Page 3 of 7 1 2 3 4 5 6 7
Re: So, how much braking do you really need? [Re: Mike H] #870596
12/04/10 04:56 PM
12/04/10 04:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Second thought, a little off subject, is if torsion bars were such a great thing, why don't cars today use them? Or do they?
My 98 chevy pickup uses them.
Re: So, how much braking do you really need? [Re: Challenger 1] #870597
12/04/10 05:40 PM
12/04/10 05:40 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
My '02 GMC HD does as well..
Re: So, how much braking do you really need? [Re: Mike H] #870598
12/04/10 05:42 PM
12/04/10 05:42 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
It seems like the best way to improve an old cars braking, even with stock drums, would be to install some kind of ABS system. But I have never heard of anyone doing that. Is it too expensive/complicated to design/install?
I did it to a Camaro, but it was the really long way around to get ABS and traction control in an old car
http://www.cardomain.com/ride/2682662/1969-chevrolet-camaro
Re: So, how much braking do you really need? [Re: Challenger 1] #870599
12/05/10 12:03 AM
12/05/10 12:03 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
'01 Durango has 'em, too.
BTW, front brakes on the Durango are discs 11.3 inches in diamter, and rears are drums (they look to be 11x2 or so). Braking is satisfactory although the discs have a tendency to warp. Later model Durangos ('03 and up), I believe, have 13" rotors, and discs in the rear. Maybe Ma Mopar learned something in 5 years from '98 to '02.
Re: So, how much braking do you really need? [Re: MoparMarq] #870600
12/05/10 12:56 AM
12/05/10 12:56 AM
AndyF Offline
AndyF  Offline
Most everyone has learned by now the value of big brakes. Any modern car that has the power of a 440+6 or a Hemi will have at least 13 inch rotors on it. Even the lower price Mustangs and Camaros come with big brakes these days.
Re: So, how much braking do you really need? [Re: Mike H] #870601
12/05/10 12:27 PM
12/05/10 12:27 PM
London, England
Gavin Offline
Gavin  Offline
London, England
ABS does not actually improve the available braking capability.
Re: So, how much braking do you really need? [Re: Gavin] #870602
12/05/10 06:10 PM
12/05/10 06:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
No but it does prevent you from locking the tires, and in theory locked tires on pavement slow down less rapidly than when ABS keeps the tires at their point of maximum traction.
it seemed like one second i was doing 110, and the next second i was doing 60. no dive, no swerve, no sway, it just felt like instantaneous deceleration! i gained a whole new respect for brakes after that.
Yes but was that because of big brakes or was that because of it having a much better setup suspension, tires, stance, lower center of gravity, favorable mid-engine weight distribution, etc?
Re: So, how much braking do you really need? [Re: DaytonaTurbo] #870603
12/05/10 06:34 PM
12/05/10 06:34 PM
London, England
Gavin Offline
Gavin  Offline
London, England
Well the comment made was "the best way to improve an old cars braking"....and ABS does not improve braking.
If you're saying that braking with non-locked wheels is better than locked wheels, then yes of course it is, I doubt anyone is arguing that. But it doesn't take ABS to avoid locked wheels - proper set up and threshold braking.
Re: So, how much braking do you really need? [Re: Gavin] #870604
12/05/10 06:49 PM
12/05/10 06:49 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
ABS makes stopping faster in panic situations for people who haven't practiced panic braking and keeping the brakes right at that threshold. Every winter on an empty stretch of slick road I'll practice how fast I can punch the brakes and stay on the edge of locking them up.
The current set up on my truck ('72 W200, discs all the way around), I can't lock up the fronts. But that may be more due to the 32s and dry pavement This spring I'll get a pressure gauge and do some more testing.
Re: So, how much braking do you really need? [Re: hooziewhatsit] #870605
12/05/10 06:54 PM
12/05/10 06:54 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I think that very important point is worth repeating, and to state the obvious is ABS "cycles" brakes between near lockup and release, and that actually increases stopping distance over the experienced driver as you mentioned.
Re: So, how much braking do you really need? [Re: jcc] #870606
12/06/10 03:43 PM
12/06/10 03:43 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
Re: So, how much braking do you really need? [Re: jcc] #870607
12/06/10 05:04 PM
12/06/10 05:04 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Keep in mind that ABS trades off tire skidding for additional heat.
Brakes convert the energy of the car in motion to heat energy via pad/rotor friction. You have to manage that heat. Larger rotors not only give better leverage but they also provide a larger heat sink. A simple example would be to touch a lug nut after you exit the highway and pull into a service station. The lug will be warm. The brake rotor and hub would likely burn your fingers. Even driving home after work will put enough heat into the brakes to feel (or burn) by hand.
In a 10.9" B-body rotor you've got maybe 10 pounds of rotor with venting to disperse the heat. The rest of the mass in the hub portion of the rotor does soak up some heat but it has no way of dissipating that heat. Without serious ducting and forced air they won't last long when pushed hard. It's also one of the reasons you need high temp grease for wheel bearings (they make their own heat too).
Have you ever stomped the brakes at high speed and been able to smell the pads and rotors cooking?
The MB rotors I use tip the scales at 27 lbs. The majority of that weight is in the vented surface area. It can dissipate much more heat than the small factory stuff. The cross drilled holes take some weight out of the rotor and offer a tiny bit of venting.
Here's a video of the SLR's carbon ceramic brakes glowing after a single stop from 120 mph.
http://www.youtube.com/v/apDIP5PU1WU
You can see how serious they were about cooling the brakes by the ducting running into the hub as well as the top of the caliper.
- Stu Harmon
Re: So, how much braking do you really need? [Re: jcc] #870608
12/06/10 08:24 PM
12/06/10 08:24 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I'll third that and add that I've read tests where in side by side comaprisons, profesional drivers can outdrive the ABS computer.
Seperate fromteh original topic, but relative to ABS, I've been in off road situations where locking up the tires and pushing a gravel berm in front of them was a much safer way to stop than having ABS modulate a vehicle into a potentially disastarous situation.
Re: So, how much braking do you really need? [Re: TC@HP2] #870609
12/06/10 10:01 PM
12/06/10 10:01 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
To the OP's question;
how much brake you need depends on what you do with the car. For most people a properly set up factory set of drums would do although fade is an issue with REPEATED use (a one time panic stop is unlikely to be repeated until the brakes have cooled or high speed stops (over 60 mph) which also aren't that common in day to day driving.
A factory disk/drum setup with decent tires is more than adequate for most any non-roadracing aplication.
The huge rotor/6 piston caliper setups just aren't needed for a street driven car, but people buy them mostly cause they think they look cool.....sorta like the soccer moms in thier Rubicon Wranglers that have never been off pavement.
Another thing to consider is comparing say, the brakes on my 06 Durango is kinda misleading unless you remember that the Durango outweighs my Superbee by over 2000 lbs!
I still remember trying to slow down my brothers drum braked, 427 powered GTO from 150mph......that took awhile! my factory disk/drum equipped 442 was a lot nicer to slow down from those speeds.
I laugh when someone suggests you need 4 wheel disks to stop properly! god help you if you jamb on the brakes of your new SRT8 right in front of my (4 wheel disk equipped) Ram dually when I have my camper on! at 12,000 lbs, I'd suggest a 68 drum braked coronet will stop faster.
2 pennies,
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: So, how much braking do you really need? [Re: DPelletier] #870610
12/06/10 10:56 PM
12/06/10 10:56 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Drum brakes will actually lock your wheels quicker than disc brakes because the shoes will actaully turn into the drum and 'self tighten'. Bad thing is that they will heat up an fade in repeated stopping or applying.
Re: So, how much braking do you really need? [Re: MoparforLife] #870611
12/07/10 12:41 AM
12/07/10 12:41 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Locking the tires is rarely desired. Most of the time it'll lead to VERY long stopping distances. Those are closely followed by insurance claims, personal injury attorneys, and a couple months of waiting for your car to get out of the body shop.
When I see the guy in the 4 wheel disc equipped Ram with the 12,000 lb camper jack knife in the middle of the road and dump the rig on it's side, I want to know that my 4 wheel disc brakes will stop me before I slam into the roof of his overturned truck and squash him like a grape.
No, I don't need 14 inch rotors on the front of my 65 Belvedere. However, it is the best performing brake package I've had on the car AND it was the most affordable at the time. There is a noticeable difference between these and the standard old Mopar disc brakes. These are MUCH nicer, even in daily use.
Let's not bring up the 4 wheel drums and single pot master cylinder this car left the factory with. They were horrible.
- Stu Harmon
Re: So, how much braking do you really need? [Re: feets] #870612
12/07/10 12:44 AM
12/07/10 12:44 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
That is pretty cool looking.
I need to make up some duct work for mine actually...the front spoiler I have already has the opening for the brake cooling ducts (the touring/road race cars used them) Just need to run some hose from there to some sort of mount behind the rotor.
Re: So, how much braking do you really need? [Re: feets] #870613
12/07/10 01:19 AM
12/07/10 01:19 AM
DPelletier Offline
DPelletier  Offline
Don't worry Feet's; firstly, I'm not going to be jacknifed in the middle of the road, and secondly, your little car isn't going to squash me like a grape!
for the record, I have nothing against you building your car as you like with 16" brakes if that's what you choose. The point I'm making is that you don't need that to be safe driving amongst traffic.
Re: So, how much braking do you really need? [Re: DPelletier] #870614
12/07/10 10:06 AM
12/07/10 10:06 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
11" Hemi Drums all the way around on the 69 Coronet. www.praisedynobrake.com kit.
Adequate braking performance. Push on them and you stop. Don't drive like a gdam fool and close on stopped traffic 5 times in a row and all is well.
Re: So, how much braking do you really need? [Re: feets] #870615
12/07/10 10:23 AM
12/07/10 10:23 AM
Upper Midwest
Upper Midwest
eets you are right. I neglected to finish the statement for some reason. Locking up the tires will a lot of the time lead to very bad consequences. IE: Bad skids, broadsides, etc. Just made a comment on drums is all I did. sliding tires after a very few feet turn to like a liquid to slip and slide on.
