pinion angle #873997
12/07/10 10:55 PM
12/07/10 10:55 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
is this the best way
WAXER
Re: pinion angle [Re: QWK_ENUF] #873998
12/07/10 10:57 PM
12/07/10 10:57 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
no this is
Mopar Performance
Re: pinion angle [Re: QWK_ENUF] #873999
12/07/10 11:03 PM
12/07/10 11:03 PM
Cab_Burge Online work
Cab_Burge  Online Work
It seems to me that your showing two different angles, the transmission output shaft and front U joint and drive shaft angle and then the drive shaft and pinion shaft angles in the same diaghram This seems to be brought up on here regularly, confusing many newbies that are searching for knowledge Both angles need to be check and corrected as needed, there not one and the same
Re: pinion angle [Re: Cab_Burge] #874000
12/07/10 11:07 PM
12/07/10 11:07 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
i'm just pokin old quickttree
WAXER
Re: pinion angle [Re: QWK_ENUF] #874001
12/08/10 07:12 AM
12/08/10 07:12 AM
Q
Quicktree Offline
Quicktree  Offline
Q
only for people who are capeable of understanding it
Re: pinion angle [Re: QWK_ENUF] #874002
12/08/10 08:09 AM
12/08/10 08:09 AM
gregsdart Offline
gregsdart  Offline
OK, you guys have been around long enough it looks like yer pitchen a rock into a hornets nest
Re: pinion angle [Re: gregsdart] #874003
12/08/10 01:37 PM
12/08/10 01:37 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what else s here to do this time of the year for you guys
Re: pinion angle [Re: QWK_ENUF] #874004
12/08/10 01:53 PM
12/08/10 01:53 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Technical drawings of this quality are rarely seen outside of design centers and manufacturing facilities.
It is all so clear now.
Re: pinion angle [Re: tubtar] #874005
12/08/10 04:28 PM
12/08/10 04:28 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
nice motor plate whos and where if you dont mind thanks mike
Re: pinion angle [Re: earthmover] #874006
12/08/10 04:46 PM
12/08/10 04:46 PM
Super Scamp Offline
Super Scamp  Offline
Is this a Quick Tree design. Drawing on the card board box?
Just One Man's Opinion Mopar Mafia Racing
Re: pinion angle [Re: Super Scamp] #874007
12/08/10 04:48 PM
12/08/10 04:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yes
Re: pinion angle [Re: Quicktree] #874008
12/09/10 01:34 AM
12/09/10 01:34 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
yes
Its as simple as that
Even a Caveman could understand it.
I have to admit, Before I saw this post. I never even heard about Pinion angle.
Tonys drawing made it the simplest to understand
Thankyou Quicktree!!
