Re: TO SPRAY OR NOT TO SPRAY
[Re: fishy340]
#871235
12/05/10 03:58 PM
12/05/10 03:58 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
I'd love to spray mine. Don't know how I've gone 4+ years w/o spraying it, especially w/ the harrassment I get from my friends. They all spray...a LOT. My thing is that if I set the car up to run on nitrous, it'll run like a turd on motor w/ less gear and a tight converter. That is the only reason I don't want to do it...atleast on the cuda. It'd easily run 8's on a plate, but... I still have the Cheater system I used to get my first 10 sec timeslip several years ago...it was hard to take it off, lol.
[Re: an8sec70cuda]
#871236
12/05/10 05:20 PM
12/05/10 05:20 PM
Posts: 197 New York
Dustin71
New York
DO the right thing..... FOGGER,... FOGGER,.... FOGGER,......
[Re: quick77rt ]
#871239
12/05/10 08:29 PM
12/05/10 08:29 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Its very cheap just to bolt on a small kit and go, it costs alot to build around a spray motor.
Its fun, but it does have a learning curve thats not very forgiving...
http://www.youtube.com/watch?v=OGE-EsZIHKY
Not always the case. If things are done properly, I know many people who have used plenty of nitrous and never hurt a thing. Just like anything else...proper preperation is the key to success.
Monte
[Re: MoparBilly]
#871240
12/05/10 08:51 PM
12/05/10 08:51 PM
Posts: 4,072 Mo.
racerx
Mo.
Uneducated N20 user here... Part time, maybe 10 or 20 "Hero runs a year...it's great! wouldn't even consider leaving home without it. I've went 10.17-131, came back around turned on the bottle with a 9 degree retard chip in the 7Al3, and went 8.96-146, same fuel, same plugs, same moly coated rings!
I've also torched head gaskets, warped a few pistons, and even made a few stock 440 rods look like noodles, but I'd do it all again, the time slips were worth it.
Just curious on what block and at what weight?
[Re: Monte_Smith]
#871241
12/05/10 09:50 PM
12/05/10 09:50 PM
quick77rt
Parts Problem
Parts Problem
Yep, Mine was human error, all mine...I got to take the lumps, all is back together and running great. Overall an easy fix. (six boosters replaced, motor freshenup, some paint work, ect..) I had a small window with the road closed and was not prepared...wild ride but not planning on a repeat. That was my first nos issue ever, got a bit more respect for that blue bottle these days. Quote:
Monte
