Page 2 of 3 1 2 3
Re: '69 Satellite Wagon Project [Re: StukaJU87] #871573
12/24/10 12:44 AM
12/24/10 12:44 AM
Northern NJ
StukaJU87 Offline OP
Northern NJ
The old (383) and the new ('68 440) sitting in the shop.
I was alone so I had to drag the 440 about 10 feet to the chain hoist so I could get the stand off it and get it set on a pallet with blocks under the motor. I left the chain hoist hooked up with just enough tension on it to make me feel safe.
Here is the motor, Hughes converter and blue 727. Address any complaints about the blue trans to Pete Tritak. He did it and who was I to argue?
Did the old converter trick with the wrench. Worked like a charm.
Working by myself I was able to get it all settled in rather easilly.
Scott
1969 Super Bee, 383/4 speed
Re: '69 Satellite Wagon Project [Re: StukaJU87] #871574
12/24/10 01:00 AM
12/24/10 01:00 AM
Northern NJ
Northern NJ
I also installed the oil pressure sender for the idiot light. Installed the DB Electrical mini-starter. Put new grade 8 exhaust studs in for the headers and mocked them up. New motor mounts with the old mount brackets off the 383 since they were real nice.
I also took out the remaining heater fitting using the bolt and mongo pipe wrech method.
I replaced the heater fittings with plugs.
Scott
Re: '69 Satellite Wagon Project [Re: StukaJU87] #871575
12/24/10 02:46 AM
12/24/10 02:46 AM
The orange and blue look good.
Re: '69 Satellite Wagon Project [Re: ] #871576
12/25/10 01:37 AM
12/25/10 01:37 AM
jersey
Spaceman Spiff Offline
jersey
Are those the headman shorty headers?
What part of north jersey are you from, i'm in Essex county.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: '69 Satellite Wagon Project [Re: Spaceman Spiff] #871577
12/26/10 12:16 AM
12/26/10 12:16 AM
Northern NJ
Northern NJ
Yup, Hedman shorties, coated by HyperCoat.
I am in Bergen County.
Scott
Re: '69 Satellite Wagon Project [Re: StukaJU87] #871578
12/26/10 01:30 PM
12/26/10 01:30 PM
Winchester, In
tippytoe Offline
tippytoe  Offline
Winchester, In
Cool project ! Keep us updated with progress & pics ! Love the B-body wagons !!!
Re: '69 Satellite Wagon Project [Re: tippytoe] #871579
12/26/10 07:59 PM
12/26/10 07:59 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Makes me miss my wagons..
Re: '69 Satellite Wagon Project [Re: Dos Snails] #871580
01/14/11 10:36 AM
01/14/11 10:36 AM
Northern NJ
Northern NJ
Getting it wrapped up for engine bay paint. It ain't no resto so we are going medieval.
And the Milodon dipstick works perfectly with the shorty headers.
Scott
Re: '69 Satellite Wagon Project [Re: StukaJU87] #871581
01/14/11 10:02 PM
01/14/11 10:02 PM
Northern NJ
Northern NJ
So today, I got the engine bay primed. That cheap a$$ Harbor Freight gun shot the primer perfect.
That piece of crap gave us hell with the color though. LOL It came out pretty good to me. I know it is not perfect, but I was not going for perfection. Just a decent looking engine compartment.
Scott
Re: '69 Satellite Wagon Project [Re: StukaJU87] #871582
01/14/11 10:27 PM
01/14/11 10:27 PM
new jersey
copper74 Offline
copper74  Offline
new jersey
car looks awesome!!!!
Re: '69 Satellite Wagon Project [Re: copper74] #871583
01/14/11 10:29 PM
01/14/11 10:29 PM
Northern NJ
Northern NJ
Thanks, Mike. It's coming along. I'll start putting it back together on Monday.
Scott
Re: '69 Satellite Wagon Project [Re: StukaJU87] #871584
01/22/11 12:30 AM
01/22/11 12:30 AM
new jersey
copper74 Offline
copper74  Offline
new jersey
scott-any chance you may need a quart of sassy grass base coat clearcoat? i have a brand new quart i am getting rid of. let me know. mike lundin12@comcast.net
Re: '69 Satellite Wagon Project [Re: copper74] #871585
01/25/11 09:08 PM
01/25/11 09:08 PM
Northern NJ
Northern NJ
Mike, it may be a long time til it gets the rest of the body painted. I only did the engine compartment so I could get the new engine in there and not have to take it back out. Thanks though.
I took off the tape and started putting some stuff back on. I cleaned up the wiper motor but it is just for show. The damn casing on the wires is all dry rotted and broken. One wire is totally bare.
Anyhow, that is just in there until I can get a decent looking replacement. There is paint on the small brake lines but I don't really care since it will never be "show car quality" .
One side of the wire looms is not seated so I can still get the battery wire in there.
Scott
Re: '69 Satellite Wagon Project [Re: StukaJU87] #871586
01/26/11 07:51 AM
01/26/11 07:51 AM
new jersey
copper74 Offline
copper74  Offline
new jersey
still looks good. i have a box full of wiper motors. you are more than welcome to come and see if you can use any of them. i am certain a few of them were from 68-69 b-bodies.
Re: '69 Satellite Wagon Project [Re: copper74] #871587
01/27/11 11:21 PM
01/27/11 11:21 PM
Northern NJ
Northern NJ
Thanks, Mike. When the weather breaks I will take a ride down and bs for a while.
Got a lot done today. Got the voltage regulator, ballst and ecu bolted in.
Got the ground for fule guage in.
Got the motor and trans rigged up with that crappy Harbor Freight engine tilter and a forklift.
Voila!
Scott
Re: '69 Satellite Wagon Project [Re: StukaJU87] #871588
01/28/11 11:14 PM
01/28/11 11:14 PM
Northern NJ
Northern NJ
Got a bunch more done today. Got the radiator back. Put the horns in. Carb, coil, battery box, alernator, hooked up the starter. Kickdown cable hooked up at trans. Started to run the new engine wiring harness, etc.
Scott
Re: '69 Satellite Wagon Project [Re: StukaJU87] #871589
01/29/11 12:00 AM
01/29/11 12:00 AM
Looking really good!
Re: '69 Satellite Wagon Project [Re: ] #871590
01/29/11 07:00 PM
01/29/11 07:00 PM
Northern NJ
Northern NJ
Thank you. I appreciate that.
Scott
Re: '69 Satellite Wagon Project [Re: StukaJU87] #871591
01/29/11 07:06 PM
01/29/11 07:06 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
This is going to be an awesome wagon. Definitely going to turn heads. Keep up the good work.
Re: '69 Satellite Wagon Project [Re: MuuMuu101] #871592
02/03/11 09:42 PM
02/03/11 09:42 PM
new jersey
copper74 Offline
copper74  Offline
new jersey
looks killer!
Page 2 of 3 1 2 3
