10 01:45 PM
State of confusion
State of confusion
I could try that and see what`s up I guess.............rebel, I`ll have my friend shoot a couple of photos and see if I can post em. Thankxx guys............if I can make this set-up work that would be ideal.
Re: Hood scoops/cold air induction solutions............... [Re: rebel] #875016
12/10/10 01:49 PM
12/10/10 01:49 PM
State of confusion
State of confusion
I`m running a single 8082-3 hp 1050 dominator.............
Re: Hood scoops/cold air induction solutions............... [Re: Locomotion] #875017
12/10/10 02:28 PM
12/10/10 02:28 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I remember speaking to John Bauman when he was the one doing the testing on the snorkel. Chrysler was very specific
as where to place the carbs in relationship to the scoop in differet areas. Much had to do with maintaining fuel flow as well as ram air
home of the
Sox and Martin Hemi Duster
Re: Hood scoops/cold air induction solutions............... [Re: HEMIFRED] #875018
12/10/10 06:55 PM
12/10/10 06:55 PM
State of confusion
State of confusion
I`ve always liked those scoops but not sure about the law in terms of blocking my vision....
Re: Hood scoops/cold air induction solutions............... [Re: Thumperdart] #875019
12/10/10 07:24 PM
12/10/10 07:24 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
I'll add this. I make alot of lexan boxes for hood scoops and we just cut a square hole in the cowl hood and let the lexan box hang out. prob 5 yrs ago when we made the 1st one it was sealed off on 5 sides front only open obviously. you could make a pass and I could see gas like it was floating/pulling out of the carb floating in the box abouve the carb. Drilled 4- 1/2 inch holes in the back of the scoop. Never done it again. don't ask me why. Just my experience.
One day I will have something cool here.
Re: Hood scoops/cold air induction solutions............... [Re: sdaurity] #875020
12/11/10 03:49 PM
12/11/10 03:49 PM
State of confusion
State of confusion
I to have seen this even w/lexan grill block-off`s where the holes released unwanted air/pressure and the cars picked up. As mentioned, maybe I should "unseal" it from the hood and try that but I`d swear it is quicker sealed.
Re: Hood scoops/cold air induction solutions............... [Re: Thumperdart] #875021
12/11/10 07:00 PM
12/11/10 07:00 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Try a 12 inch long piece of duct tape on the front of the k&n facing forward and a k&n filter top
Re: Hood scoops/cold air induction solutions............... [Re: emarine01] #875022
12/11/10 09:27 PM
12/11/10 09:27 PM
State of confusion
State of confusion
That`s what someone else recommended and it`s on my list of "to do`s" as soon as I finish up my car work along w/installing a new polished cell my friend bought me for christmas. I thaught about doing what LabRatt did w/the k&n lid receiving air THROUGH the top of my scoop but once I do that, I`m committed.............
Re: Hood scoops/cold air induction solutions............... [Re: Thumperdart] #875023
12/12/10 02:24 AM
12/12/10 02:24 AM
Aubrey, Texas
O
oldtimer5151 Offline
O
Aubrey, Texas
You are getting a lot of air turbulence at the top opening of the scoop. The carb will not function in all that pressure and turbulent air. The air must enter the carb as smooth and straight as possible to properly mix the gas and air. There is a lot of turbulent air coming off the hood and into the large open scoop. If you cannot use a taller scoop, then the the "thunder bolt" air intake system should work. Just my 2 cents.
Re: Hood scoops/cold air induction solutions............... [Re: Thumperdart] #875024
12/12/10 09:28 AM
12/12/10 09:28 AM
N.E. Ohio
OhioGTX Offline
OhioGTX  Offline
N.E. Ohio
Not sure if thjis will help, but I have experienced similar issues and found that a stub-stack solved the problem. We basically determined that different signals were being given to the carb at the bleeds due to whatever was happeing with the air in that compressed space at speed..the snub stack helped quite a bit...as a note we experienced this when the carbs were very close to the scoop...worst case it is a cheap experiment..as an alternative, open the back of the scoop ( drill holes / rais rear of hood etc.) allowing for a clean flow of air over the carb...maybe due both...
68 GTX, 9.38 at 144, Best Machine 540..
