Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: '72CudaRacer] #872703
12/06/10 08:16 PM
12/06/10 08:16 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Mark williams calls their set "Drive Lugs" I think. I think the part # for strange's sleeves is A-1011 or something close to that. You also need a little sleeve installer, but it comes with the sleeves.
Brian Dunnigan
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: '72CudaRacer] #872704
12/06/10 11:55 PM
12/06/10 11:55 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Strange carries the old style "traditional" 5/8" stud with the screw-on sleeve or several different new style stud packages with the 11/16" diameter shank in the center.
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: Mopar_Mike] #872705
12/07/10 12:06 AM
12/07/10 12:06 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Does anyone make an open end 5/8 stud lug for Weld Pro Star wheels?
If you bought the moroso or Comp engineering kit then they should of came with the nut's and aluminum spacers.
I did not buy the kit, the studs came on the axles I bought. Is that how the 5/8th work tho? There is an aluminum spacer that fits on the stud, inside the wheel and then a small acorn lug nut? I have seen those with some kits.
No! the aluminum spacer goes on the outside of the wheel so the lug nut doesn't dig into the rim.
Re: 5/8 Stud Lugs for Weld Pro Star Rims anyone? [Re: '72CudaRacer] #872706
12/07/10 09:55 AM
12/07/10 09:55 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
Thanks Brian,
I am going to call Strange today and figure it out.
RS23L7 4-Speed
