So, how much braking do you really need?
#870556
12/03/10 11:45 PM
12/03/10 11:45 PM
Posts: 253 Orange County, CA
Mike H
Orange County, CA
I can't recall having any difficulty bringing my 69 340 Dart (manual drum brakes) down from 110+mph, many times. So what's the deal with the massive disk brake setups so popular today? Ten inch, 12", 14" rotors, 4 pad, 6 pad, what, 12 pad? I've never even ridden in a mopar that can handle as well as my wife's 90 Camry, or even our Suburban with my wife, kids and the dog in it. So I assume nobody's driving LeMans or Nurburgring. Where the heck are you guys driving that you need so much braking? Down a mineshaft?
Re: So, how much braking do you really need?
[Re: Mike H]
#870559
12/03/10 11:55 PM
12/03/10 11:55 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
There used to be a saying about never having enough horsepower... I just figure you can never have too much braking potential. And if I do ever get the car out to a road course/open track day sort of thing or run it really hard up in the hills/canyons I know I will never overheat or run out of braking. ![](/ubbthreads/images/graemlins/thumbs.gif) (I really wish I could have used the matching 8 piston AMG Brembo calipers for the AMG 360mm rotors...but feets couldn't do me a good enough deal on them ![](/ubbthreads/images/graemlins/laugh2.gif) ) ![](http://i415.photobucket.com/albums/pp237/ozhemi/044.jpg)
[Re: goldmember]
#870560
12/03/10 11:58 PM
12/03/10 11:58 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
braking is typically limited by tire grip and thermal dissipation. 3 cars with identical weight, weight distribution, and tires, one with 10.87" discs, one with 11" drums, the other with 13" discs will probably stop in the same distance from say, 60 mph. but do multiple hard stops from speed, you'll get brake fade quickly with the small disc and the drum car....
my duster stops very good with 10" drums all the way around....from say, 50mph. once on the freeway, I had to make a hard stop from 75mph when an accident happened a few cars ahead of me....by 25MPH my brakes were gone from heat soak....had to swerve and go in the grass to avoid the car in front of me....
[Re: Keith Black®]
#870562
12/04/10 12:02 AM
12/04/10 12:02 AM
OzHemi
Garden Grove, CA
...for me, I like the extra "braking horsepower" that 4 wheel discs offer. THAT, plus they look nice through the spokes of the 18 inch rims!
![](/ubbthreads/images/graemlins/iagree.gif)
Wilwood's largest 6 piston SUV caliper & 14.5" discs:
If you had a small car like a Torana, only 14.17" rotors like mine would do.. ![](/ubbthreads/images/graemlins/laugh2.gif)
(They are 1.41" thick too )
[Re: Mike H]
#870564
12/04/10 12:09 AM
12/04/10 12:09 AM
Posts: 606 Montana
Yancy Derringer
Montana
I'd suggest your memory is remembering the "good times"
My 64 426 Dodge had 11" brakes and a front sway bar stock. I did not have what I'd call "a lot of reserve"
My 69 383 Roadrunner with 11" manual brakes didn't either
My '70 440sixpack had single piston power front disk, and I guess 10 1/2" in the rear. It was more than adequate, but I did some trailer towing---a pretty loaded move from San Diego to N Idaho once, towing a '70 Cuda on a trailer and lots of personal junk. The trailer had electric brakes, but I would not consider that car had "tremendous" over braking capacity.
[Re: Mike H]
#870565
12/04/10 12:11 AM
12/04/10 12:11 AM
RapidRobert
I'm gonna fab some rear discs on a SBP 8&3/4 as I ran across some late MP SBP disc rotors from God knows what that are sitting idle/use fabbed brackets/probably 73 A 2.60" calipers. The proportioning may (& prob will be) off but I'm bored and want to know (if 4 wheel discs are good). Just dont know how the endplay is going to affect things but I'll get it close to zero. I have a DD 65 dart w 74 A (2.75") discs/10" bbp drums/stock 4 wheel drum splitter/large bore (1&1/8" iirc) M/C and it stops real good (though the rears lockup 1st on a panic stop) but I drive like an old man around town so no probs and the semi met pads (or rotors) are not wearing significantly that I can tell. All is good ![](/ubbthreads/images/graemlins/thumbs.gif) .
[Re: patrick]
#870566
12/04/10 12:13 AM
12/04/10 12:13 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
There are a lot more factors but I'm not going into it. I'm used to stopping from well above 120mph and the factory drum brakes in great shape with the proper shoes(not replacement crap) are capable,but fade will become a problem on repeated stops. With the factory tires and such I wouldn't worry so much about real braking. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Mike H]
#870569
12/04/10 12:47 AM
12/04/10 12:47 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
If you are running drum/drum setup, the quickest and easiest bang for the buck is to upgrade to the widest tires that will fit your rims and wheel openings. The bigger contact patch is huge. OEM drums with skinny tires would lock up and skid big time when you stood on them. With a good brake rebuild w/ 4 wheel drums and fat tires, you can stand on the brakes and the tires will not slide. For drag strip use, the setup is plenty safe. If you are doing rallye racing (or an aggressive driver on the street), that is quite another story ![](/ubbthreads/images/graemlins/tsk.gif) Need disc's up front then.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#870570
12/04/10 02:21 AM
12/04/10 02:21 AM
Posts: 606 Montana
Yancy Derringer
Montana
...drum/drum setup, the quickest and easiest bang for the buck is to upgrade to the widest tires that will fit your rims and wheel openings.
While you might have a valid point so far as a panic stop, this will do NOTHING for brake fade on a curvy, hilly, hard driven road.
Also, it's important to realize that larger DIAMETER tires effectively cause a "geared up" effect on the brakes (of all kinds) and lessen the braking effect
[Re: Challenger 1]
#870573
12/04/10 03:11 AM
12/04/10 03:11 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Front disc brakes are a godsend as far as braking goes. Mopar disc brakes are are pretty dang good especially with a proportioning valve in the rear brake line, it helps to balance front to rear braking.
Last summer I drove my 74 340 challenger to the top of Pikes Peak, which meant I had to drive back down that huge mountain.
I not so sure drum brakes wouldn't over heat coming down that thing.
Halfway down, they stop you and shoot your brakes with a heat gun. I thought I was hardly even using the brakes running in low gear and second but the guy said they were hot and I should let em cool.
Sign say "hot brakes fail" This is at the top, on the way down
Pikes peak is really tough on brakes, expecially with a auto trans or where you can not use engine braking. usually having to be on the brakes because of slower traffic in front of you, and moving too slow for force air through the rotors for the brakes too cool. That said, I'm still running the stock 11" manual drums on the Coronet, but it is a manual trans with 4.10:1 gears ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Mike H]
#870575
12/04/10 03:43 AM
12/04/10 03:43 AM
Posts: 22,772 Bitopia
jcc
Bitopia
To answer your question, keeping up with the jones's, mines bigger then yours, fad, etc. I might even be guilty. Technically it all comes down to how many times you want to stop from speed. And most of the time on a road course with a non race car, the biggest first brake improvement is simply fresh High temp brake fluid, next is decent air ducts to front brakes, and decent pads for the application. And massive oversized brakes will lower a cars driving performance unless we are talking CF rotors, because of rotational mass of huge rotors. If what you got works, just maintain it, and smile at the newest/greatest/biggest crowd. ![](/ubbthreads/images/graemlins/Twocents.gif)
